Question about Dell ST2321L Black 23" 5ms LED Backlight Widescreen LCD Monitor
Remove monitor stand
Remove stand
Can we remove stand from monitor HP 2010i
Dear yes you can remove stand of HP monitor with the unlock behind the monitor near stand neck.
Thanks
Firoz Ali
Apr 28, 2014 | Computers & Internet
I need to remove the viewsonic VX2433wm stand.
mine has 4 silver screws running perpendicular to the stand shafts, remove the 2 pairs and the stand should slide out the bottom.
Mar 17, 2013 | ViewSonic VX2433WM 24 inch LCD Monitor
Remove stand from lenovo li2321s monitor
in between the stand rails is a removable piece of plastic with a sticker that contains the "nutritional information" about the monitor. If you remove/pry it off you will fine 4 screws that remove the monitor stand completely.
Jan 30, 2013 | Lenovo Computers & Internet
Remove stand from monitor
there will be screws on the back which will allow you to remove the stand, then on the back of the monitor their should be 4 screw holes, use these to attach a a flat plate wall bracket to it.
but if you can't remove the stand, then put a clap speaker bracket on the wall & just clap the base of the monitor, as this type of bracket can be adjusted both in & out & up & down.
Jul 21, 2012 | Acer AL1711 17" LCD Monitor
I cant remove the stand of my LG 194WT monitor
Here is the manual for your monitor, it will give you the instructions on how to remove the stand.
http://www.retrevo.com/support/LG-L194WT-Monitors-manual/id/440bh350/t/2/
Feb 28, 2011 | Computers & Internet
How to remove the bottom stand of the monitor
You just have to remove the black plastic cover over the stand hinge, then you will see the stand mounting screws.
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Sep 24, 2010 | ViewSonic VA1930WM LCD Monitor
How do you remove the stand from a BenQ 767?
remove screws either side where stand go into back of monitor.
then slide stand toward bottom of monitor and it should slide out
Jan 14, 2010 | BenQ FP767 17" LCD Monitor
Can not remove the stand to mount it on the wall
If the Aquos 46 is anything like the Aquos 42, the monitor is attached to the base with machine screws (bolts). They are located in the lower back portion of the monitor, probably need an Allen wrench to loosen and remove. Once that is done, the base can be removed from the monitor. Best way is to lay the monitor face down on a tabletop padded with foam, a quilt or blanket, etc to protect the screen as you work. Remove the stand from the monitor, not the monitor from the stand; it is easier and safer that way.
Jan 18, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Dell ST2321L Black 23" 5ms LED Backlight Widescreen LCD Monitor Logo
21 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
