Question about Pool & Spa
How do you set pentair TMRLX 24 hr pool pump timer
  • 7,627 Answers
Posted on May 10, 2013
4 Suggested Answers
smartr10U
  • 1305 Answers
SOURCE: pool pump was on had a storm electric went out.
Pull the lid and strainer basket off your pump and reach in (electricity will be off at this point) and make sure that the pump inlet isn't blocked with debris from the storm... small stuff can get thru the strainer and jam up the pump motor... I know...i've got the pool from hell ...constantly jamming the pump...but it's next to a huge evergreen tree...
after you get the debris out, take a crescent wrench and remove the cap off the motor shaft on the outside of the pump. Turn that shaft with a wrench back and forth to free up the motor and dislodge the debris... if it frees up, put it all back together and turn the power on...you may have to repeat this process a coupe of times to completely clean the impellers in the pump.... good luck!
K
Posted on Aug 06, 2009
  • 64 Answers
SOURCE: pentair pool pump vs 3050
These pumps should not be hooked into an intermatic mechanical timer. It should always have power supplied to it, meaning it should be installed to the line side of the power supply. Scheduling is done either in pump itself or thru an external controller such as a suntouch or easytouch controller, etc. When you have it wired into a timer like intermatic, power is interupted to the pump every day when the timer setting is for off. It is very hard on the drive of this pump, it does not like it, and will shorten the life of the drive. The pump was designed to always have power supplied to it, even when it is not scheduled to run. This may be the problem you are experiencing. HTH
Posted on May 22, 2010
  • 22 Answers
SOURCE: 2010 Easy Set 2500 Gph Swimming Pool Filter Pump (): ok we have the 24 by 52 in intex metal frame pool ...
88 It is the Setup/Start up Code. it is displayed until you set the timer. which you do so by holding down the down arrow till you hear a beep, then hold down the up arrow till you here a beep. from there you can set the time and then to lock it in repeat the process. On the filter set it to run atleast 1 hour longer than you SWS. set the timer on both at the same time.
Posted on Jun 17, 2010
How to set pentair TMRLX 24 hr timer for pool
Copy following link for setting Pentair timer:
http://waterheatertimer.org/How-to-set-timers.html
Pentair timer appears to be ordinary FM1 timer module.
This timer module is sold separately and used by many companies to control pools, spas, boilers, water heater systems, hvac thermostats, off-peak timer controls etc.
Add a comment and describe timer in detail, including voltage, and what you have done so far.. etc.
May 10, 2013 | Hardware & Accessories
Hi - My Intermatic T101P3 timer motor stops after it turns off the pool pump. I have one start and one stop time in a 24 hr period. I have to manually start the pump at the timer in the morning,...
Sounds like the clock leads are on the wrong posts, or at least the hot one is. If if was moved to the load side then manually starting the timer will also power up the clock motor. As soon as the clock trips the off timer, the pump and the clock motor are both off. Examine the clock leads to the wiring diagram inside the clock box cover to ensure they are connected correctly. I bet you'll find one of the wires is misplaced.
John
Aug 31, 2011 | Intermatic T101P3 Pool Timer IndoorOutdoor...
I just replace a T101 with the same timer. The old one stopped turning. The new one has the same problem. It is getting power because I can manually switch on the pool pump. The timer just won't...
The switch for the pool pump does not necessarily run from the same power as the timer motor...
Check for timer motor rated power on the first two terminals that run the timer motor...you may not have proper power there...you may have 120v but not 240 volt...
heatman101
Aug 12, 2011 | Intermatic T101 - 24 Hr. Dial Time Switch...
My Pentair pool pump runs continuously even though it is set to auto on outside & inside panels.
If your pump is running constantly either the timer is set to "manual on" or the timer has failed. Check the settings on your timer. Usually on a mecanical timer the manual on lever is just under the 24 hour dial. On the electronic timers it is controlled by a relay that if it fails defaults to always run.
Jun 12, 2010 | Garden
Will Pentair Intelliflo pump save me enough money to justify cost
Here are a couple of thoughts. If you install an intelliflo pump and run it for the same amount of time and at the same rpm as your current pump, you will still have a savings. If you drop the rpms by 1k, you will have an exponential savings. Go to the pentair website and use the program to estimate your actual savings. You can still run the heater at a reduced flow setting but there is a limit, you have to check with the heater manufacturer to see what the minimum is.
If you are running a conventional pump 24/7 you are using a ton of energy. You should be able to run the pump for 8 hours a day and achieve the same results. For instance, running the pump from 4am to noon should give you a good window to maintain the heat and not run it all the time. It also depends on if you have a cover on your pool when it's not in use. If you don't, you will lose significant heat when it's not running, however, running it early morning should give it a chance to heat back up before you want to use it again. You will have to experiment with timer settings, etc..
I really do think the intelliflo pump is a great pump. The rare earth magnet design allows it to be way more efficient than the conventional pump. It is so much more efficient that when it's running, you can hold your hand on the motor and it is just warm. Your pump motor probably runs very hot, heat is a by product of inefficiency. I hope this helps.
Jan 19, 2010 | Pentair Intelliflo Pump 4x160
I am looking for the most energy efficient way to run a 10,000 gallon indoor pool 365 days a year. Would i need a timer to optimize my electricity savings with the use of a Pentair IntelliFlo 4x160 pump or...
You run a pool pump based on pumping volume compared to pool volume and long enough to turn the water over frequently enough to keep it balanced and clear.
You should have no need to run it 24 hours a day to accomplish that since the pool is indoors and safe from the effects of weather and sunlight.
What you will want to do is determine the minimum amount of time then the pump needs to operate to keep the water balanced and clear based on fill water makeup, your chemical choices and bather loads and then set the timer to run the system for that amount of time and the pump for the speed required.
If you really want to be sure you are as efficient as possible you will need to look at the pump curve for your exact model and look for the point on the curve the pump is most efficient at, speed/volume wise and run it at that setting for the time you find thru experience mentioned above. That way the pump moves the most water it can at it's most efficient point for as little time as is required to keep the pool clean.
I hope I worded that in a way that makes sense.
Dec 07, 2009 | Pentair Intelliflo Pump 4x160
No power at the control panel - MasterTemp 250
check for 24 vac at the transformer if 24 check for fuses
Aug 16, 2009 | Pentair Mastertemp Pool & Spa Heater Dual...
Pentair pool pump vs 3050
Jun 02, 2009 | Pentair IntelliFlo VS+SVRS Pump 230v -...
Pool & Spa Logo
71 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
