Question about QSC K12 Speaker PA Active
Qsc k12 schematic
CUANDO SUBO LA GANACIA LA CABINA SE APAGA Y VUELVE PRENDE
    Habit-Forming:
  • 10 Answers
Tengo el mismo problema, ella suena pero al subir la potencia se apaga, supongo es una soldarura mala, si es asi por favor especificame adonde y si es otra causa favor indicar.
Agradecido de ante mano!
Posted on Oct 06, 2014
Lost power
might be the fuse or its power supply board faulty. check and confirm, if the power supply unit is faulty talk to qsc the have replacement modules as repair might give you hard time.
Apr 15, 2014 | QSC K12 Powered Speaker Package
Qsc hpr153i rattle
Please specify a bit more, does the rattle is physical(Enclosure structure) or electronically hear thru speaker(Power Amp Common Issue)? I have the solution for the amp issue, let me know.
Mar 20, 2013 | QSC Audio Products QSC HPR153I 12 SPEAKER
Not putting out sound fan on light on
A common issue with the QSC RMX series amp is faulty volume pots, so i would recommend go this way first of all, let me know a bit more to improve help.
Feb 04, 2013 | QSC Audio Products QSC RMX 850 RMX850...
Qsc hpr181i blow fuse
Two possibilities here, one is a cracked pin on one of the power supply UF diodes and the other one that the power output devices got fried.
Jan 30, 2013 | QSC Audio Products QSC HPR 181i
My QSC PLX 2502 amp completely blew. Channel 1 has been giving me problems for a year and I have had the amp about 3 years. This past week it drove into the red so much and I could not stop it. Well now...
You should NOT drive the amplifier into the clipping mode continuously. There is a possibility that you have fried your speakers or that they are the real problem. You haven't told us what you were driving, however this amp will deliver 450 Watts per side RMS at 8 ohms which means your speakers have to be rated at least that much RMS power for continuous. When speaker voice coils fry, they can wipe out amplifiers. Let us know what speakers you are using and how they are configured. This amp is going to be expensive to repair I can tell by looking at the schematic: Here is the schematic:
http://elektrotanya.com/qsc_plx2502.pdf/download.html
Scroll down to "get manual" and click to download it. IGNORE other download links.
This amp has circuits to boost the power supplies to the amps to handle the peaks. It is rather complex but the schematics are complete and have good explanations... some of the best I have seen. There are going to be a lot of destroyed components and great care has to be used after repair to "cold start" the unit to make sure nothing else is bad or it will blow up again. Most people do NOT have trouble with the QSC amps... so do tell me what speakers you are using and how they are configured so we can verify the design is correct. This amp is rated for 8 ohms so USUALLY only ONE speaker can be connected per side... and finding an 8 ohm speaker that can take 450 watts continuous RMS isn't easy. People fall for the advertising claiming "Peak" and "Program" power which are FAKE advertising... ONLY use continuous RMS power when sizing amps and speakers. There are MANY ways to cook out equipment... One is to boost the bass or the treble way up. Another is to NOT use balanced interconnect lines between mixers and your amps. Yet another is to NOT power ALL interconnected equipment from a single receptacle or power conditioning module. Please describe your setup further so I can help you more!
Sep 20, 2011 | Qsc Plx-2502 450w Per-Ch. 8 Ohms Amplifr...
I connected my QSC K12 to a powersupply that was dimmed, The power. Switch was turned on when I connected the power cord and I heard a booming sound that came with a spark.I suppose the fuse has to be...
This can be found on the QSC Support site and appears to be the only reference to the problem on these loudspeakers. Check the site at the link below:
Open up the cabinet, take a look and tighten up the clips that hold the fuse for the horn in place...Tech. support said they've seen that problem many times in the past.
http://forum.qscaudio.com/forum/search.php?fid[]=4&sid=f7645ff1016aafa7fd5b992d30770052
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Jun 02, 2011 | QSC K Series K8 2-way 8" Active...
K12 power in and out??? Fuse OK. What to check next?
Late response but that sounds like a cracked pin at one of the power supply uf diodes...
Dec 27, 2010 | QSC K12 Speaker PA Active
Have a blown capacitor in a QSC PLX 3602. It's the large black capacitor near the on/off switch. Can't read the letters and numbers. What is this capacitor? Thank you.
I need a board marking number as there may be several caps near the on/off switch.
Example:
C117 .47mfd 250VAC (use 600VDC)
C126 .1mfd 250VAC (use 600VDC)
C132,133,136,137,140,141, All 2200mfd 200VDC (These are large canned units)
Note if one of the latter ones, better check the full wave rectifier bridge for a bad diode as well.
I have the schematic but not an assembly drawing so description of near switch doesn't tell me enough.
Oct 29, 2010 | QSC PLX3602
QSC K12 Speaker PA Active Logo
252 people viewed this question
Top QSC Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a QSC Music Expert? Answer questions, earn points and help others
