Question about Smith A.O. SMITH Cyclone XHE Natural Gas Commercial Water Heater BTH-120
Hi temp water - Smith A.O. SMITH Cyclone XHE Natural Gas Commercial Water Heater BTH-120
  • 7,627 Answers
Adjust Temp setting. Perhaps this will help: http://www.hotwater.com/lit/im/com_gas/197727.pdf
Posted on May 10, 2013
Clean light is flashing. Dishwasher will not start.
Hi
If clean light is blinking then it may be an issue with heater circuit, door switch or wash pump, please reset the power to the dishwasher. After, 5 minutes check if you are still getting the same error. If yes, then it is a water heating fault. To resolve this error try pressing this reset sequence-- Heat Dry - Normal - Heat Dry - Normal or High Temp - Air Dry - High Temp - Air Dry or Hi Temp Scrub, energy saver dry, Hi Temp Scrub, energy saver dry or High Temp Wash-Heated Dry-High Temp Wash-Heated Dry. Now let the unit run for 2-3 minutes and then you press the Cancel/Drain button and allow it to completely drain and reset. If this doesn't work then it's an issue with the wash pump not pumping the water past the heater efficiently or due to lack of water to heat. Please make sure that heater is not open circuited and is heating the water efficiently. You'll have to check the heater using a multimeter; the meter should read between 3000 to 3300 ohms (Use multimeter on Rx1 ohm setting). If heater is fine then make sure water pressure is optimum and fill valve is working fine. Hope this helps... Please post back if you need more information.
Daniel
Aug 29, 2011 | Whirlpool Dishwashers
Clean light "green" flashes 7
Hi
If clean light is blinking then it may be an issue with heater circuit, door switch or wash pump, please reset the power to the dishwasher. After, 5 minutes check if you are still getting the same error. If yes, then it is a water heating fault. To resolve this error try pressing this reset sequence-- Heat Dry - Normal - Heat Dry - Normal or High Temp - Air Dry - High Temp - Air Dry or Hi Temp Scrub, energy saver dry, Hi Temp Scrub, energy saver dry or high temp wash-heated dry-high temp wash-heated dry. Now let the unit run for 2-3 minutes and then you press the Cancel/Drain button and allow it to completely drain and reset. If this doesn't work then it's an issue with the wash pump not pumping the water past the heater efficiently or due to lack of water to heat. Please make sure that heater is not open circuited and is heating the water efficiently. You'll have to check the heater using a multimeter; the meter should read between 3000 to 3300 ohms (Use multimeter on Rx1 ohm setting). If heater is fine then make sure water pressure is optimum and fill valve is working fine. Hope this helps... Please post back if you need more information.
Daniel
Aug 29, 2011 | Dishwashers
Whirlpool gold quiet 3 dishwasher flashing clean light nothing works i had to push 2 button and cant remember code to reset unit
Hi
Daniel
Aug 28, 2011 | Whirlpool Dishwashers
My dishwasher has power to it but the heat dry option is lit and it wont start ant idea what to do?
Hello
Do you have any of the extra functions selected, such as "Hi Temp Rinse" etc?
The selector switch has a selection for Hi-Temp Wash; the switch is in parallel with a thermostat mounted on the bottom of the tub and with a contact in the timer. The
selector switch, temp assure thermostat, and the temp boost thermostat are all in series with the timer motor. Both thermostats are normally open thermostats. When
the timer reaches the end of the second wash cycle, the contact in the timer supplying power to run the timer motor will open. At which time, if the selector switch for the Hi-Temp Wash has been selected, power to run the timer motor must come through the thermostats. The temperature of the water in the tub must rise to 137° ±5° F for the thermostat to close and the timer motor to advance. If the water temperature is below 137° ± 5° F, the timer will pause until the heating element raises the temperature of the water in the tub and allow the thermostat to close.
Hi-Temp Rinse
If the selector switch was a selection for a Hi-Temp rinse, the switch is in parallel with a thermostat mounted in the tub, and the contact in the timer, the same as the Hi-Temp wash. The operation for the Hi-Temp rinse will be the same as for the Hi-Temp wash with the exception, on some models, the temperature of the water in the tub will be 150° ± 5° F for the thermostat to close to give a sanitizing rinse.
What do we learn from this? That you either have a bad heater or a bad thermostat. Check the heater for continuity with our OHM meter.
Aug 03, 2011 | Frigidaire Dishwashers
Hi have problem with canadian spa (balboa mrspa1) control panel digital reading when turned on goes to OH,circulation pump will not run
OHS, OH, or SPA TEMP LMT Message There is an "Over Heated Spa" (OHS or OH) Water Condition.
One of the Water Temp Sensors has detected 110°F (43.3°C) Incoming Water Temp and Spa Functions are Disabled. System will Auto Reset when Water Temp is below 108°F (42.2°C). Check for Extended Pump Operation or High Ambient Temp, or contact your Dealer or Service Organization.
Spa Water Cool Down
• In order for the Spa Water Overheat Error Message to Automatically Reset and Clear, the Spa Water Must Cool to below 108°F (42.2°C).
• Check the Topside Panel Display to see if the "OHS", "OH", or "SPA TEMP LMT" Spa Water Overheat Error Message has Cleared. If the Error Message has Not Cleared, the Spa Water is still too Hot to Continue Testing.
• Either Wait for the Spa Water to Cool Below 108°F (42.2°C), or Exit Now and Retest at a Later time.
You can find answers to COMMON SPA MESSAGES at the following website:
COMMON SPA PANEL MESSAGES
Hope this helps.
Mar 30, 2011 | Balboa Instruments Duplex Digital Panel 2...
Clean lite flashing
Hi
If clean light is blinking 7 times then it may be an issue with heater circuit, door switch or wash pump. If yes then please reset the power to the dishwasher. After, 5 minutes check if you are still getting the same error. If yes, then it is a water heating fault. To resolve this error try pressing this reset sequence-- Heat Dry - Normal - Heat Dry - Normal or High Temp - Air Dry - High Temp - Air Dry or Hi Temp Scrub, energy saver dry, Hi Temp Scrub, energy saver dry. Now let the unit run for 2-3 minutes and then you press the Cancel/Drain button and allow it to completely drain and reset.
If this doesn't work then it's an issue with the wash pump not pumping the water past the heater efficiently or due to lack of water to heat. Please make sure that heater is not open circuited and is heating the water efficiently. You'll have to check the heater using a multimeter; the meter should read between 3000 to 3300 ohms (Use multimeter on Rx1 ohm setting). If heater is fine then make sure water pressure is optimum and fill valve is working fine. Hope this helps... Please post back for further assistance.
Jan 30, 2011 | Kenmore Dishwashers
Here again is my model and serial it stops in the middle of the cleaning cycle Kenmore 665.16773402 serial # ft0302854 Here is how I have been resetting the dishwasher. I hit the following sequence of...
Door latch.
Open and close the door to make sure the door latch is securely fastened
Hi-Temp Wash, Hi-Temp Rinse, or Sanitize options.
Some models have options that may require a water heating delay, such as Hi-Temp Wash, Hi-Temp Rinse, or Sanitize. Additional time may be required to heat the water to the proper temperature. The dishwasher will continue to circulate water during this heating delay but the timer will not advance until the proper temperature is reached
Oct 06, 2010 | Dishwashers
HI IAM A ELECTRICIAN WORKING ON A LAAR HOT WATER BOILER WITH A STORAGE TANK THE TEMP IS SET TO 160 THE HIGH TEMP LIMIT SWITCH IS SET 200 AND THE AQUASTAT ON THE STORAGE TANK IS SET ON 120 THE BOILER COMES...
I would suspect a water circulation problem, most likely air in the system, if the water can't flow it will overheat.
If the problem persists after bleeding check to make sure the pump is running
May 06, 2010 | Heating & Cooling
Maytag mav6000 hot/cold problem
hi try to just regulate the temp by turning down the water flow from your taps if more cold is coming in than hot turn cold water down a bit to your satisfaction thanks THE APPLIANCE DOC
Sep 05, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Smith A.O. SMITH Cyclone XHE Natural Gas Commercial Water Heater BTH-120 Logo
49 people viewed this question
Top Smith Pool & Spa Experts
Mike Squire
Jay Finke
Jay Finke
Paul Carew
Are you a Smith Pool and Spa Expert? Answer questions, earn points and help others
