Toshiba satellite c660 Logo
Anonymous Posted on May 10, 2013
With out adapter not work - Toshiba satellite c660
max carson
Level 3:
  • Toshiba Master 7,627 Answers
  • Posted on May 10, 2013
max carson
Toshiba Master
Level 3:
Answers
7627
Questions
Helped
1015099
Points
21773
Is Samsung WIS09ABGN wireless LAN adapter compatible with Seiki LED TVs?
We know the adapter works as a wifi adapter. We DON'T know if your TV will accept ANY wifi adapter. What model is your TV?
I have a VTECH 6.0 and I believe a lightning strike took out the telephone base power adapter and would like to purchase a replacement adapter.
Any generic adapter will work as long as is is the same voltage and rating on the wall adapter you have. It is a 6 volt 400MA adapter. Radio Shack has generic adapters. Also try your adapter in another wall socket and see if that works.
Hope this helps.
1helpful
Hello. Today in the morning my laptop (Asus A8Jseries) was working alright. Then after 6 hours when i tried to turn it on, it didn't. I mean, it starts to work and Asus symbol comes alone, but then it just...
If it happens only when you move the adapter plug inside the power jack, it's likely that you have a problem with the power jack inside the laptop. The power jack has to be resoldered or replaced.
If it happens even without touching the adapter plug, the problem could be related to the faulty power adapter.
You can test the power adapter with a voltmeter and find out if the ouputed voltage is correct. If the voltage is not correct, replace the adapter.
http://www.chargerbuy.com/replacement-asus-a8-ac-adapter-19v-3-42a.html
But don't trust that even if the output votage matches specifications. It's possible that the power adapter doesnt' work correctly under load. Test your laptop with another known good adapter. If the laptop works fine with another adapter, your power adapter is defective and has to be replaced.
On screen display of dell ac power adapter not recognized......for dell studio 1555 does anybody have solution whenever i plug in my power cord into laptop ,,,,moreover battery is also not charging
2 possible causes, faulty adapter or faulty motherboard. try to update the BIOS if applicable. If this does not work, attempt to test the adapter on another laptop to confirm if it is working, or try a confirmed working adapter with your laptop. If same issue with another adapter, or if your adapter works with another laptop, it will be a motherboard problem. If the adapter fails on another laptop or if another adapter works with your laptop, you'll need to get a new adapter. Hope this sheds some light. Feel free to rate the usefulness of the information.
Newly set up,router working but no light on at all on the adapter when put into pc,is the adapter broken?
The LED on the adapter may be dead. Since the Router is work you don't have any problem. But if the LED being ON gives you the confidence that adapter is working, take it to an electronic repair to replace the LED on the adapter or buy another adapter.
1helpful
It does not connect
Wireless Adapter is a device that will receive the wireless signals and will make your computer wireless adapter. without the wireless adapter you can not use the computer to connect to the wireless network. Now a days all the laptops and desktops are equipped with the built in wireless adapters.
First check whether you have a wireless adapter on your computer ?
WIN XP
Right click on MY COMPUTER ==> properties ==> Device Manager ==>
you will see Network adapter ==> under network adapter you will see the wireless adapter ==> Right clink on the wireless adapter ==> properties => Check whether it says the Device is working properly or not ?If it says working properly then that's great !
WIN VISTA/ Windows 7
Click START ==> Control Panel ==> In the right hand side at the top you will see " Classic View "
Switch to classic view ==> you will see Device Manager ==> Under Network Adapters you will find your wireless adapter listed . Right clink on the wireless adapter ==> properties => Check whether it says the Device is working properly or not ? If it says working properly then that's great !
If you do not see wireless adapter in the Device manager , then either you do not have the adapter or the wireless adapter is not working .If you see "yellow exclamation mark" on the wireless adapter, that means the drivers are not installed for the adapter or not working. Reinstall the drivers.
Once your adapter is working properly , try to connect to the wireless network.
If you are installing the external wireless adapter to the computer and if you are using Windows 2000 or Windows 98 , ME, then you will have to connect to the wireless network using the utility of that adapter.
If you are using Win XP then you can use windows to connect to the wireless network or you can use other utility.
In case of Win VISTA, you will use windows to connect to the wireless network.
Click Here for more info
Ac adapter dont work it isnt the laptop itselfs its the ac adapte
Check your mains adapter plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced.
The adapter is a sealed unit and is very difficult to open and repair. Usually you need to replace the power adapter.
Can i install adapter to a macbook
You cannot install this adapter on your Macbook , it is only made to work with Windows operating system from windows 98se up to windows Vista, you can try to look for a airport adapter that will surely work with your Macbook...You can check this link for the complete details about this adapter http://cnet.nytimes.com/adapters-nics/netgear-wg111-usb-adapter/4507-3380_7-30791890.html
Hope that helps..............
Top Toshiba Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
