I have a Toshiba model SD-3990SU DVD player and when I load a disc it reads no and will not play.
  • 7,627 Answers
All DVD's, CD's, or just one? What is the Format of the Disk? Is it a Home Made disk? You can try to clean the Laser with one of these: http://www.google.com/#q=laser+cleaner&hl=en&source=univ&tbm=shop&tbo=u&sa=X&ei=dPmMUfTtGIOm8QSShYDwBw&sqi=2&ved=0CDYQsxg&bav=on.2,or.r_qf.&bvm=bv.46340616,d.eWU&fp=22cc289d1aeb76b8&biw=1024&bih=659
Posted on May 10, 2013
  • 1 more comment
  • michael Strauss May 10, 2013
    Thank you for your quick response. I used two DVDs that were from a store. I have cleaned the optic cell and it still reads no when you insert a DVD.
  • max carson
    max carson May 10, 2013
    I assume the two DVD's work on another machine. Well the obvious, I'm a genius for the obvious, the DVD player is defective, broken. Is it's under warranty? You purchased the DVD player in the U.S. and your using U.S. DVD's?
  • max carson
    There's not much you can do. You cound open it and look for loose connections, but, as you know, if a component is bad, unless you intend to troubleshoot a Circuit Board, it may be dead.
  • 1153 Answers
SOURCE: Toshiba disc error
Check formatted disc see if it's +R,-R and see if Toshiba will play homemade disk or just disc recorded in different format.
Posted on Sep 05, 2007
SOURCE: Toshiba SD-K860 DVD Player wont load DVD's
Having the same problem. DVD player loads enough to identify it is a DVD or a CD, but won't actually start playing anything.
Posted on Aug 12, 2008
  • 14 Answers
SOURCE: dvd player refuses to read any disc I load into the machine
Hello I was looking to try and help you with your DVD player, we will start by loading a music cd store purchased, no burned cds please, if the cd loads and plays then your dvd player is either out of adjustment or going bad, most dvd players, i have worked on, will load and play a music cd, but will show loading errors when trying DVD's. If the music cd dosen't load then there could be an issue with the drive or tray. If the music cd plays just fine, then your laser is either out of adjustment or going bad. You can call the manufacuter to see if there is a process for resetting the DVD player, not all DVD players have this option, if resetting the DVD player dosen't work, but music cd's do then your laser lens is dirty or going bad. At this point you have three options 1) Take it to a repair shop, 2) Get an new one, 3) Get your hands dirty if your really handy and know what your doing to clean and replace the laser. I hope I can be of further assitance and I look forward to helping in the future, Thank You and have a nice day.
Posted on Jan 14, 2009
SOURCE: Toshiba DVD SD-3980SU2 or SC2 player loads every disc as "bad disc"
Toshiba says:
Information for Owners of Toshiba SD-3980 and SD-K750 DVD Players spacer.gif To ensure the satisfaction of our customers and to maintain the integrity and quality of our products, Toshiba America Consumer Products, L.L.C. is issuing an important product update. This is not a safety issue.
Toshiba is committed to customer service and to continuously improving the quality of its products. It has come to our attention that certain DVD players bearing the model numbers SD-3980 and SD-K750 may at some point in their life stop playing discs due to a component part failure. In such case, the error message "bad" will be shown on the unit's display. Affected units will have "SU2" at the end of the model name (e.g., SD-3980-SU2), which can be found on the back of the unit.
If you own either of these models and experience the issue described above, please contact Toshiba Customer Solutions at 1-800-631-3811 for information on how to obtain a replacement unit.
Posted on Jan 18, 2009
  • 35 Answers
SOURCE: toshiba reads no disc
Dust infiltration is a likely culprit. Unplug the unit, open the case. Take a cotton swab and wet it with a small amount of glass cleaner. Gently wipe the laser lens several times without applying pressure, then use the other end to finish cleaning it off and to dry it. Often, so much dust gets inside these units and coats the objective lens it can't see the disc anymore. Give it a try, might work after this operation. I've fixed many CD & DVD players this way. If that doesn't work, take a can of compressed air and blow out dust from inside the laser by pointing the nozzle to the open space between the lens and the lens cover. Hold the can at least three inches away so as not to damage the internal workings of the laser assembly. Several short/sharp bursts of air might dislodge dust that has accumulated inside the laser housing.
Posted on Mar 05, 2009
When loading cd, it says bad
It's likely there is dust on the CD player lens. Many DVD units have two lens units, one for DVD's and the other for CD. You will to clean the CD one.
Mar 26, 2017 | Toshiba Televison & Video
DVD player won't play DVD, says "load"
The unit can recognize that a disc has been loaded but can not read the contents. This can be as simple as a dirty lens or more drastic like failing optics. Try cleaning the lens using a cotton swab and alcohol. If that fails to correct the problem and a music CD will play OK, then the optics are failing. DVDs require more laser power to read than a music CD.
Dan
Feb 04, 2009 | Toshiba SD-3990 DVD Player
Toshiba says:
Mar 29, 2008 | Toshiba SD-3980 DVD Player
Disc Error
Simple issue, the lead laser cannot read any data, for better result please try to check with the DVD shop.
Hope you like my solution please rate me solved.
Best regards,
Philip
Nov 17, 2007 | Toshiba SD-3980 DVD Player
Oct 29, 2007 | Toshiba SD-K860 DVD Player
Toshiba SD 4800 dvd player
I've had the same symptoms on the last two Sony DVD's that I've rented. I managed to get around this by hitting one of the menu buttons after the loading message stopped.
Aug 07, 2007 | Toshiba SD-4800 DVD Player
Toshiba disc error
Jun 25, 2007 | Philips DVP642 DVD Player
Toshiba SD-3980
If the disk is not dirty, smudged up or scratched -- it is likely the laser pickup getting weak or the spindle motor not keeping at the right speed. If you have to clean the disc, wipe from the center out with a clean soft cloth.
Jan 13, 2007 | Toshiba SD-3980 DVD Player
Televison & Video Logo
Top Televison & Video Experts
