Question about Emerson Quiet Kool 10GV13 Air Conditioner
Wall airconditioner It is a 220 volt & I would like to put a timer on it where I could set it to run maybe an hour only in the evening. I have looked everywhere & cannot find a timer that would work for that high a voltage
  • Emerson Master
  • 7,627 Answers
Trying to set my garden leisure spa on sleep so it circulates less. Currently it turn on every hour and runs for 7 minutes.My electric bill is out the roof.
there is a thing called a switch that you can activate to turn it off unless you are using it
That saves about 85% of the power bill
retime the timer to run at longer periods for less time or fit your own timer in the lead to the pump
Apr 20, 2017 | Leisure Pool & Spa
Dryer not making hot air
CONTACT A TECHNICIAN:
1. If you are not comfortable with electricity.
2. If you do not know how to use a volt/ohm meter
Beware, you can get electrocuted.
I found a simple wiring circuit on page 7 of https://www.appliancesonline.com.au/manuals/hdy60m/hdy60m_user_manual.pdf
  1. Dryer does not run: check the electrical outlet.
  2. Dryer runs, no heat: there are 4 parts to check: timer, thermostat, heater, and fuse. UNPLUG the dryer, set the timer to OFF, and use an ohm meter with a high OHM's selection to check continuity between the thermostat, heater and fuse. OK if it shows some resistance: then the timer is probably the problem. If OPEN, check each part individually, the ones showing some resistance are OK, the bad part is the one that is OPEN.
  3. Checking the timer, use a voltmeter set at range that measures the range appropriate for 220/240 Volt AC. This can be dangerous. Using the PDF as a guide, put one probe on "3", the other on "4" , when running you should see 220/240 range, if not, the timer is bad.
Jul 12, 2016 | Dryers
What is the intermatic e 1020 used for just moved into a house andits in the bathroom and makes a lot of noise.
The E1020 timer is reliable heavy-duty 24-hour on-off analog timer with replaceable trippers and manual override, rated 12 amps.
This timer replaces ordinary single-pole on-off switch.
Timer has extra white wire that connects to white neutral wires inside box to run timer mechanism, while mechanical single-pole switch does not need this wire.
I don't know what it is doing... maybe running the vent fan periodically, or turning on attic vent fan?
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#E1020
http://waterheatertimer.org/How-to-set-timers.html
For same timer, with less noise, install E1100-1200 aka the KM series in-wall analog timer. Or install digital in-wall timer, or replace timer with on-off switch.
Aug 11, 2012 | Intermatic Timer E1020, Single pole/single...
Can we wire with 220 single phase
It should be all set for 220 volts, a 3 phase timer would be twice that size if they make one. Little things don't run on 3 phase power. Are you just running the lights with it? If so, you don't even need the 220, just one side of it will do, make sure you have a wire to the clock motor, should already be there, check it out, Hope this helps.
Aug 28, 2010 | Intermatic & Indoor/Outdoor Rain Tight...
I would like to put a danby on an electrical timer so I can dehumidify my camp trailer 2hrs a day. It has a soft start though. Is there a way to do it?
If it plugs into a wall outlet of 120 volts then all you have to do is go to a hardware store and buy a timer that you plug into a wall outlet and program it for two hours a day and then plug the danby into the timer. But make sure the timer will carry the amp load of the danby, for instance wall outlets are usually 15 amp, so the danby amp rating should be 10 amp or less and you don't want anything else on that circuit.
Nov 24, 2009 | Heating & Cooling
My intermatic timer won't trip back on
I don't think the timer runs on 240 volts does it? You can switch 240, but the timer uses 120 volts to run. You might check the connections and timer clock rating more closely. Also, the 'off' & 'on' trippers are different, make sure you use the right one.
Jun 26, 2009 | Intermatic & Indoor/Outdoor Rain Tight...
COOK TOP WIRING
 You have Red and Black HOT wires and a Green Neutral - That is 220 volts. From the wall - Black is Normally HOT and White is Neutral. That is 110 volts. If that is a typical household outlet, is will only supply a demand at about 15 amps while running at 110 volts. Your Cooktop will most likely demand somewhere around 50 amps at 220 volts. - Short Answer - You will need to have a 220 volt supply line ran to the cooktop from the breaker. Easy to do but dangerous if you are unfamiliar with high voltage.
Apr 30, 2008 | Jenn-Air JED8430 Electric Cooktop
Appliance rewiring wiring WIRLPOOL ULTIMATE CARE II
The Whirlpool Ultimate Care II cannot be outfitted for a standard 115 VAC wall outlet. Your dryer is a 220 VAC appliance. It needs to have it own dedicated 30 amp, 220 VAC circuit with the proper outlet and power cord installed. The dryer heating circuits and timer will not run on 115 VAC. I think you need to reconsider what you are about to do...
Jan 23, 2008 | Dryers
Wiring a stove
If there is no 220 outlet in the location where you're planning to put the stove then you need to run wiring to the new location. There are two seperate phases of 110 volts coming to your home. The voltage between each of these phases and the neutral wire is 110 volts. When your house was wired only 1 of the 110 volt signals was run to your 110 volt outlets. In order to create a 220 volt outlet you need both of the 110 volt signals run to the outlet.
If you have a straight shot between your breaker box and the location where you need the 220 volt outlet then this is not too big a deal. If you have finished ceilings and walls inbetween then this will be much more difficult.
If you're not comfortable with electrical wiring this would be a good time to call a licensed electrician.
Nov 18, 2007 | Ovens
Emerson Quiet Kool 10GV13 Air Conditioner Logo
96 people viewed this question
Top Emerson Heating & Cooling Experts
Dan Webster
Dan Webster
jdthefixer
Tim Whalen
Are you an Emerson Heating and Cooling Expert? Answer questions, earn points and help others
