Question about Plumbing
Open water tank
Handle of tank very hard to open frightened of breaking it
    Master:
  • 563 Answers
Couple things you can try to help free it up. A nice strike with a hammer can cause vibrations to help break it loose or you could try applying heat, I usually use a mep torch. The heat lets metal expand slightly which helps to break up any buildup. Best trick is to not give it constant pressure, rather sharp taps. It it feels like your about to break it, you're probably right.
Posted on May 10, 2013
We have an ft900 with error code E516 can we reset to get unit going?
Operation and Care of FT900 SERIES DISHWASHERS SAVE THESE INSTRUCTIONS OPERATION MACHINE PREPARATION - Check before beginning operation. Open the machine doors and make sure all components are in their proper operating positions Pump Intake Screens must be put on holders at each pump intake (Fig.1). Fig. 1 Strainer Pans must be in place on top of each tank (Fig. 2). Fig. 2 End Caps must be correctly installed at ends of all Wash Arms (Fig. 4). Fig. 4 Wash Arms must be properly installed and latched in place (Fig. 5). Fig. 5 The Final Rinse Arm (and Dual Rinse Arm when present) must be properly installed (Fig. 7). Fig. 7 Curtains and drainback pans must be in their proper places, refer to pages 11 - 14. Strainer Baskets must be in place in Strainer Pans (Fig.3). ANK FILLING Assure proper water hardness. Recommended water hardness is 3 grains or less per gallon. Higher hardness may cause excessive formation of lime scale. Chlorides must not exceed 50 ppm. All water (and steam, if equipped) supply valves must be opened and the electric supply turned on before the machine will function. Close all drains and doors. The drain handles are located near the floor at the front of each tank. Rotate drain handles clockwise to the vertical position. The prewash tank,
Sep 29, 2016 | Dishwashers
Why wont my old grill work with new propane tank
Turn off propane. Disconnect propane tank from barbecue. Open burner valves for about 20 seconds. Close valves. Reattach propane tank. Slowly open propane tank valve. Turn on burner and ignite
Jul 13, 2014 | Weber Q Grill
How do i disassemble my hoover f7220
Hi there! The tanks, brushes, nozzle and handle can be removed from the cleaner by following these quick steps below.
1. To remove the clean water tank simply grasp the handle and push down on handle to unlock it, then pull the tank out by the handle.
2. To remove the dirty water tank, slide the latches open located on the sides of the cleaner that hold the tank to the base of the cleaner. Grasp the handle and pull up and off.
3. For brush removal, with the handle in the upright position, tilt cleaner back until handle rests on floor. Grab brush assembly and pull firmly.
4. To remove the nozzle, with handle in upright position, tilt cleaner back until handle rests on floor. Pull tab at rear edge of nozzle and pull forward to remove nozzle.
5. For handle removal simply remove the handle screw and lift up on handle.
Disassembly beyond this point is not recommended. Hope this helps!
Jun 05, 2014 | Hoover F7425-900 SteamVac V2 Widepath...
I have a hoover 5835-900 and it is leaking solution everywhere
You'll have to find out where it's leaking! Its not real hard. I will help you!
1. Fill the clean water tank. Check that the valve on this tank doesn't let water through when not on the machine. If it does this the tank is the problem.
2. Take off the 4-6 phillips screws holding the hood on to the machine. They will be on each corner underneath. Be Gentle! Do not break any of the plastic parts. Remove the hood.
3. Check where the clean water comes to a L valve. This valve is a very common problem. Place the water tank on the machine. DO NOT hold the handle down. Use paper towel to check for wet spots if you can't see where it is leaking. It should be fairly obvious.
4. If the water is coming from the "back" of the machine or the handle pry the cover off the inside of the handle revealing the hoses. The water release valves may be leaking. Be sure to check all hoses for cracks or breaks. Simply find the water.. and trace it back.
90% of the time it is the L valve which looks like this:
http://www.vacuummedic.com/product.php?id=231
Carefully put the machine back together not forgetting anything and test!
Good Luck!!
Aug 15, 2012 | Hoover F5835900 Upright Steam Vacuum
My Hoover max extract Spin scrub FH50220 is leakiing bad what can I do
Good Luck!!
Aug 10, 2012 | Hoover SteamVac Carpet/Upholstery Deep...
When hot tap is turned on there is a banking noise from boiler.Have had new pump fitted and have domestic hot water and central heating.Noise continues, but not as bad as before.When heating switches on...
try by draining tank. it may have sediment build up in it. heres how. go to www.ehow.com/how_5544402_drain-hot-water-tank.html this site will explain it better. have a good day! Sediment can drift into recirculation lines, jam open check valves, and cause the recirc pump to stick until it burns out. it causes noise, sometimes enough noise to annoy, or even frighten, people if the tank is inside a dwelling. The noise is caused by small amounts of water under the sediment layer turning to steam bubbles, which then collapse violently.
Feb 18, 2011 | Water Heaters
Water is coming from bottom when useing the hose.
Good Luck!!
Vac Dr.
Jan 12, 2011 | Hoover F6020-900 SteamVac Upright Vacuum
How do you get the water tank out to fill on the bissell pro-heat
release the handle until it sits all the way flat. At the top of the water tank there is a folded down gray handle, lift that up and then pull up on the handle and it should come straight up. Then you need to push that gray handle all the way forward so that the lid will pull up, and you then pour the clean water into the small round opening in the top of the open tank.
Jun 29, 2009 | Bissell 1699 ProHeat Clear View Upright...
Water drains out the bottom of cleaner as soon as tank is attached.
You don't say where the water is leaking from i.e. the back or the front. It likely is coming from the back. There is a connection to the "seat" that the tank sits in. There is a small hose that delivers the solution from the tank to the pump in the machine and I have seen them break off at the valve under the handle. If this is the case, the valve will have to be replaced.
Feb 10, 2008 | Hoover F6212-900 / F6215-900 SteamVac...
Plugged water line?
The trigger in the handle is clipped into two plastic snaps. When the trigger is pressed, the trigger pivots in these snaps and the pressure is transmitted through a rod connected to the trigger down to a valve located under the water tank. If the machine has been carried by the top handle insead of the carry handle that is incorporated into the water tank, the extra stress on the trigger will break off the snaps and the trigger will not function properly. Take the water tank off the machine and press the trigger. Observe the valve below the tank support and see if the rod is pressing down on it.
You might also check the hoses that come down the handle where they turn at the bottom of the tank. Sometimes they kink there and this will restrict water flow.
If you have been using the wrong shampoo, that is shampoo not designed for hot water extractors, it is possible for it to congeal in the lines and plug them.
Jan 27, 2008 | Hoover F5807 SteamVac Wet/Dry Vacuum
Plumbing Logo
273 people viewed this question
Top Plumbing Experts
Paul Carew
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
