Cannon all in one printer
No power light. One day OK next switched on and no response. Lead and fuse in plug checked OK. Any idea what I could do. Nobody seems to want to try and repair printers.
  • 32,281 Answers
The reason why no one wants to repair inkjet printers is they are cheap and it is cheaper to buy a new one.
Posted on May 11, 2013
  • 208 Answers
SOURCE: ac power
There are a couple of fuses in that power supply. But if it is a 412 or an F12 most likely you have developed cracks in the solder connections of that particular LVPS.
I would recommend replacing the LVPS.
Roughly a 250 dollar price on that power supply.
Posted on Dec 03, 2007
Inky
  • 691 Answers
SOURCE: printer dfx8500
The DFX-8500 uses a series of beeps to identify errors and error 6 relates to carriage load measurement. This error causes an auto power off after 12 seconds.
Parts that can effect this error are:
PW Sensor - defective
CR Motor - Defective
CR Encoder sensor - defective
Hope this helps
Posted on Jul 16, 2008
efs_perpends
  • 1996 Answers
SOURCE: Cannon printer quit working suddenly.
Is it possible that the cord came unplugged from the transformer itself instead of the printer or wall plug?
A power outage shouldn't affect it, but a power surge can. Please use surge protection circuits on your computer equipment. It's so much cheaper than repairing or replacing them.
Take it from someone who learned the hard way....
You can try a printer reset. Turn the printer off, unplug the power and data cables from the machine. Wait at least ten minutes to allow the printer cache to be purged.(Canon's recommendation)
Then plug back in and turn on.
I hope this works for you! Good luck!
Posted on Apr 10, 2009
e-ware
  • 776 Answers
SOURCE: Do I need a new print head?
5 flashes indicates a faulty printhead or possibly a problem with the p/head contacts. Try removing the head which is easier if you take the cartridges out first(no tools required) and re-seat it having checked the contacts for dirt.
If that doesn't work it may be that the waste ink tank is full. Try this ...
Canon S9000, S300, S400, i550, i560, i850, i860, i865, i9100, i9950, PIXMA iP3000 above,
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal.
Posted on Sep 13, 2009
guide2u
  • 461 Answers
SOURCE: Just wont switch on - I checked the fuse in the
Try to use different cable. you may want to check below link for any other Canon MP830 issue
http://pc-and-peripheral.blogspot.com/
Posted on Oct 19, 2009
Cannon ip4200 no power nothing is there fuse internally ?
there should be a fuse in the power board . but with another shape. maybe is a small black cilynder.
Apr 19, 2016 | Cannon Office Equipment & Supplies
PIXMA MG5350 WILL NOT POWER UP. HAVE CHECKED THE PLUG FUSE.
Unfortunately, I believe the printer will need to be replaced.
If you have verified the power outlet is good, there are not many options. No reset for 'No power'.
Nov 30, 2013 | Office Equipment & Supplies
Wharfedale LCD2710HDAF no power to tv, checked cable and changed fuse a few times, new power lead? or is this a common problem?
Hi.
The power cord must be checked using a multimeter. The test is done reading impedance (ohms) between plug's prongs and contacts to TV power board.
If the power cord is OK and there is no power, then the problem is the power board inside the TV.
Regards.
Ginko.
Dec 04, 2011 | Televison & Video
Canon i865 printer will not turn on plug ok lead ok no power to on light
If your are sure that you have power at the end of the connector that plugs into you printer and the printer's power switch will not turn the printer on then you either have a bad power switch or other power problem inside the printer - you will have to take the printer to a PC technician to have it repaired.
If there is is no power at the end of the connector that plugs into your printer then you have to replace your power cord.
If you believe that this information was helpful to you please return to the FixYa website and rate this response to your question.
Regards,
Yavacotech
Dec 07, 2010 | Canon i865
Greetings, I have a Cannon MP830 all in one printer . . . yesterday I set it to make two copies--I was low on ink, but as I always let it run until it is empty before replacing the ink, I hit OK to by-pass...
Double check to make sure all the cables are securely plugged in. There is also probably a switch in the back of the printer, usually by where you plug in the power, that you might want to check. otherwise, unplug it and plug it into another outlet just to make sure the outlet on the power strip isn't bad. You may also want to try completely unplugging it from both the wall and computer, and then just plugging the power back and then the computer if that helps.
Good luck, let me know if it still doesn't work,
Dec 29, 2009 | Canon MP830 All-In-One Printer
Printer won't turn on...is plugged in and has been printing well.
hi, have you tried checking, changing the fuse in the plug.
check the lead is fitted correct.
as for the fuse is the printer running of mains lead or just of the usb lead let me know, if its mains the unplug the lead that goes to your comp and then try it with just the power lead plugged in to see if that makes the differance.
Check the mains lead works try it on something else if you can if its running off only the usb lead then the lead may be at fault.
Let me know then i can assist you further ok
Nov 06, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
I have changed my fuse but still have no green light on my printer
ALL LIGHTS ARE OFF -
PRESS THE POWER BUTTON TO MAKE SURE THE PRINTER IS ON
TURN OFF THE PRINTER AND MAKE SURE THE POWER CORD IS SECURELY PLUGGED IN
MAKE SURE YOUR OUTLET WORKS AND AS NOT FUSED OR IS NOT CONTROLLED BY A WALL SWITCH OR TIMER.
TRY PLUGGING THE POWER LEAD INTO ANOTHER SOCKET
YOU COULD HAVE A FAULTY LEAD
Nov 03, 2009 | Epson Stylus R265 InkJet Photo Printer
Printer will not power on
check to make sure the power cord is plugged in all the way in the back of the unit as well as to the wall. Try all the obvious things first. change wall out let you have it plugged into etc. Good luck
Jan 30, 2008 | Canon PIXMA MP750 All-In-One InkJet...
No Indication...Dead Unit?
Firstly, try plugging the unit into another mains socket just to make sure it's not the socket that's faulty, or try another appliance in the socket you are using. Next, make sure the fuse in the plug hasn't blown. If you don't have a fuse tester, you can try the fuse in another similar appliance to see if it works. If it has blown and your spare lead is the same, there will be an internal problem. Inside the unit is an in-line 2 amp fuse. If this has blown you almost certainly have a power board problem. Always switch the mains off before plugging in or removing the mains lead from the rear of the unit. Back EMF can damage the appliance if you don't do this.
Dec 26, 2007 | Panasonic DMR-E55 DVD Recorder
No power lights
ok " could be a internal fuse, or bad transformer
Id check for a fuse first
Nov 16, 2007 | Hitachi Performa CP-RS55 Multimedia...
k24674
jasbo
jasbo
