Question about Water Heaters
My 100 gallon cyclone water heater is flashing 11 and says combustion air failure. Can I make a quick and temporary fix until I can get a tech to come out and look at it.
  • Water Heaters Master
  • 5,245 Answers
AO Smith posts service manuals, including cyclone models:
www.hotwater.com/Resources/Product-Literature/Service-Handbooks
Another resource: Post question on Tank forum:
http://www.thetankatwaterheaterrescue.com/forums/forum3/
Add comment and say what you discover
Posted on May 11, 2013
  • 2976 Answers
SOURCE: ECO failure. Replaced the gas control thermostat & vapor sensor
It sounds like your gas/air mixture needs to be adjusted. The flame should have just the slightest amount of white, at the very tip. The rest should be evenly blue. There is an air vent adjustment in the line to the burner, right after the gas input.
Posted on Sep 03, 2009
SOURCE: My Paloma tankless water heater flashes C2 11 error code
I just had the same problem and I fixed it in about an hour or 2. First shut off the gas,water and power(unplug it) Take off the cover There are about 20 screws above the electrical circuit board. You have to remove all of those screws to remove plate that is covering the burner assembly. The burner assembly has these 3 pins that look like number 7's these are covered with build up and gas can't flow right. That's why you get the c211 error not enough gas. Take a wire brush and gently remove any build up, I also cleaned the thermocoupler which is next to the burners. It looks like a metal pin with a couple of wires coming out of it this was also very dirty. I took a can of air and basically freshened it up It works perfect now. Email me with any Q's at Mario@myredr.com Good Luck All that you need is a long phillips screw drive and a drill because its about 25 screws
The burner assembly has 2 screws all the in back underneath the assembly once you remove those 2 the assembly comes out . You don't have to disconnect any wires.
Posted on Oct 29, 2009
  • 102 Answers
SOURCE: RHEEM 40 Gallon FVR NATGAS Low WATER HEATER 6YR 22V40SF: water leaking from top of water heater how can i f...
If water is leaking from a pipe. then replace or repair the pipe or fitting. If the leak is coming from the unit itself, then replace the unit. Hope this helps.
Posted on May 20, 2010
packrat1948
  • 528 Answers
SOURCE: RHEEM 50 GALLON WATER HEATER,4
That is a power vent failure code.
Rheem is aware of this problem and are changing systems as we speak. Call your Rheem dealer and demand the updated system.
Posted on Feb 07, 2011
SOURCE: where is anode rod located on 100 Gallon rheem
Anode rods for tank-type water heaters are located on top of tank.
This is true since anodes are about 44" long.
Top of anode is standard 1-1/16" hex nut.
Anodes can be located in 2 different places: either directly screwed into top of tank -or- attached to hot water nipple.
Most times the exploded parts diagram in manual simply shows 'anode rod' without specifing exact location. If your tank has long warranty, then it can have two anode rods, and 1 will be on top and the other probably attached to hot water nipple, or there could be two anodes screwed into top of tank.
http://waterheatertimer.org/Replace-anode-rod.html
If anode is screwed into top of tank, then it will be under a plastic cap -or- it will be concealed under the top cover of tank.
Look for plastic cap, and if none shows, then remove screws holding down metal cover and look there for 1-1/16" hex nut.
Lastly, remove hot water nipple and check for anode located there.
If you have 2 anode rods, then replace with same metal for each.
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on Mar 22, 2011
Do you have to have combustible air vented in for a 40 gallon power vent water heater
Let's hope the air supplied is not combustible but in answer to your question, codes applicable to a power vent water heater installation require an external air supply for improved efficiency. Just had the experience and the final cost was ten times that of installation without the noisy power vent.
Jun 27, 2016 | Water Water Heaters
On A.O. Smith water heater model BTH 199 100 where is the heat sensor rod located ?
Parts list:
http://www.hotwater.com/lit/partslists/197728-004.pdf
Flame rod, flame sensor sits next to igniter inside combustion chamber. This can be cleaned with sandpaper. Do not touch with fingers. Purpose of flame rod is to detect whether ignition has caused actual, sustainable fire inside the combustion chamber.
If sensor is bad, or no ignition is detected after 2-3 attempts, then 'no ignition' error is given.
Bad gas control valve, bad-or-dirty flame rod-sensor, low gas pressure, misaligned rod, dirty combustion parts, etc
Service handbook:
http://www.hotwater.com/lit/training/316586.pdf
High gas pressure spikes can daMAGE gas control valve p7
Product manual:
http://www.hotwater.com/lit/im/com_gas/197727.pdf
Word-search for 'failure'
Low gas pressure. p14 and p54
1-3 trials before declaring 'ignition failure. p48
bad flame sensor (clean with sandpaper) #10 p58
unit must be grounded (check outlet with circuit analyzer) #12 p58
Sequence flow chart p59
Rough starts = ignition failure p60
Troubleshoot chart - ignition failure p62
Mar 12, 2013 | A.O. Smith BTH-199 BTH-199 100 Gallon...
Hot water heater womt light, flammable vapor sensor code
Most likely: Combustion chamber got too hot because air intake is clogged with dust, causing less air to flow upward through vent pipe ... the slowed flow of air caused combustion chamber to overheat.
What brand and model water heater?
Look at label on side of unit and add comment.
Otherwise call service tech to repair/ replace water heater and clean arrestor screen (air intake) and replace or reset parts as needed, depending on model number and brand water heater.
AO Smith, Bradford white, and Rheem are main manufacturers.
Each has slightly different repair protocol, and each gas control valve can also be different. So more information is needed.
Identify gas control valve:
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
Rheem TRD/ FVIR glass vial
http://waterheatertimer.org/How-to-repair-Rheem-FVIR.html
How to remove combustion parts to inspect for Rheem glass vial and clean arrestor screen located under combustion chamber:
http://waterheatertimer.org/How-to-replace-thermocouple.html
Sep 30, 2012 | Audiovox Richmond 6G40-36F 6-Year Tall Gas...
Problem keeping my Rheem hot water heater light
What brand, model, and approximately how old is water heater?
This is important because water heater designs are changing quickly.
Did you remove door over combustion chamber to access thermocouple?
Newer Rheem water heaters have air intake under combustion chamber that has to be blown out using compressed air.
If this is different brand, then use mirror under water heater to see air intake.
Set water heater on bricks to avoid high water. Make sure drain line out of drip pan is 3/4" and terminates in good drainage location.
Put brass garden hose cap over drain valve.
http://waterheatertimer.org/How-to-replace-water-heater-drain-valve.html
Aug 29, 2012 | Rheem RHG Pro40-40F Pro Series Natural Gas...
Rheem tankless water heater error code 11
Error 11 is ignition failure, or insufficient gas, or defective sensor, dirty combustion parts.
Do the yearly required maintenance such as cleaning the combustion parts, and error code will probably be solved.
Problem is Rheem does not post service manuals for people to learn how to service their equipment without calling service tech.
Copy following link for Rheem troubleshoot resources
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
The cost of yearly maintenance will easily eat away the expected yearly savings of $100 for typical family of 4.
Aug 20, 2012 | Rheem RTG-66DVN Direct Vent Natural Gas
Rheem water heater 42vp40sf and the fvd interface failure code is flashing. how do i fix this?
Call Rheem
1-800-432-8373
TRD is flammable vapor system. Typically there is a glass bulb or fuse located in the combustion chamber.
See example image:
http://waterheatertimer.org/images/FV-TRD-glass-fuse-300.jpg
Remove the burner and look for the evidence of broken glass bulb that holds the air intake open.
Air intake is located bottom of combustion chamber, and bulb breaks causing metal plate to snap upwards and close off air supply to combustion chamber.
Rheem will have exact part number and possible instructions. Other people have wedged the air intake open to get system working again, but I do not know if that will work with your model water heater with electronic control. Working around the FV system exposes home and people to flammable vapor ignition and explosion when water heater is exposed to flammable vapors.
Example manual with illustrations.
http://waterheatertimer.org/pdf/Test-if-thermal-release-device-needs-replacement.pdf
Clean burner and pilot orifice and combustion chamber while burner parts are removed. Also clean air intake.
When burner is removed for cleaning, the access door gasket might need to be replaced.
Your product manual and/or Rheem will have that part number.
Sep 23, 2011 | Audiovox Richmond 6G40-36F 6-Year Tall Gas...
I have a paloma tankless water heater ptg-74pvn-2 that gives me the error code c2 11. looks like everybody has a problem with this. what can i do to fix it, surely enough they should have some easy way of...
Easy solutions for C2 11:
Rheem is one of the big manufacturers but has disproportionate number of questions at fixya since they try to funnel problems through service techs instead of posting do-it-yourself service bulletins. People want do-it-yourself service bulletins, as appear on the Bosch site for their products. Easy-fix in this sense would be to buy Bosch, and read service manuals aforehand to see if you have testing skills and equipment to maintain and repair tankless water heater.
Easy solution for C2 11 Rheem problem is don't install gas tankless water heater, since all costs are energy and tankless are expensive to install, maintain, repair, and replace for the mere savings of 1-8 per month.
Third solution for C2 11 no-ignition is to clean burner and combustion parts, and sand carbon off the igniter, on a yearly basis, as recommended in manual.
Fourth solution is to call a qualified service technician each year as recommended in manual, and have technician fix problem and catch water heater up on recommended service. This person can check other causes for C2 11 such as bad igniter, bad gas solenoid, low gas pressure, air in gas line, improper unit grounding, bad wiring, bad sensors, etc.
This check-up can also make sure vent drain is working properly and that acidic water vapor and other resulting combustion by-product are going into the household drain and eventually out to sea instead of dripping down into the heat exchanger causing rust and premature failure of exchanger.
Next solution will not solve C2 11 error code, but can address other error codes before they happen: Maintain water heater on yearly and monthly basis as recommended in manual. This is good for folks who like projects.
http://waterheatertimer.org/pdf/Tankless-maintenance.pdf
More resources:
1-800-432-8373
http://waterheatertimer.org/How-to-install-gas-water-heater.html
Sep 20, 2011 | Rheem Paloma PTG-74PVN / RTG-74PVN...
I have a Nortitz natural gas water heater, model #N-063s-1. Acouple of days ago it stopped heating the water. what can I do myself to fix this matter. Thanks, lynnatheana@hotmail.com
There are many reasons a tankless heater will stop heating water. The first thing I would look for is a flashing red light on the burner indicator. The flash break down goes as follows
continuous blinking - typically means ignition failure or the unit is overheating; look for visible water inside the unit, have your gas pressure checked, or check the flame rod/igniter for buildup of debris
three blinks - typically indicates 16 error code; typically resolved by performing a descale
4 or 5 blinks - exotic error codes; for these you should definitely contact Noritz tech support
If there is no flashing light, first check your filter for debris. If the filter is clean, your flow sensor is probably stuck. Again I'd recommend contacting Noritz tech support to help you clean the flow sensor.
Jul 31, 2010 | Noritz 6.3 Gallon Residential Tankless...
Rheem Power Vent 2 water heater is flashing 4 times and there is no hot water. Model # 41VRP50NT What can I do to fix this? Do I need to call a plumber?
The flashing light is a trouble sequence light. Find your manual to see what 4 flashes means. It's usually attached to the side of the water heater tank. Try a quick fix by unplugging the power vent and see what happens.
May 15, 2010 | Rheem 50 Gallon FVR NATGAS Water Heater...
Sometimes the hot water just goes cold
Here are a couple things to look for:
1) flashing burner light - a flashing burner light indicates the unit is getting an error code
common error codes:
A. continuous flashing - ignition failure or abnormal combustion; look for visible water in the machine indicating a leak, check gas pressure, debris or buildup on flame rod/igniter plug, or clean unit with compressed air
B. 3 flashes - error 16, abnormal outlet water temperature; typically this code indicates you'll need to descale you unit
C. 4 or 5 flashes - exotic error codes; you should contact Noritz technical support to deal with these codes
2. If there is no flashing code, try increasing the hot water flow. In the summer time you typically use less hot water; this can result in intermittent operation of your tankless heater. Increase water flow by either: A. cleaning your showerhead and removing scale deposits B. widening your flow restrictor C. Remove your flow restrictor in the showerhead
3.If none of these resolves your problem, you probably have debris in your flow sensor. Contact Noritz technical support for a walkthrough on removing debris from a flow sensor.
Feb 18, 2010 | Noritz 6.3 Gallon Residential Tankless...
Water Heaters Logo
55 people viewed this question
Top Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
