Question about Asko W6221 Front Load Washer
Repair manual blows house fuse when I try to start
When I turn it on the fuse box for the house keeps blowing
Have you tried a different area of the house? I would call an electrician and have your outlets checked.
Apr 06, 2015 | Bissell 9500 ProHeat 2X CleanShot Upright...
2001 Ford 350 7.3 diesel. Turns over but will not start. Wait to start light will not come on. Checked fuses under hood. Had the 20A pcm fuse was blown. Replaced fuse and tried again. Wait to start light...
i
Inside of the fuel filter housing is a heating element, a fuel warmer. It is common for this element to break the spot welds of it's mounting plate and ground out against the housing, hence it blowing the fuse every time you try and warm up the glow-plugs. Take the top off of the fuel filter housing and remove the filter, then look into the bottom of the housing and see if the heater is touching the walls of the housing. If this is the problem you should be able to unplug the fuel heater and have the engine start until you get the heater replaced.
Mar 02, 2014 | 2002 Ford F250 Super Duty SuperCab
My KB6524PK Sharp drawer microwave keeps blowing a fuse. I have replaced 3 now, so it's not the fuse. There is something else going on. Can it be the house electrical fuse box? Or sometimes the
It could all be down to the micro-switch on you door. If the switch is not opening or closing properly, making/breaking contact properly it could cause a short which blows a fuse. Try giving it a clean. if there's some goo on the contacts from use, it could cause the problems you describe.
Try and get direct contact with the switch to clean it, if you cant, try a spray of WD40 a de-greaser or similar.
Oct 01, 2012 | Refrigerators
I'm testing my daughter's dehumidifier that blows her fuses. In my house, it does not blow my circuit breakers but does trip my GFCI outlets. What do I need to do?
If you are blowing fuses and GFCI's your compressor is either not starting at all, is starting hard, or is at least grounding out momentarily...
at any rate the compressor is failing, and that is not economically replaceable..
heatman101
Sep 25, 2011 | Maytag M7DH65B2A Dehumidifier
My dryer keeps blowing fuses. What could be the problem?
could be a number of things,, is it the house fuse or the machine fuse? check this link out http://www.partselect.com/dryer+dryer-wont-start+repair.htm
Jun 10, 2011 | LG DLE2514 Electric Dryer
1. after 10 minutes of the engine starting, the
Try this website for resolving car problems by downloading a FREE service manual for your vehicle. This is not an owners manual but a factory mechcanic's manual.
http://ezinearticles.com/?Find-the-Free-Auto-Repair-Manual-You-Need-Online&id=92717
May 01, 2010 | 1995 Oldsmobile Aurora
White knight dryer wk767 (Crosslee) blows fuse when turned on
Probably a problem with the heater element (if mineral insulated metal sheath type), or fluff on wire heater coils if that kind. This is behind the back cover.
Feb 27, 2010 | Dryers
Dryer will not start
cd5c1d0.jpgThis fuse will blow IF their is a blockage of air flow. The restricted air will build quickly. The fuse is mounted on the blower housing on rear of dryer. NOTE: you will continue to replace these puppys a around 10 bucks a pop if you fail to clean the dryer.
OLD SCHOOL MANUAL
BONUS: repair photos
Jan 05, 2010 | KitchenAid KEYS750LQ Electric Dryer
Hi, When my GE jvm1650bb microwave starts, it begins to work and then blows the fuse in the house. Does this every time, the circut is not overloaded. Is their a part that went bad that I can replace?
Try your oven on another circuit in your house. It is curious that your oven doesn't blow its own fuse before the house one. If it doesn't blow the fuse in the "new" circuit, check to see what is really on the kitchen circuit. It might, in fact, be overloaded. Good luck.
Nov 28, 2009 | GE JVM1650 1000 Watts Microwave Oven
Henry hoover cuts out
A 5amp fuse will struggle on start up on anything over 1000watts. Check the rating plate on the appliance for total load
Aug 19, 2009 | Numatic Henry Bagged Canister Vacuum
Asko W6221 Front Load Washer Logo
103 people viewed this question
Top Asko Washing Machines Experts
Gerry Harvey
Gerry Harvey
Joseph Hoffmann
marley mcelhinney
Are you an Asko Washing Machine Expert? Answer questions, earn points and help others
