Question about Samsung PS42S5H 42 in. HD-Ready Plasma Television
Samsung ps42s5h hi, I have a tv that when i try to power on, just give me a sound when tv try to start but no switch on. And the tv continue trying to start but with no success. Do you know what could be the cause? Best Regards
    Top Expert:
  • Samsung Master
  • 74,136 Answers
There is some short circuit inside one or more circuit boards inside your TV. It need a thorough check up It is a skilled work. If you wish to get more details, surf the following link. There are over two thousand and four hundred posts. All are related to television and other domestic electronic equipment service help. You can get a solution there. Type in the brand name to your device to its search box, can be located at the top right of the display window.
Posted on May 11, 2013
tvtek
  • 1284 Answers
SOURCE: 32" Samsung TV, No Power or Sound, power LED on, flashes 3 times
Most likely the set has lost vertical sweep or the feedback from that circuit. This will shut the set down to prevent a horizontal line from burning the face of the CRT. This will have to be looked at by a technician.
Posted on Sep 11, 2009
  • 121 Answers
SOURCE: I am having problems with
Your problem is typical of Samsung LCD TVs. The capacitors on one of the internal boards are rated at 10V and should be higher. If you open the case, you'll see bulging capacitors. If you can handle a screwdriver and soldering iron, you can actually fix it yourself with a few capacitors from an electrical supply store. Simply read the specs off the bulging capacitors and get a higher voltage-rated replacement. For exmaple, if the capacitors say "1000uf 10V 105C", you would replace them with "1000uf 35V 105C" or similar rating. Or an easier method: Recently, Samsung themselves have been making repairs as it is such a widespread problem. Call Samsung at 1-800-726-7864 and they may just repair it for free, even if its not under warranty.
http://www.thebuzzmedia.com/samsung-tv-capacitor-clicking-issue-and-free-repair/
Posted on Feb 23, 2011
  • 156 Answers
SOURCE: hi, power supply is not working
Can't say this for sure, but if it's a power supply problem, take the TV apart and access the power supply (unplug it, of course). Look at all of the capacitors (the little round cans with 2 wires either coming out the bottom or one coming out on either end). If they appear to be bulging (you can tell a good one from a bad one very easily), they're most likely bad and many times replacing those will solve your power supply problem.
Posted on May 20, 2011
ladywinn
  • 5138 Answers
SOURCE: Hi my Samsung ps42s5h keeps
Look on the power supply board for bad capacitors they will be swollen or vented on Top.
1000uf 16v 2200uf 10v 3300uf 10v 330uf 10v
Posted on Jun 20, 2011
SD Tech
  • 14553 Answers
SOURCE: Hi, I switched off my Samsung TV last night as usual, and when I tried to switch it on this evening it wouldn't switch on.I tried unplugging it and turning it on, but the red power light on the b
I see so many here with no sound/no picture issues:
ISSUES:
1. IF sound main fuse/s are good.
2. If no power or standby check main fuse, standby power supply and any signs of damage you can see---burnt parts etc.
3. almost all these sets the troubleshooting involves checking voltages on the main power board to narrow down the problem.
4. Be safe and if you do not know what you are doing don't open the set.
Answers to issues:
1. RE:fuses---if a blown fuse is found get a good replacement(not the generic ones like Radio Shack). Many fuses are special even aside from amperage--Don't put a higher rated amperage fuse in the set for any reason.
2. RE: power supply in set: if total dead aside from main fuse the set uses a standby power supply that runs 7/24 and a main supply (some are combined and some not.
Here aside from checking fuses you want to examine all the filter caps on the power/standby to see if any are puffed up or buldged up in some fashion--I attach a photo of a good one---top should be silver metal and PERFECTLY flat and have no brown material coming out on top or bottom.
What happens in the standby area is they use caps with too low a voltage rating (saves money) which causes them to fail in a year or two---the standby runs 7/24 and the heat dries out the caps and they fail.
3. Trouble shooting consists of the above and then at some point you have to buy and try a board to see if it fixes it or not.
4. Safety first--no TV set is worth getting injured or even killed over. If set is opened at least look for puffed up and bad caps like in this photo. 11_6_2012_3_22_05_pm.jpg
Posted on Nov 06, 2012
Hi, i have a samsung ps42 s5 plasma. the screen has pink/red striped flickering across the screen. any suggestions?? thanks
You may have a small signal board that is bad. Speak to your local TV tech. I don't beleve you screen is bad...if the stripes you say are traveling. Hope this gives you a clue!
Mar 14, 2010 | Samsung PS42S5H 42 in. HD-Ready Plasma...
Our Ps42s5H TV regularly at 8PM at night looses picture on the top 1/2 of the screen only. The picture usually returns without any interferance but the set continues this behaviour for appro 1/2 hour and...
Hi
This is down to your Y Buffer upper board, Take the back off you tv and look to your left, you will see a main Y sustain board and then to the left of that 2 x thin long rectangular boards connected to your main Y baord and screen
These thin boards controll the picture top and bottom, get the number of the top thin board and replace it, of the top of my head it is .... LJ41-02760A look on Google or Ebay, these can be replaced cheaply at around £20-£25
I would stress to do this ASAP as it might take your main Y Sustain board out and these are expensive to replace!!.
This should 98% of the time cure your problem.
Hope this helps
Mar 12, 2010 | Samsung PS42S5H 42 in. HD-Ready Plasma...
Samsung 40" tv not coming on
I would check out the power supply module for bad caps with bulging tops. Check DC voltages at the output connectors, you should have 5, 12, 24V.
Jan 08, 2010 | Samsung LE40R74BDX 40 in. LCD Television
Samsung HD 42inch TV Model No. PS42S5H Y Board
Your board numbers should start with LJ92. They will cross to both Samsung and LG. Oh, your model number goes nowhere, double check it.
Aug 25, 2009 | Televison & Video
Cant get ps3 to work without being black and white
Make sure it`s switched to CBVS, You`ll probably find that the TV is switched to RGB or S Video or SVHS. Try scarts as well as the phono`s. Ian
Aug 04, 2009 | Samsung PS42S5H 42 in. HD-Ready Plasma...
Fault with Samsung PS42S5H
sounds like the lower y-sus buffer! take off the back and give me the pcb number should start with Lj92
Nov 03, 2008 | Samsung PS42S5H 42 in. HD-Ready Plasma...
Samsung ps42s5h
IF YOU ONLY CHANGED THE BUFFER, YOU SHOULD CHANGE THE Y-MAIN ALSO, THAT BUFFER TAKES OUT THE Y-MAIN AND VISA-VERSA
Sep 05, 2008 | Samsung PS42S5H 42 in. HD-Ready Plasma...
Screen or what???
hi i just spoke to samsung because mine has got a similar problem and was told it could be the screen or the motherboard if its the screen it will cost around £400 to repair motherboard is less but could not give me a price
Nov 16, 2007 | Samsung PS42S5H 42 in. HD-Ready Plasma...
Samsung PS42S5H 42 in. HD-Ready Plasma Television Logo
46 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
