Question about Brother MFC Office Equipment & Supplies
How to Reset Brother MFC-9120 fuser & maintenance kits
How do you reset the fuser unit & PFKit to 100% on Brother mfc-9120 without replacing them?
  • 1056 Answers
SOURCE: Replacing Brother MFC-8440 Fuser
To remove the fuser - remove the tray at the bottom and the back tray (4 screws, 2 either side) lift out the phone line box on the right (looking from the back - 2 screws) and swing it out of the way (careful as cable isn't too long) 2 screws either side of the fuser (long black object at the bottom) unplug the halogen lamp (white plug on left) and small 5 wire plug on right, and lift out fuser unit.
Posted on Aug 28, 2008
SOURCE: Fuser replacement on Brother MFC 8860DN
Yes I did it myself, however I am savvy with most hardware, I wouldnt suggest it for the novice. It cost around $NZ245 for the fusing unit, which from doing a quick search online is about the same in most countries.
Posted on Sep 03, 2008
  • 32 Answers
SOURCE: Need to reset the counter
First, you enter the config menu by powering off the printer. Hold the middle and right arrow buttons and turn the printer back one. Continue to hold until you see Performing self test. Then release. You will then see config menu. Scroll down to reset maintenance count and press select. It will reset and bring you back. Then restart the printer.
Posted on Jul 24, 2009
  • 59 Answers
SOURCE: Problem for Brother MFC-8860DN Printer How do i
press menu 7 3 2. this will bring you into the parts reset, and reset the fuser
Posted on Mar 31, 2010
SOURCE: dr-360 mfc drum reset
Brother MFC-7345n. DR-360 With power on and door open hold down the Clear/Back button. When asked new drum 1 for yes and 2 for no. Press 1 for yes to reset drum life
Posted on May 28, 2010
I replaced the fuser. How do I reset the fuser?
Replace Fuser Message and Reset Brother MFC 8480DN ...
? 0:46
www.youtube.com/watch?v=quGzXnDsZQA
Jun 27, 2012 - Uploaded by Kevin Gumpp Instructions on how to reset and replace the fuser on a BrotherMFC 8480 ... V?deo Recarga Toner Brother TN 580 ' MFC 8860DN ' DCP 8060 ...
Oct 01, 2015 | Brother Printer MFC L8850CDW Wireless...
Brother 8480dn displays "REPLACE PARTS. What does this mean
There are periodical parts to be replaced - eg. laser, fuser & PF Kits. You can check from your display which is due. You can also reset the counter to continue using if printer/printout is normal by going to maintenance mode & 8, 8 , choose which counter to reset.
Feb 18, 2015 | Brother MFC-8480DN All-In-One Laser...
Reset a brother MFC 7460DN after replacing the fuser unit?
You need to press Menu-Mono Start-Up Arrow 4 times in less than 2 Seconds !!! and you will be in Maintenance mode. LEDs will be flashing. Press 88 then use the arrows to select Fuser and press ok. Then press 99
Oct 25, 2014 | Brother MFC 7460DN - Multifunction fax /...
Reset counter 8950
Press 3 & 9 together, select and reset.
Sep 26, 2014 | Brother MFC 8950DW
Error code 78
Usually a result of a sudden power outage. Majority of the time it can be reset without replacement of the fuser. Here is an article I wrote explaining the cause and how to reset the message.
http://www.fortwayneprinterrepair.com/wordpress/2011/09/28/brother-fax-mfc-76777879-fuser-errors/
Dec 06, 2010 | Brother MFC 8300 Laser Printer
Need to clear the error code "replace Fuser" Fuser is new and so is the paper tray cannot seem to get the darned thing to clear
Put the MFC into Maintenance Mode
Press the Menu and Start Keys at the same time then press the up arrow key 4 times the machine should display "Maintenance " in the LCD display
Press the 8 key twice, Display should show Part Replacement
Press up or down keys to select "Reset Fuser" press OK or Start Key to reset the counter of the fuser
To Exit Maintenance Mode press the 9 Key twice
I hope this helps.
Aug 20, 2009 | Brother MFC-8460N All-In-One Printer
Replace Fuser error will not go away
With in 2 seconds you have to hit Menu,*,2,8,6,4
Continue even though you hear the 3 beeps.
When it does into maint mode press 88
That is parts counter reset
Scroll to the part and hit ok.
Press 99 to exit Maint mode
Dec 14, 2008 | Brother MFC-8870dw Wireless Multifunction...
Aug 25, 2008 | Brother MFC-8440 All-In-One Laser Printer
Resetting "Replace PF Kit 1" message
Same with me on my MFC 8870DW. The procedure worked perfectly:
1) Turn off printer
2) Press and hold menu button and turn on. Keep holding button until you see maintenance on display.
3) Press 88. This brings up parts replacement menu.
4) Press Up arrow until you see the part you replaced (laser, fuser, pf kit1, pf kit mp).
5) Press the OK button.
6) Power off and restart printer.
But how do I know whether or not I really NEED to replace a PF Kit1? I guess I'll find out if it recurs soon.
Joe
Jun 18, 2008 | Brother MFC-8460N Laser Printer
62 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
