Question about Nintendo Game Boy Color Console
Gameboy button The left arrow on the arrow pad doesn't work.
  • Nintendo Master
  • 424 Answers
I think that it is broken then.
Posted on Oct 07, 2016
Casio Exilim EX-P505 the left arrow key doesn't work. is it setting or broken? what should i do?
Most likely the arrow key switch is broken or the contacts are corroded. If it's a snap-button switch, it needs to be replaced. If this is bad, I recommend replacing the others also. If it's a conductive rubber button (like most TV remote controls), the conductive patch on the inside is worn and needs to be repainted with carbon/silver conductive paint. A miniature snap-button switch is generally less than a dollar from Mouser Electronics - soldering skills are required for replacement. Conductive paint for rubber button switches is $10.45 for a 1 gram tube. It has a very limited shelf life once it's opened, so use up the rest on the other camera buttons, and the power, channel and volume buttons on your favorite TV remote control (if you can get it apart without breaking the case)
Cameras are typically difficult to take apart for repair. You'll have to consider the value of the camera versus the effort to get to the control buttons. The electronics inside are sensitive to static electricity damage, so you should work on an anti-static mat and use an anti-static wristband with it..
Nov 14, 2017 | Casio Exilim Pro EX-P505 Digital Camera
How to open unlock mouse pad
Click the Windows "Start" button in the bottom-left corner of your desktop.
Scroll up and click "Control Panel."
Choose the "Mouse" icon or type "Mouse" in the field in the upper-right corner.
Click the "Enter" button and then click the "Mouse" link.
Press the "Hardware" tab or the tab to the right of it that specifies the type of touch pad you have.
If you are under the "Hardware" tab, highlight the touch pad in the list of devices and click the "Enable" button.
If you are under the touch pad tab, click the enable button.
Click the "Apply" button and then click the "OK" button
or
Locate the function key on your keyboard (F1 through F12) that has an icon of a touchpad. This is often a rectangle with two smaller rectangles below it, representing the touchpad and its two buttons.
Press and hold the "Fn" key, usually found in the lower left area of your keyboard.
Press the touchpad function key and then release both keys. If this does not enable your touchpad, try holding the "Fn" key down and pressing the touchpad function key twice in a row.
Shortcut Key Method
Press the Windows icon key on your keyboard and hold it down until the Start menu pops up. If your keyboard doesn't have a Windows icon, press "Ctrl-Esc" at the same time.
Use your arrow keys to locate the Control Panel and press "Enter."
Navigate to "Mouse" with your arrow keys and press "Enter" to open the mouse control dialog box.
Then, press "Alt-F" together to access the tabs at the top of this box.
Navigate using the arrow keys to "Device Settings" or "Touchpad" or the similar option on your system and press "Enter."
Press the "Tab" key until the "Enable" option or a check box next to it highlights and then press "Enter." Press "Tab" again until you are highlighting "OK," and press "Enter." Your touchpad will be re-enabled.
hope this helps
Sep 22, 2012 | Computers & Internet
Rotate screen back to horizotal
Try pressing Ctrl + Alt + UP Arrow Key, or try Ctrl + Alt + and a different Arrow Key.
If that does not work: Right-click on empty Desktop > Graphics Options > Rotation.
or
Press "Ctrl-Alt" and an arrow key (left, right, up or down) to rotate the screen.
Continue pressing the hotkeys and arrow keys until you reach the desired rotation. This works with most video drivers on Windows XP. If it doesn't,
Click "Start," then "Control Panel," then "Display," then the "Settings" tab. Click the "Advanced" button. Check for an "Orientation" option. Select your desired orientation.
hope this helps
Jul 25, 2012 | HP Pavilion tx1000z Notebook
I got a NES (finally) but i got a problem. when i start it up with (for example) zelda i can select a save, in other words when I push the up or the down button it does nothing. But when i press start to...
The reason it doesn't work in the menu is because it doesn't use the D-pad (the plus-shaped button that you use to move around). To go through the menu options, you need to press the Select button (that's the left of the two small buttons in the center of the controller). Many games use that to select menu options instead of the D-pad.
Jul 06, 2011 | Nintendo NES Console
Hi, my left clicker on my Sony Vaio stopped working. The right clicker works as well as the scroll pad but clicking on the scroll pad doesn't work as well. I have tried rebooting, installing the mouse...
More then likely the button has worn out.The first thing I would try to check to see if its the button or not ,just plug a mouse in to the laptop and see if that works with left click if it does it just may need a new button put in.If your handy you may even be able to do it yourself.If you have any other questions just let me know.
Jun 11, 2011 | Computers & Internet
On touch pad, the left and right click below the pad, for the mouse, the left button doesn't click anymore?
Since the left button is a primary button it gets used quite a lot thus the button fails at some point in time.
Either the button has broken or the spring mechanism has broken.
Don't worry it can be repaired, claim warranty support if you can. The laptop needs to be partially disassembled and the buttons inspected. The button may need replacing.
Take care!
damnor01
Jun 09, 2011 | HP G70-460US Notebook
Which is the enter button?
If it doesn't say "enter" then it's the button with the arrow that has a downward line and it then turns and points left.
May 18, 2011 | Acer Aspire One PC Notebook
My mousepad is working but the cursor between left and right button doesn't work? I have a ACER Aspire 9300
1) Go to control panel (either with the help of keyboard or mouse)
2) Open Mouse
3) On Button Tab Select Button Configuration ( Switch Primary and Secondary Buttons)
4) Also Check your Touch Pad Driver Software
Thanking you
May 16, 2011 | Acer Aspire 9300 Notebook
"how can i put a
Press Menu - If you see a Setup tab , press the right arrow button to highlight the Setup tab. - If you dont see a Setup tab, press down arrow button to select Setup, then press OK button. -If your camera doesn't have a Menu button, press the Review button then choose Settings.
Press the down arrow button to choose Date & Time the press OK button.
Press the Right/Left arrow buttons to move between year, month and date.
Press the Up/Down Arrow button to scroll through the year. month and date.Use the same procedure to set the Time.
When finished press OK button.
Hope this helps. Rate if it works. Thanks
May 04, 2011 | Cameras
Nintendo Game Boy Color Console Logo
71 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
