Question about Garmin GPSMAP 541s
Garmin 541s transucer, unit problems
The depth reading on the rear unit starts flashing, when you start to plain out. Rough water causes the same problem. Unit will also shut itself off. I have been dealing with this issue for several months. The dealer has tried everything, moving transducer, replacing unit etc.. Still the same issues, I do not like Garmin products for marine craft, and would not recommend to anyone. Glad mine was under warranty, got money back from dealer, got (2) Hummingbird 898si. Thanks BucksIsland Marine. Southside, AL
  • 35 Answers
Sound like the transducer is catching air.
Posted on Jul 13, 2013
What can i do to stop the flashing of the depth finder at times it will not show the current depth
Hey Joe,
Wow.. where to start.. there are so many things that will cause the issue you are describing.What type of electronics do you have? Does this happen at all speeds? Where is the transducer mounted? I need more info about when it stops reading.
1.Wrong setting on the unit
2 Bad transducer
3 Bad transducer mounting (either inside the hull or outside the hull.)
4. (In hull) Turbulence going under the boat (mine quits reading at about 55 mph @ half trim...the boat is lifting so much it causes air pockets so the transducer loses contact with the water)
5. (Outside hull) Turbulence around the bottom of the boat where the transducer meets the water.
Good luck,, when you get the info.. reply to me..
Jun 03, 2017 | Boating
My two year old Garmin 95 depthfinder has worked great until a month ago when the depth read-out started rolling over rapidily and continuously between 18ft and 32 ft. In adition, the water themperat
Hi Tom!
I believe I'd start troubleshooting with the power supply. Disconnect and clean the cable ends with Fluid Film (I swear by this stuff) Check the crimps and make sure they're not loose. Pay special attention to the ground connection.
With your temp not reading correctly in addition to your depth rolling, this usually indicates a common fault. (Usually ground.)
Check the data cable and socket on the control head for corrosion (again, Fluid Film is your friend) If that doesn't fix your problem, then a "hard boot" or reset of your system might solve the problem(s).
Hope this helps you out.
Good Luck!
-Steve
Dec 16, 2014 | Garmin Boating
What is causing the depth to keep blinking when my boat is on plane.sometimes the screen just shows a horizontal line where the depth should read. garmin541s brand new
First, make sure that the connection is good, clean, and tight on both ends of your transducer. Sometimes turbulance or temperature stratifications in the subsurface water will cause this. Also, check the specifications of your transducer. Some do not perform well while moving at high speed. One test, when on plane, when the problem occurs, slow the boat and see what happens to the readout. Repeat this several times. This should help narrow down what is causing the problem.
Sep 19, 2013 | Garmin GPSMAP 541s
Garmin 541s rear tansducer does not read after plaining out
first of all it wont read after you plain out and as far as cutting off connect it straight to the battery see if that fix your problem
May 08, 2013 | Garmin GPSMAP 541s
I lose depth when moving
that's common with all depth finders when on plane you loose bottom lock when you slow down to stop does it start to work again if so you have no problem
Apr 22, 2013 | Garmin GPSMAP 541s
Is Garmin Fishfinder 90 working?
possibly.most ive owned will flash random numbers when out of the water.the fact its flashing or reading numbers at all,means its working.youll have put it in water to see how accurate,obviously
Jul 08, 2010 | Garmin Fishfinder 90
I have a gps Map 498-depth sounder not working? Have new transducer from Garmin-it flashes "00"-it is not connected to boat yet (transducer)-need it be or can I put in a bucket of water (need it be in...
If the transducer is out of the water, you will not get a reading and see the flashing depth. You should hear and feel the clicking in the transducer when out of the water and working properly. Are you getting a temp reading when out of the water?
May 16, 2010 | Boating
New GPSMap 440 S Depth flashing
You need to visit the garmin site and download a software upgrade its free and should fix any glitches you may be experiencing with your unit.
Jul 01, 2009 | Garmin Gpsmap 440s Dual Frequency Combo
Eagle 640c Fish Finder dosen't read corectly.
I had the same problem and got the transducer changed. It now works perfectly. That could be the problem you are having... bad transducer.
May 17, 2009 | Eagle Intellimap 640c Marine GPS GPS...
Garmen 240 fishfinder
A test bucket wont work, A 200 khz transducer will generally not work in anything less than 2' of water, due to surface clutter. If the transducer is working, you should hear it make a ticking sound.
When you got the 17000 foot reading was your range set to auto?
How is the transducer situated on the boat? Sometimes turbulence and bubbles from the hull can cause erroneous readings, including unrealistic depths, or no depth at all. Stop the boat and turn off the engin e and anything electrical to see if problem repeats itself. If it only crops up when the boat is moving then it is most likely the transducer location.
Jul 26, 2008 | Garmin GPSMAP 235 Sounder GPS Receiver
Garmin GPSMAP 541s Logo
192 people viewed this question
Top Garmin Boating Experts
TO Lady
charles
Are you a Garmin Boating Expert? Answer questions, earn points and help others
