Question about HP ProBook 4530s Notebook
Cant Install windows 7 pro
My boot divise shows me eror when i want to make me an new copy of windows 7 pro
    New Friend:
"Make a new copy" of Win 7 pro: are you copying an OEM DVD then trying to boot from it?
Posted on May 10, 2013
Testimonial: "what is an oem dvd i have make an copy from deamon tools an copy and still nothing my boot divise wont let me "
  • runo May 10, 2013
    how do i make an oem dvd whit an demon tool windows 7 pro file i have burn it whit demon tools but nothing
    New Friend:
    Problem Solver:
  • 14 Answers
If someone need windows 7 key that i suggest you go site www.funkinyes.com to got. 100% genuine it to provide. Hope can help you.
Posted on Feb 02, 2016
Tip
Install Windows 7 or Windows Vista on a Pc Without DVD Media
For user who doesn’t want to waste a DVD disc to burn the ISO to physical media, and does not have WinPE (Windows PE) startup disc, here’s a workaround method to install Windows Vista and Windows 7 into physical computer’s hard disk drive or partition (volume) directly with ISO without writing or burning to disc. The without-disc installation method is useful especially during beta and RC period of new operating system in the making, where the new build and new versionis launching and publishing every now and then. This tutorial guide assumes that the new Windows 7 or Windows Vista will be installed and replaced the original existing operating system currently installed. The instructions can be modified slightly (mainly on hard disk partition used) to fit into need of readers who want to have a dual-boot, multi-boot, or simply just to upgrade install to new OS.
1. Install a virtual CD/DVD drive on existing Windows operating system.
2. Mount the Windows Vista or Windows 7 installation DVD ISO image using the virtual drive.
3. Copy all files inside the virtual CD/DVD drive mounted with the ISO into any folder on any partition or hard disk drive not going to be used to install the Windows OS. For example, copy into E:\Windows7.
4. Copy the bootmgr and boot folders nested inside the copied folder (i.e. \Windows7) to root directory of system boot drive, typically C:\.
Note: For Windows Vista, users may need to use this step: Copy the bootmgr folder from E:\Windows7 to C:\ root directory, copy E:\Windows7\boot\boot.sdi file to same folder in C:\boot folder, and then copy bootsect.exe from the E:\Windows7\boot\ folder to C:\ drive.
Note: boot folder in system boot drive is hidden system folder.
5. Create a new folder named sources under the C:\ root folder.
6. Copy the boot.win file inside \Windows7\sources folder to the source folder created in the system boot drive, normally C:\.
7. Open a command prompt as administrator.
8. Run the following command (change the C to your drive path letter if applicable):
C:\boot\bootsect.exe /nt60 C:
For Windows Vista users who copied bootsect.exe to C:\ root folder, use the following command instead:
C:\bootsect.exe /nt60 C:
A successful message is the command completes successfully.
9. Change the name or label of the boot system partition local disk to BDCP or any name you prefer that easier to remember and type (in DOS command promot, use label command).
10. Restart the computer.
11. After booting up, the system will start the corresponding Windows installation process. Select the applicable language to install, time and currency format (regional settings locale) and keyboard or input method in the installation wizard dialog.
12. On the next screen, user will be presented with option to Install Windows. DO NOT press on Install Windows button, instead, click on Repair My Computer link on the bottom left corner.
13. In the Windows Recovery Environment (WinRE) System Recovery Options dialog window, click on Command Prompt to open a DOS Prompt window.
14. Run the format command to format the primary hard disk or partition to clean state:
format c: /q
Note: /q switch, which perform quick format can be omitted to full format. And if existing hard disk partition is of FAT32 filesystem format, use format c: /q /fs:ntfs to convert the file system to NTFS while formatting. Before formatting begins, the command may prompt for hard disk drive or partition label name, if so, enter accordingly (i.e. BDCP).
15. After format completed, start the Windows Vista or Windows 7 installation process again by manually running the setup.exe located in the copied. Note that the setup.exe is not the one located on boot system drive which copied at later step, as the boot drive has been formatted. For example:
E:\Windows7\sources\setup.exe
16. Continue with installation procedures by following on-screen instructions as per normal practice.
on May 19, 2010 | Computers & Internet
Good day PRO, I WAS TRYING TO INSTALL WINDOW 7 ON MY Asus Eee PC 1005HAG/1005HGO COS MY UNCLE CONVERTED IT 2 VISTA HOME PREMUIM and remain a day 2 Expire. When install window 7 i selected window 7...
FIRTST YOU NEED TO CLEANUP YOUR C DRIVE .WHEN YOU INSERT THE CD REMOVE ALL THE OLD PROGRAM FILES BY SELECTING THE OPTION FOR C DRIVE THEN INSTALL THE FRESH COPY OF WINDOWS 7.
Jul 21, 2011 | Computers & Internet
I have a toshiba satellite a205-4707 when i got it it would freeze at startup i had a ancient copy of xp pro sp1 i could only install with power cord unplugged.even after install if i plugged in power cord...
http://www.4shared.com/file/oE15gXll/killdisk_and_boot-cd-iso.html
get this from my shared drive(read instructions in there)
and wipe your disk clean (Warning...this process will make you lose all data on disk so be careful, if posible backup all critical data that you need)
once done install WinXP SP3(get a Windows XP cd from a friend or download a pirated copy from net) look for "WinXP SP3 piratebay" in google
when installing WinXP make more than 2 partitions (C, D, E)
Install WinXP in C
once done, let Windows boot and show Desktop
install WinVista or Win7 in D
use E for saving your critical data
Nov 29, 2010 | Toshiba Satellite A205-S4617 Notebook
Copy WIndows XP from one hard drive to another
Why are wanting to clone your hard drive to another on when all you need to do is install Windows 7 directly onto the new hard drive?
Are you wanting to save all your settings and data before you install Win 7 over the top of XP?
Jul 20, 2010 | Microsoft Windows XP Professional for PC
I my laptop cant boot windows 7 and xp together !
Since you have installed XP after installing windows 7 & vista, you have erased the boot manager of vista. To get it back, just download & install Vista Boot Pro from http://www.softpedia.com/get/System/OS-Enhancements/VistaBootPRO.shtml
May 04, 2009 | Acer TravelMate 4320 Notebook
CANT GET WINDOWS XP PRO TO COPY FILES TO A GX280
The problem is the driver for the sata hard drive. You would need to get that from the dell site and put it on a floppy disk, then at the start of the windows install select to install that driver. I ended up just installing the rc version of windows 7 and it worked out fine.
Mar 02, 2009 | Dell Optiplex GX280 (99301) Motherboard
HP ProBook 4530s Notebook Logo
135 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
