Question about Sanyo Microwave Ovens
Some power but not operating
Facia panel lights up when plugged in. timer counts down when programmed. light not working when door opened. turntable not working. bulb checked-ok. two fuses checked-ok.
Check out with a multitester whether the control panel switch on the power towards the high voltage transformer NNB disconnect the high voltage transformer for this test. if not the relay on the electronic controlle device is broken and the panel needs replacement. check also the 3 safety switches on the door for proper operation. mind the power it is dangerous.
Posted on May 11, 2013
MicrowaveSvc
  • 9047 Answers
SOURCE: Oven not coming on but timer and lights working
The door switches are almost certainly the culprit - probably the upper one. It may also be a loose mount, or even a loose spring in the hook-like devices on the door which activate the switches. There is a center monitor switch whose purpose is to blow open the fuse if the door is open and the upper or lower switch gets activated. That's why the fuse blew when the screwdriver was introduced - you activated the door switch while the monitor switch was on. I've attached a generic picture which gives you the idea. More importantly, at my Web site, I have critical safety information, disassembly tips, and infomration on checking and replacing door switches. You can find these via my link at FixYa here: http://tinyurl.com/yzjozk
Posted on Feb 03, 2007
  • 619 Answers
SOURCE: Sharp R-1505 microwave
The power fuse open , if open replace it don't make jumper it b
cause fire .
the power transformer builtin fuse open/
The door micro switch open /need to replace.
Posted on Jan 03, 2008
jeltey
  • 44 Answers
SOURCE: JVM1190 wont cook
You have a blown actuator. This is the device that creates the microwaves that cook the food. The cost of one of these will be as much as a new unit.
Posted on Nov 09, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: Microwave Oven Does Not Start Cooking
This is usually caused by either a bad door switch or a loose door switch mount, which are pretty simple problems to fix.
Even though a door switch clicks, it may still be bad inside.
Door switch or mount trouble is usually caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
One test that sometimes helps is to gently lift up (and/or push down) on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
If you don't find yours, or if you want to look at it without disassembling the oven, you can download it here.
If yours is not shown at the parts site or manual site linked above, Please reply back with your brand and model number so we can help you.
If you only need a switch, you can order a universal type here for $5 postpaid.
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases in about a week or so.
Posted on Dec 25, 2008
  • 19 Answers
SOURCE: Microwave GE MD JVM140K Spacemaker yr= 1994 NOHEAT, DISP/TIMER OK
Call GE answer center 1-800-626-2000
ask for tech help
Have you model # off your data plate ready.
Posted on May 10, 2009
Turntable does not spin, no heat
HV fuse has failed. Possibly caused by door switches or Diode Pack failure. Do not attempt a repair unless you are competent to do so. Extremely hazardous voltages inside!
Feb 27, 2014 | GE Spacemaker JVM1640SJ Microwave Oven
Kenmore elite microwave model 721.79203010 problems
I'd check to make sure you don't have a door switch that isn't functioning properly. Also, might be a control panel or control panel interface issue.
Mar 18, 2013 | Microwave Ovens
Microwave timer works but will motor will not run/cook.
If everything works on the unit, but you do not receive any heat or possibly the turntable does not turn you have a faulty magnetron (controls heat) and a faulty motor (controls turntable). You would require service on the unit, if parts are available. Some microwaves are so small in cubic foot size, that manufacturer's do not have parts available for purchase/repairs.
Dec 24, 2012 | Frigidaire FMV156DC Microwave Oven
My GE Profile Countertop Convection/Microwave Oven PEB1590DMBB Has stopped working.
It sounds like you may have a shorted cook relay on the control circuit board which can be repaired simply and inexpensively.
A YouTube video showing how to remove a typical over the range control panel assembly in under 5 minutes, is here.
Nov 30, 2012 | General Electric PEB1590DMBB: Profile 1.5...
Mbbs 01 thermador micro oven: timer counts down, lights go on, but no heat, no fan and turntable does not turn. is it a fuse?
Key clue is table does not move---All microwaves with a table have a lever switch that is engaged when door closes--only can get at from inside the unit----it prevents the unit from operation if door not closed.
What happens from closing door a lot is the switch with a lever arm can come loose or even if snapped into a plastic holder break out of the holder.
IF this it is not too expensive a repair.
Jun 16, 2012 | Thermador MBBS Microwave Oven
Kitchenaid KCMS185JSS
The problem is one of the door switches has failed, usually caused by food partical buildup, switch must be replaced for normal operation.
Mar 12, 2012 | KitchenAid Microwave Ovens
Timer counts down but turntable won't spin and fan does not come on. Light on interior comes on when door is open and exhaust fan works. Any ideas?
In all likelihood the mangnetron has failed, or perhaps even the Power Supply. or a fault that is shutting the system down for safety reasons You need to have it serviced by a reputable service centre/man. Ensure you get a firm "Quote" before proceeding, and remember these days the cost of repair can equal or exceed the price of a new one.
Feb 15, 2010 | Frigidaire FMV156DC Microwave Oven
Fan & Turntable start when door is opened.
sounds like there is a switch that is bad. you can go buy a new MW for about 200$ and in yours if there is a major problem then i would just go buy a new one but might be worth a repair man to come check it out
pleas do not poke around in the microwave as it carries a charge of 5000volts and can kill you even if not plugged in DON'T TOUCH THE WIRES WITH BRAIDS ON THE OUT SIDE if you must get inside of the unit
Dec 10, 2008 | Microwave Ovens
cause fire .
Jan 03, 2008 | Sharp R-1505 Microwave Oven
Microwave Ovens Logo
117 people viewed this question
Top Sanyo Microwave Ovens Experts
William Miller
William Miller
Greg Cann
Greg Cann
tony denham
Level 1 Expert
Are you a Sanyo Microwave Oven Expert? Answer questions, earn points and help others
