Pixma all-in-one mg5460 paper jam
The paper is jammed, and I can see it when I lift the panel. My kids were messing around and the paper just got sucked into the printer. Please help.
SOURCE: 'paper jam' error on canon pixma ip4300
Hi guys, I eventually found a solution to the problem for my printer. With the top cover open, I pushed a sheet of 120 micron thickness A4 clear plastic binding cover through the exit tray as far as it would go to rest against the bottom row of rollers. I switched the printer off then back on again and as the rollers lifted momentarily, I pushed the sheet of plastic as far up through the machine as I could before the rollers went down again - it went in a fair distance. The printer then ejected the plastic sheet. I then put the plastic sheet into the paper tray and tried to print a blank document page. The plastic fed through cleanly and my printer has been working since without any error messages. I hope this works for you.
Posted on Mar 04, 2008
SOURCE: canon mp180 paper jammed
I finally fixed the problem by running two sheets of heavy card stock through at the same time. With the machine off, I positioned the two sheets in the feeder so that they would be pulled in when the printer was turned on. When I turned on the printer, it drew the two sheets through and I guess this reset the paper sensor. I previously found that only one sheet at a time did't work.
I found this solution posted by JsamJr answering another question but it worked for me. pushing the card in and then removing it and pressing ok worked
Posted on Apr 28, 2008
  • 83 Answers
SOURCE: I had a major paper jam at my printer (Canon,
  1. Protect yourself from shock. Disconnect the power cord from the back of the Canon Inkjet Printer. This is an important step when working inside ANY electronic device.
  2. Step 2 Unhinge the back access panel of the printer. It seems repetitive to say this, but this door will be in the BACK of the printer.
  3. Step 3 Look through the opened back panel and look for paper. Remove any and all paper you find jammed there.
  4. Step 4 Close the back access panel. Make sure that it latches into place and looks the same way that it did before you opened it.
  5. Step 5 Find the front or top access panel. This is the panel you would lift to change ink cartridges. Open this access panel. If the carriage that holds the ink cartridges moves, then you forgot to unplug the printer, go back and do that now. Look for paper that may be jammed in this area of the printer.
  6. Step 6 Remove any paper you find jammed here. When pulling from the front there will be resistance from the paper feeder. Pull slowly or the paper will rip and create a more stressful problem.
  7. Step 7 Close the front access panel. Make sure that it falls or latches back in place. It should look the same way that it did before you opened it.
  8. Step 8 Plug the printer's power cord into the wall outlet, and attempt to print again. If the printer prints the job, then you have successfully removed the paper jam.
Posted on Jan 26, 2010
pineworks
  • 4041 Answers
SOURCE: paper won't feed through canon printer. no paper jam apparent -
Hello there gave it a go this may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 16, 2010
  • 4 Answers
SOURCE: Printer keeps on jamming paper
Turn the darn thing over and shake it. there's probably something in there. In mine it was a miniature oyster cracker. Works great now but I was about to go insane until i shook it out.
Posted on Sep 08, 2010
Paper completely jammed
Lift feed panel, then the cover. carefully pull in thedirection of normal feed onto the scan plate. Do not try to pull out from the entrance.
Mar 13, 2015 | Canon Pixma MG3150 All-In-One Color...
Cannon pixma mx922 paper jam
I had a very bad jam (paper tore...you know the drill...see upper panel). My wife and I used a chopstick and hemostats to gently, gently lift the rollers and ease the paper out (lower panel...most of the paper has been pulled out). The stick should be applied to the support between the rollers. You have to go from roller-pair to roller-pair, easing the paper out without ripping it.
Oct 14, 2013 | Canon Office Equipment & Supplies
It won't feed paper
Hello, Welcome to Fixya.com
The paper feeder sensor in the APF is what might be causing your issue.
1. Check for any jammed paper in any part of the printer.
2. A jammed piece of paper can cause the paper not to feed.
If that is not the case you might need to have this looked at locally.
Regards
rulds2008
Mar 22, 2011 | Canon PIXMA MP240 All-In-One InkJet...
Error 3 indicated - what is it and how do I fix it
E3 means that there is a paper jam. If you are getting the E3 error and there is not an actual paper jam you may need to do is simulate a paper jam. Try inserting paper crooked to cause a jam so that when it starts trying to feed the paper through it gets jammed. Then lift the cover up and take the paper out. You'll then get a bunch of the lights flashing. Turn the printer off and then back on and you should be good to go.
Mar 04, 2011 | Canon PIXMA MP150 All-In-One InkJet...
Paper jammed
    This is how to clear paper jammed in canon inkjet printer.
    2. Unhinge the back access panel of the printer. It seems repetitive to say this, but this door will be in the BACK of the printer.
    3. Look through the opened back panel and look for paper. Remove any and all paper you find jammed there.
    4. Close the back access panel. Make sure that it latches into place and looks the same way that it did before you opened it.
    5. Find the front or top access panel. This is the panel you would lift to change ink cartridges. Open this access panel. If the carriage that holds the ink cartridges moves, then you forgot to unplug the printer, go back and do that now. Look for paper that may be jammed in this area of the printer.
    6. Remove any paper you find jammed here. When pulling from the front there will be resistance from the paper feeder. Pull slowly or the paper will rip and create a more stressful problem.
    7. Close the front access panel. Make sure that it falls or latches back in place. It should look the same way that it did before you opened it.
    8. Plug the printer's power cord into the wall outlet, and attempt to print again. If the printer prints the job, then you have successfully removed the paper jam
Dec 19, 2010 | Canon PIXMA iP1800 InkJet Photo Printer
Keeps having paper jams need help
Protect yourself from shock. Disconnect the power cord from the back of the Canon Inkjet Printer. This is an important step when working inside ANY electronic device. Unhinge the back access panel of the printer. It seems repetitive to say this, but this door will be in the BACK of the printer.
Look through the opened back panel and look for paper. Remove any and all paper you find jammed there. Close the back access panel. Make sure that it latches into place and looks the same way that it did before you opened it.
Following the steps above you can clear the paper jam issue on your canon inkjet printer installed on your Windows based PC.
Hope that helps.
Thanks for using fixya..
Nov 17, 2010 | Canon PIXMA MX320 Color USB InkJet Printer
What Does E3 mean
E 3 means "Paper Jam". If there is no actual paper jam, but the error cod E3 is still there, it might be that something has fallen into the printer, or a piece of paper has been jammed in there. First, remove the cartridges, and turn the printer upside down and gently shake it to see if anything comes out. If nothing goes, or you can't hear anything, what you need to do is simulate a paper jam (it thinks there is one, so give it one!). Just shove a paper (120g or heavier) inside the printer (after lifting the hood up) so that a real paper jam would occur. When it starts trying to feed the paper through and its getting jammed lift the cover up and take the paper gently out. You'll then get a bunch of the lights flashing. Turn the printer off and then back on and you should be good to go.
Apr 06, 2010 | Canon PIXMA MP210 Photo All-In-One Printer
Paper jam; paper "wrapped around roller -- OK to pull it out?
simply pull out the power cable then just simply open the back cover and pull gently on the paper.
do not just rip it out... Gently and it should be fine
hope it helps
Jan 05, 2009 | HP Deskjet 6940 InkJet Printer
Paper tray empty, or paper jam at back
Hello, I had same problem with my Pixma 600, when you lift the control panel flap to turn on the printer just below the on off button ther's a small icon of the printer with a green led at the top and one at the bottom. Press the button to the right to change either top paper feed to bottom tray feed or vice versa.Then try again, you may need to load paper in tray at bottom/front on printer.
Cheer's
Paul 'W'
Onyer~EDson(:0)~[><
Nov 27, 2008 | Canon PIXMA MP830 All-In-One InkJet...
check if there is a little paper that stuck on it that causes a paper jam
Mar 09, 2008 | Canon PIXMA MP210 Photo All-In-One Printer
331 people viewed this question
k24674
