Pixma mg5460 support code 6000, paper jam..
Paper appears to be jammed
shaggyrat
  • 1224 Answers
SOURCE: canon pixma mp460 code error 6000
Solutions for error 6000 Issue: ERROR LCD: Error code (5xxx through 9xxx) appears on the display
1. Press ON/OFF switch to reset the multifunction device 2. Removing paper jams MP450 / MP460 3. The MP460 may require repair
heres the problems currently with mp460 and at bottom is the link
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=238&modelid=13369
this is the solutions for the mp460
for the guest
clean out your ink absorber after unplug
reset printer you still have a little credit card sized paper in your printer that you need to remove it
Posted on May 21, 2008
SOURCE: paper jam problem in pixma mp145. E3 error.
I have trying resseting and the error message does not clear. I have checked the printer througly and there is no paper jam.
Posted on Nov 29, 2008
SOURCE: says paper jam but there is none. pixma mp450
Take any paper out of the paper feeder and get a plastic ruler the softer the better lift the top of the printer up so you can see where the print cartridges are now push the ruler down through the paper feed roller be careful because you could break the rollers go from left to right right to left twice and check for any debris once you have done this unplug the printer for about 20 seconds then plug back in and let it reset then try copying or printing a doc and see how you go!
Posted on Mar 11, 2009
  • 52 Answers
hi
just recently had these problems
symptoms:
LED flashing E3 code and alarm light was solid. But dissapeared when opened the coved and came back on when closed the cover.
Also the when the cover was open the inks did not slide out to the left and stayed to the right side.
There was no paper jam, but error said paper jam.
Solution:
1. I took a thick piece of paper, from like a paper folder ones, thick enough to go in the printer and not curl up when pushed..
2. turned off the printer and turned it back on.
3, while printer was turning on,and makings sound as it does normally when turning on, I pushed through the piece of paper and the rotors stoped for a millisecond.
4.the rotors started again and pushed out the paper by it self with out my force.
5. I let the printer get started. and then turned it off and then on.
6. this solved all of my problems.
this was the first problem ever with this printer in 3 years.,preety good printer.
Posted on Nov 04, 2009
pineworks
  • 4041 Answers
SOURCE: paper won't feed through canon printer. no paper jam apparent -
Hello there gave it a go this may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 16, 2010
What is service code 6000?
Hello Richard Miller
The error that you have, it means that your printer has a paper jam, this is the error appears in you computer, may be in the printer have the next error number. P3 followed E3
If you are writing this review, it is because they believe you have a paper jam, if they have seen and removed yourself.
Principally printers and Canon, in many cases the system detects a paper jam, but is not exactly a paper is causing the problem, in many cases can be any object that has entered and is obstructing the passage of the pages.
My first recommendation is to look carefully where they enter the pages on your printer, if necessary use some lighting for better viewing, you might find something there.
If after all get nothing related, follow the steps below to solve your problem. http://www.en.rellenadodecartuchos.com/2015/04/delete-service-error-6000-or-p3-fallowed-e3-canon-pixma-mp240-printer.html
Even then, you can not solve the problem, I recommend the following way, which is to eliminate jam Canon inbox.
service-code-6000-xnnjabddbe1z3hwtjta3ekn0-4-2.jpg Remove error 6000 printer Canon PIXMA MG2410 en Rellenado
To be honest most of the time are other elements that influence paper jams, which can not be determined on the Canon printers.
Nov 20, 2015 | Canon PIXMA Office Equipment & Supplies
Errror code 6000
Error code 6000 appears when the paper jam, power off the printer and remove carefully the jam paper and power on the printer:
Nov 09, 2010 | Canon Pixma MP450 All-In-One InkJet...
Error message 6000
6000 is a paper jam or jammed sensor.
http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_mp_series/pixma_mp600#ServiceAndSupport
Click service and support, then enter error 6000, then click Error LCD ... 6000..., then click Removing paper jams mp600. Sorry, but they use javascript so I can't give you a more direct link.
Sep 08, 2010 | Canon PIXMA MP600 all-In-One InkJet...
3 yellow flashes, then 1 green on a Canon PIXMA Ip4000
3 flashes is a GREAT symptom report. We need some more than that, but it does give us a direction.
If this is a "Service Call Error", it will be accompanied by an on screen message that includes a "6000" error code.
Here are the possible solutions....
- Timing sensor unit (QM2-1213)
- Timing **** disk film (QC1-4833)
- Feed roller ***'y (QL2-0598)
- Platen unit (QM2-1215)
- Logic board ***'y (QM2-1548)*1
- PAPER FEED MOTOR (QK1-0550)
These solutions are not for the novice, but are user servicible for many out there.
If this is a "Operator Call Error", it will also be accompanied by on screen error codes
Paper jam. [1300]
Paper jam in the under guide. [1304]
Paper jam in the rear guide. [1303]
Solution: Remove the jammed paper, and press the Resume/Cancel
button.
OR
Front door closed. [1250] Open the paper output tray.
Get a free copy of the service manual by contacting me at www.Equipmentcity.net
Sep 29, 2009 | Canon PIXMA iP4000 InkJet Photo Printer
Canon error code 6000 in mx308
please help me. i have canon print mx308. the have paper jams. paper has the full out from print. how i can finish the problems?
Jul 25, 2009 | Canon Pixma MP450 All-In-One InkJet...
What is error 6000
I the paper is jammed. Purge unit is jammed with something and not being able to move. Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like.
Jun 26, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Cartridge is jammed
I have a canon pixma 780. It was working fine then I had a paper jam and message "Cartridge jammed" I removed paper with no difficulty-piece was not torn.Now it will not print at all Paper feeds through but no printing in any colour
Mar 17, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Canon pixma mp460 code error 6000
for the guest
May 16, 2008 | Canon PIXMA MP600 all-In-One InkJet...
532 people viewed this question
k24674
