Belling fastlite hob
One of the rings will not turn off. can this be fixed or should I get new one. Age 5 years
4 Suggested Answers
jackboy
  • 2985 Answers
SOURCE: Belling Cooker Hob Cracked
Nope
Posted on Jul 25, 2007
  • 3 Answers
SOURCE: Heat not turning down on hob or ovens
Found this online - £101.99
Belling Stainless Steel Cooker Control Panel for DB90
http://www.espares.co.uk/part/cookers-and-hobs/belling/db90/p/1092/154/0/538873/547712/stainless-steel-cooker-co.html
Posted on Mar 18, 2010
SOURCE: hob regulator wiring
OK, they are wired so that the two elements are switched in and out, to form, a single, a dual but in series, and a dual, but in parallel. like this Low, ONE, Element ONLY, The Other is out of circuit. Med, TWO elements are connected using the switch, in SERIES with each other. High, you switch TWO elements in PARALLEL. Simply meter the switch out to do that when each position is turned. Just think of it like, It's just two resistors, wired up. single, series, & parallel.
Posted on Apr 19, 2010
Beko HII64403T induction hob, the left 2 rings packed in tonight, they went from 6 to E then turned off. the 2 right rings continued to work.
contact BEKO they will know why they did what they did and will know better what the fix will be . sounds like the 2 units might have burnt out due to not having the pots on them .
Nov 08, 2016 | Kitchen Ranges
What can I do about the hobs overheating - when on, they are only on the highest heat and can't be turned down.
THE only solution is to replace the regulators that control the hotplates.
Could prove to be expensive.
Mar 01, 2015 | Belling Ovens
I have a belling 335 and both the oven and rear left hob ring have stopped working. what is likely to be the problem?
The thermal fuse inside rear is faulty. The grill also has it's own thermal fuse so make sure you change the correct one.
Sep 06, 2012 | Belling 335 Electric Kitchen Range
When turning on my 2 year old Neff induction Hob T4543N1 it displays a full set of E errors and cuts out it does after two attempts corect itself and function perfectly
I had flashing Es every time I turned the hob on - got worse and worse until unusable. Neff help line useless - service call cost ridiculous. My problem was the capacitor on the 5 volt power supply had failed. 5 volt supply was at 3.8 volts. Replaced the capacitor and the hob's now perfect - a joy to use. Only helps if you are tech savvy and willing to open the unit, but may give you some hope or point you in the right direction.t
Jul 28, 2010 | Neff Cooktops
Hob regulator wiring
Apr 19, 2010 | Belling CookCenter 151 Dual Fuel (Electric...
Replacing faulty regulator for hotplate
Remove hotplate and oven control knobs. Under the 2nd and 5th knobs is an extra screw which holds on the front cover. Unscrew these and free the cover then access is gained to the screws (2 on each edge) which removes the plate to which the regulators are fixed.Remove the faulty regulator by unscrewing it from the plate,(2 screws) It is an easy job then to install the new part taking care to put the correct wires on the correct terminals. Reassemble, job done!
Jan 11, 2009 | Belling Cooktops
Electric hob
You have a faulty heater element on the hob, what is probably happening is it is ok until it gets hot then it shorts and blows the fuse. You need to identify which hot ring is faulty by trying them in turn (if there is more than one that is) and then replace it.
Oct 21, 2008 | New World 60ESO Electric Kitchen Range
Aeg hob
It is child lock.
Turn cooker on, press two + at front of oven, this will then take it off for that cooking session.
To turn child lock off switch on hob, and touch - for 5 seconds.
Sep 29, 2008 | AEG 23 in. 6410KF-N Electric Cooktop
Televison & Video Logo
37 people viewed this question
Top Televison & Video Experts
Electro Med Services...
