Question about Garden
Qualcast trojan 16
I tipped it on it's side to get some grass out and now it won't start. I have tried taking out the spark plug and cleaning it but that does not help. The throttle adjustment doesn't seem to do anything, not sure if that broke somehow. The spring is just baggy and when I move the lever nothing moves at the back. Thank you!
rwvanlue
  • 486 Answers
SOURCE: Honda GV100 won't start. Fires up
problem is fuel starvation or a 'lean condition'
carburetor main jet, bowl, and pilot air jet need to be cleaned
Posted on Nov 09, 2009
kel1guy2002
  • 3740 Answers
SOURCE: The Briggs and Stratton engine on my lawn mower
Hi and welcome to FixYa, I am Kelly.
There is a brake on the flywheel with a kill switch on the flywheel brake mount (behind the flywheel) on the back of the engine. Usually you can correct this by readjusting the user safety handle / bar cable at the back of the engine on the side of the flywheel brake bracket. 1/4" head screw to lift of the plastic cover most of the time and then loosen the cable clamp / mount .. pull the cable a bit furter away from the original position re-tighten clamp and squeeze the user safety hande to make sure the kill switch is no longer activated when the user safety bar is against the mower handle.
Since you did not include an engine model number I can not discuss specifics on you engine. I can do so with your engine model number.
GENERICALLY speaking
If that does not correct the problem... if your engine has a LOW oil level sensor make sure the engine OIL is fully serviced. If the oil is fully serviced and you still have the problem on sensor models... disconnect ONE wire from the low oil level sensor and re-test spark. If disconnecting the low oil level sensor wire corrects the no spark issue.. remove the sensor and clean through the 2 holes in the barrell of the sensor with carb cleaner... several times to flush it.
On engines that do NOT have a low oil level sensor you have to inspect the black wire coming from under the flywheel for any signs of melting or chaffing. Usually you can repair any noted wire damage with electrical tape. Note fuel eventually eats the adhesive off of the electrical tape. I use electrical tape and a mini zip / cable tie over the tape so it does not migrate or come off.
Thanks for choosing FixYa,
Kelly
Posted on May 22, 2011
hunter19_46m
  • 7482 Answers
SOURCE: My 5 hp automatic throttle surges and won't idle
Hi savage524...
Remove your spark plug and check to be sure you are getting fire at the spark plug.
You do this by grounding the plug on the head of the engine and pulling the crank rope, if you are getting spark then:
Check/Clean/Replace your fuel filter if you have one, normally they are located in the fuel tank of weedeaters.
Also make sure you are using fresh fuel...and oil mix if your using a two cycle mower or weedeater with the oil to the right mixture and not too much oil as it can cause hard starting.
If the mower/weedeater is over a year old, then I recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
Sounds like you will need to clean the carburetor or replace your carburetor internal rubber parts like the diaphgram and O rings.
I recommend that you use a laquer thinner type cleaner to clean and dissolve the laquer build-up in the float and needle jet passages.
Be sure to remove all plastic and rubber parts before using the laquer thinner because it can dissolve the plastic parts and render them unuseable.
Be sure to use compressed air to blow out all the fuel and air passages.
Be careful when blowing out the passages, because there are sometimes small rubber type seats in the bottom of some of the passages.
Sometimes you can get by with priming the carburetor or using starting fluid and letting it run a few times like that and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
Keep in mind that the float for the carburetor must be level when you go to reassemble the carburetor or follow the instructions you get with the carburetor kit.
When you clean your carburetor and remove the jet screws, you will first need to lightly seat the jet screws.
But before you lightly seat the jet screws count the number of turns it takes to seat the jet screws from their original position.
Be sure to mark the turns down on a piece of paper.
That way when you put the jets back in, you know to lightly seat them first and then turn them back out to their orginal position before you started.
Once you have your carburetor rebuilt that should solve your problem.
This is a FREE answer,Please take time to rate me
Posted on May 28, 2011
Testimonial: "I am already finding dirt in the carb as I take it apart. This is the problem thank-you. "
philwalker78
  • 605 Answers
SOURCE: Model 917-372832 Eager-1 5.5 HP
Hi, you are correct, the key will be sheered. Remove the top shroud and flywheel nut, then while pulling upwards on the flywheel have someone strike downwards on the crankshaft with a hammer and brass drift. Do not use a steel drift as it will damage the crankshaft. Hope this helps, regards Phil.
Posted on Jul 18, 2011
  • 6468 Answers
SOURCE: toro mower won't start
bad safety switch or bad coil
Posted on Apr 08, 2012
Not cutting
If the mower starts and runs, then shut it off.
Find the spark plug.
Now, tip the machine up on its side WITH THE SPARK PLUG UP.
(If you do not, and if you tip it the wrong way, you can fill the combustion chamber with oil and ruin the machine when you try to start it again.)
Once it is tipped, look under the machine, and feel the blade to see if it is tight or loose on the motor shaft, and also if it needs to be sharpened.
If loose, tighten it.
If dull, sharpen it.
God bless your efforts.
Apr 12, 2016 | Garden
Motor mower wont start
By tipping a 4 cycle motor on a lawn mower or any equipment, you have all the oil and gas running into the combustion chamber and sometimes the oil and WATER will get into the tank. It will need too have the spark plug removed, the engine turned over with the starter to blow the oill, gas, and water out of the cylinder(s), the plug should be either dried and gap reset, and the gas tank drained and FRESH gas put in it. Replace the spark plug prime with just a few drops of gasoline in the carburetor throat and restart and let run to dry evrything. NOTE: An oil change is recommended, too!!
Jan 14, 2014 | Garden
I have a yz 250 Yamaha layed it over on it side and now can't get it to start put new spark plug in has spark but won't fire
fuel problem take out the carb and clean all the jets and the bowl also put a high flow fuel filter in as a precaution incase there is debree in the tank your problem is that you are not getting enough fuel or any at all.
May 11, 2012 | 2003 Yamaha YZ 250
I have a snapper 28 hi vac riding mower that won't
first try and start it with carb cleaner or starting fluid with the air filter out if it fires then its a carb/fuel problem if not it could be a spark problem remove the plug connect hte wire back up and crank the engine over while looking for spark if no spark disconnect the kill switch wires from the side of the engine should be a single wire near the throttle cable if spark with that off the problem is in the wiring or safety switch if still no spark its the coil
Apr 23, 2012 | Briggs & Stratton Garden
Briggs Stratton 625 series 190cc lawn mower: this has been tipped right over and now there seems to be oil in everything and it won't go, what can we do?
If the engine has been tipped oil will come through the engine breather and soak the paper filter, remove the filter, remove the spark plug and clean/replace, with the plug out crank the engine a few times to to evacuate any oil in the cylinder, replace the plug and try again ( with the filter still removed ) when it finally starts it will smoke quite heavily so do this out side and on a non grass surface ( oil sprayed from the muffler will kill the grass) it will smoke for some time until all the excess oil has gone, check the oil level in the engine and top up if required.
Feb 18, 2012 | Craftsman Garden
Cut the grass twice now it won't start. Please help
Need more information...
Is it getting gas? If so take a look at the spark plug wire and make sure it hasn't pulled away from the boot.
REport back what you find
Jun 14, 2011 | Poulan Pro 22" Self Propelled High Wheel...
Ran last year, won't start this year. Changed fuel and replaced spark plug. Checked spark and attempted to start with battery and tried with pull cord but no start. pulled plug and it had fuel on it so...
It might have tipped over on its side. Look at the air filter, if you see oil or gas on the filter then you might have to remove and clean the carburetor. I would start by cleaning/replacing the air filter and trying it again. If its getting fuel and the spark plug works then the only other side of the fire triangle is air.
Jun 05, 2011 | Ryobi Backpack Blower 25.4cc
Won't start after washing it, tries to turn over just won't start
check / remove the spark plug from cylinder head ,clean and dry them both,might water gets into it...
possible should adjust the spark plug tip allowance,make it slight closer.
or try to replace another spark plug. good luck..
hope it helps... please rate me if this is helpful...thanks
Jun 05, 2011 | Suzuki GSX-R 750 Motorcycles
I have a John Deere L110 that won't start. Mowed grass then parked it and it wouldnt start. These are all of the things we have done: New spark plug, solinoid, all 3 safety switches, battery terminals...
problem could be: brake pedal is not depressed; PTO is engaged; battery terminals are corroded; battery not charged; blown fuse; or fusible link in starting circuit is blown.These are the Most Common Causes for your Problem. Recheck your voltage of the battery and then check it under a load....Take a Jumper Cable Set and Attach the Positive Lead to the Positive Post of the Battery. Take the Other End and FIRMLY Touch the Large Post of the Soleniod on the Starter Side. If the Starter Turns the Engine, then Check the Voltage from the Ignition Switch to the Soleniod. If the Voltage is Going From the Switch to the Soleniod When the Ignition Switch is in the Start Position, then Replace the Soleniod. If No Current from the Ignition Switch to the Small Post on the Soleniod, then The Ignition Switch is Bad ....Hope this helps
May 07, 2011 | Husqvarna Viking 1
Garden Logo
104 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
