Question about Gestetner Dsm415pf Digital Imaging Sytem gdsm415pf
Gestetner Right Cover Problem (or something)
Hello , I have a problem with a Gestetner Dsm415pf .. Is is giving me an error that says "Follow Instructions in right cover to remove.. " I looked into the right cover and i see not paper jam or anything.. How can i fix this?
5 Suggested Answers
  • 59 Answers
SOURCE: Can't find paper jam. Looked and looked. Its a
hi if u cant find any bit of paper in paper path may be any path sensor out of order or may be dusty sensor just clean the all paper path sensors
thanks
Posted on May 15, 2010
santosj27
  • 263 Answers
SOURCE: "See instructions in right cover
If you are shore that there is no paper on the machine you probably have a problem with a sensor.
I saw sometimes a broken gate in the fuser unit that causes this symptom.
Try to look at the fuser unit, you will see a blue plastic gate, in front of that there is a black one that sometimes breaks and the sensor not work properly.
If this is the case you have to change that gate. In any cases i advise you to call your provider to solve that.
Hope you understand it
Posted on Mar 28, 2011
SOURCE: Paper is getting jammed in the document feeder
You can also try to clean the paper seperator with a dry cotton cloth
Posted on Jul 19, 2012
  • 192 Answers
SOURCE: My Gestetner- DSm415pf has an error code 121. How do I clear it so I can use the machine?
The only way to reset the jam code is to find the tiny scrap of paper that is still caught in one of the sensors. The 121 jam code is "Exit Sensor Off", essentially it means that the paper did not reach the exit sensor. This would not cause the machine to still think there was a jam, as the paper obviously never made it there.
Check and make sure you have fully closed all the doors, including the front. If that is good, then open and close all the doors one by one. If that doesn't work, then there is a scrap of paper still stuck in the machine somewhere.
If you can't see one anywhere, then it probably is a scrap stuck at the registration sensor, which is just below the registration roller. I've seen this many times, and unless you really get in there and look closely (Flashlight helps), you will never see. It's a major pain to fish it out, so good luck.
Posted on Oct 25, 2012
Drivers for gedtener dsm415pf
Hi
I found driver downloads here
Gestetner Downloads
by using the multifunction machine drop down menu to select your model, click on it and then "GO". This took me to a page with the driver link and also a link to a handy "How to install Downloads" page on the right hand side.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Jan 03, 2015 | Gestetner Office Equipment & Supplies
I need driver for scanner and printer for ricoh nashuatec multifunction dsm415pf mashine for free
Hello!
You can use the scan-to-email or download the twain driver.
For that you can go to www.ricoh-support.com and download it.
See you!
Jul 05, 2011 | Gestetner DSm415pf Digital Imaging Sytem
I want gestetner DSm415pf drivers
Gestetner is made by Ricoh. They only change the name.
You can go to the web site www.ricoh-support.com and you can find the download for free.
The cross reference of your model is Aficio1515.
If you have any dought reply to me so i can give you the help you need.
See you!
Jun 28, 2011 | Gestetner Office Equipment & Supplies
What is the correct driver for using a Gestetner Super 3G DSm415pf with a MacBook OS 10.5.8?
You need the Postscript driver.
But the question is: The machine already have the PS optional?
Because you will need it to use that driver. For that model it is optional.
Mac OS do not support the standard PCL driver
May 02, 2011 | Gestetner DSm415pf Digital Imaging Sytem
How can I scan and store in a pc from gestetner NRG-DSM415pf
First of all you need to create a folder on the PC.
Then create users and specify the path for that folder.
To create user download the user manual. Is there everything you may need.
Mar 26, 2011 | Gestetner DSm415pf Digital Imaging Sytem
I have a printer model dsm415pf I need drivers and manual for the printer
This gestetner is the same as the Ricoh aficio 1515 .You can get the drivers and manuals at www.ricoh-support.com
Jan 04, 2011 | Gestetner DSm415pf Digital Imaging Sytem
DSm415pf Rex-Rotary
The photoconductor has nothing to do with the toner. Photoconductor unit (Drum) is on a 45,000 copy cycle, and comes on when the count is reached. You don't have to replace the drum until the copy quality deteriorates. The machine will continue to work
May 11, 2009 | Gestetner DSm415pf Digital Imaging Sytem
Printer stops during print job
Please check if it is giving an error and read any instruction given on the display when this happens and follows accordingly.
Jan 10, 2009 | Gestetner Copier
Gestetner Dsm415pf Digital Imaging Sytem gdsm415pf Logo
Top Gestetner Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
Norman  J Weimar Jr
Norman J Weimar Jr
Are you a Gestetner Office Equipment and Supply Expert? Answer questions, earn points and help others
