Question about Ovens
Manual for diplomat elite aba3343 - Ovens
A manual for a diplomat high level oven and grill, model number 200504035 adp0312 please
I'd suggest contacting UK Whitegoods. They still carry spares for the Diplomat line, they may have manuals available for download.
Otherwise, manuals.com
Jan 04, 2017 | Ovens
Hi I have a Diplomat elite single oven (AAA3490). When I put the oven on, it is not warming up. Everything else looks fine. Any advice would be appreciated
If you can hear the oven fan running but the oven is cold is is most likely to be the fan element at fault. If there is no obvious damage to the element it should be checked for continuity with a test meter.
Always isolate the appliance from the mains before investigating
Jan 22, 2011 | Ovens
Diplomat Softline ADP0300 Gas-just not cooking ...anything!
Hi there..
I Just recently had the same problem, also with a diplomat gas oven..
The problem I found was down to a small resetable component under the main cover. ..
It took me ages to find the problem and I had taken the whole electical parts of the oven to bits before 'accidentaly' coming across this 'thermal switch' (located inside the main cover, at the top, behind the display module).. - to reset this there is a tiny red button between the connectors.. press this - and it should all be fine again... : One importnat note is that this may be tripping as a consequence of the fan not running or by my thinking not running on after the oven is switched off, leaving the casing to heat up and then trip this switch component.. - if this component is faulty it can be found in RS components or Farnell components.. look for Thermal swich manual reset part no: L100C 9082 470.
Nov 29, 2009 | Ovens
I have moved into a property that has a diplomat cooker. I am looking for instruction booklet for it can you help
Diplomat are no longer trading. These appliances where fitted with MFI kitchens who have also gone
Oct 19, 2009 | Ovens
Diplomat Select 620 single oven and no instructions
how do i remove the door to reseal the glass
May 14, 2008 | Ovens
Manual for a Diplomat Select 620 single oven
Sent the manual to you Tuesday the 18th.
Mar 09, 2008 | Ovens
Diplomat Oven ADP3650 Instructions
User manuals are hard to find.
The problem I had was setting the clock on a single Diplomat oven, with no clock button. Here's my solution :
DIPLOMAT OVEN OPERATING INSTRUCTIONS
The Diplomat single oven is controlled by two knobs and a set of buttons along the middle of the control panel.
The left knob sets the temperature of the oven, while the right knob selects the function to be performed, e.g. fan oven, grill, etc.
The buttons along the middle set the cooker clock, the start and end times of cooking, and the “+” and “-“ buttons will increase or decrease the time shown on the cooker’s clock.
PLEASE NOTE THAT THE OVEN WILL NOT OPERATE UNTIL THE CLOCK IS SET.
If there is any interruption to the power supply (including manually switching off at the main switch) the oven will not operate until the clock is reset.
Here’s how to set the clock:
First press simultaneously the first two buttons to the left of the control panel. They are marked as a Bell symbol (Alarm) , and a steaming Cooking Pot (Start of Cooking Time). Then immediately press the plus “+” or minus “-“ buttons to increase or decrease the time displayed. When the desired time has been reached, leave it for a few seconds, and it will remain set at this time. Any further changes to the displayed time will require this procedure to be repeated.
Hope this helps!
Oct 10, 2007 | Ovens
Ovens Logo
18 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
