Question about Refrigerators
Hotpoint iced diamond door seal
Door seal on my Hotpoint under unit freezer is not sealing at the bottom.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,632 Answers
Replace o ring
Posted on Dec 29, 2013
5 Suggested Answers
rickead1
  • 1998 Answers
SOURCE: I am wanting to replace
contact this company here http://www.allbrandonline.com/ you will be able to order your door seals from this company and they will mail them to you 1800-252-7500 is there number also remember after you install the seals to coat the seals with petroleum jelly or vaseline and leave the door of the freezer closed for at least 3 hours this causes the door seal to mold properly and keep the proper suction to make sure the door stays snug and grabs onto the frame if you have any questions message me back and please remember to rank how this opinion has helped it allows me to continue helping people in similar situations in the future on this site Thanks again Rick
Posted on Apr 30, 2011
  • 2006 Answers
SOURCE: I have a Maytag Refrigerator
Yes, it can Part Number AP4071093 and sells for $60.31.
If you take a look at this web site http://www.appliancepartspros.com/partsearch/model.aspx?model_id=44880&diagram_id=28491053#d28491053 it also has an equipment layout for the entire refrigerator with part numbers.
I am NOT saying you should order the part from here, but it is the only site that I have found that has the parts layout like this. NOTE: I have had good luck with this site, as far as getting the right part in a timely manner.
Posted on Jun 07, 2011
  • 19 Answers
SOURCE: Hi, my hotpoint fridge/freezer FF187E its my
sometimes its just easer to replace the defrost termination thermostat get a 55F for about 15.00 bucks and just change it, if it works thats the problem, if not, it may be the element or defrost timer
Posted on Mar 13, 2012
  • 19 Answers
SOURCE: frost developing around door of freezer in my ss built-in ge refrigerator
look for a mullion heater switch and turn it on, this heats the door frame and does not let it get so cold, it could also be called an Economicle switch or an exterior water control switch
Posted on Mar 14, 2012
I have a hotpoint ice diamond model rfa51p and alot pf water is on the fridge what would this to happen
Freezer /fridge water/ice in fridge and or freezer
Usually due to CONDENSATION due to bad door seals or a plugged evaporator drain line? Can use a soft flexable tubing and very hot water to clean it out. Bad door seals usually need replacement, but u can use a blow dryer and something to pry it closer to the door wall while blowing hot air on to it. To create a seal, to test for bad door seals place a dollar bill in between the door and wall of fridge where it closes. Then slide out the dollar bill with door closed. It should offer some resistance and not be easy to pull out.
Most all fridges have a drain. Look inside your fridge for a "V" shaped channel with a small hole. This hole leads to a tube and a small pan which sits on top of your refrigerator's compressor. The defrost cycle causes water to run into the channel, down the tube, and then it generally evaporates with the heat of the hot condenser/compressor.
However, if that tube is clogged with food crumbs, particles , debris etc, you will have to clear it to get back to a normal mode of operation. A toothpick, pipecleaner, straw or a cotton bud can often do the trick. Another trick one can use is to connect a copper tube wire with one end going into the drain hole then attach the other end to the heater wrap it around heater a few times. That will take care of the drain problem when it comes to ice build up but not food build up.
Even a frost free freezer will still ice up at times in the areas away from the heated defrost area and the drain line can freeze. This icing causes the pipe work to the compressor to ice over or sweat and cause a puddle. Or if the drainage has frozen over, it will need to be de-iced. ( usually the line is under the freezer bottom plate covering. Towards the back of the unit) And there is another inside the fridge area also.
Give the freezer a good overnight defrost until it's totally clear of ice in addition to making sure the drain is clear to the pan at the back and then restart the freezer.
God is so good: so this is why I give free advice so please thank him not me.
Apr 20, 2015 | Hotpoint Refrigerators
I have a hotpoint ice diamond rfa51p and alot of water fills the fridge what causes this?
Is this a common problem?
THATS BECAUSE IN ORDER TO CONTROL BOTH TEMPS IT USES THE HELP FROM THE FREEZER AND FRIDGE THERMISTORS AND THE COLD CONTROL THERMOSTAT. A BAD DOOR SEAL OR SEALS CAN ALSO CAUSE SOMEWHAT SAME ISSUE? ALSO NEED TO CHECK UR DAMPER CONTROL MAKE SURE ITS WORKING CORRECTLY.
Jul 29, 2014 | Hotpoint Refrigerators
I need to replace the rubber seal on my Hotpoint ice diamond freezer door I can't find any fixing screws on the inner door panel can I assume then that the panel clips on.
Me too, I have a Hotpoint Iced Diamond Under counter fridge that needs a new seal and i also cant see any fixings to remove it. I did read somewhere that you can't replace them you need to buy a complete new door.
Dec 14, 2010 | Hotpoint HTS16HBR Top Freezer Refrigerator
Hotpoint ice dispenser door not sealing
clean with white vinegar to remove lime deposit.
flapper may have got bent, bend back or replace flapper.
Sep 24, 2009 | Hotpoint HSS25GFP Side by Side...
Ice collecting under bottom of Freezer drawer/ seal round door intact/ food staying frozen/ Ice is cleared periodically but then builds up again
Your defrost drain hole is clogged. Look for the drain hole in the bottom rear of the freezer section. Turn off the fridge. Heat the drain hole with a hair dryer and clear the ice. Pour a quarter cup of bleach into the hole.
Jul 04, 2009 | Hotpoint Freezers
Ice in my fridge
Without seeing this I can't tell you a price or exact fault but the first free thing to try that could likely fix it. unplug the unit from the power and leave both the doors open for 48hrs so the unit is 100% defrosted then try again. cheers.
May 31, 2009 | Hotpoint RFA60 Bottom Freezer Refrigerator
Froozen doors
Hi!!! It seems that you have a thermostat problem..Does the unit ever turn off?It should..Make sure that the doors close properly because if you have an open coor the ice froms inside ,check your door gasket make sure they seal good..Good luck..
Jan 03, 2009 | Hotpoint FFA60 Bottom Freezer Refrigerator
Condensation on base of Hotpoint R134a upright freezer
sounds as tho you have an insulation breakdown. no repair except to refoam - and that is difficult to do
Aug 09, 2008 | Hotpoint 3.6 cu. ft. / 102 liter Upright...
Refrigerators Logo
155 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
