Fan comes on but the compressor dosnt on my lwhd1800ry7
Water spill on laptop
do a petrol wash to ur motherboard if den also it dosnt work den may be ur ic's or bios has burnt up try to go to service repair if den also it dosnt work den i m sorry u hve to get one new one.u should have to remove the battery immediately when water spoiled up
Jun 22, 2013 | Computers & Internet
2000 vw beetle a/c isnt cooling with compressor running
make sure low side pressure drops other wise the valves in the compressor are shot, meaning a new compressor is in your future.....
Mar 30, 2012 | 2000 Volkswagen Beetle
The air conditioner is on but is not cooling the fan turns on and all but it dosnt cool
possible causes thermostat stuck open/ compressor not working problems related to compressor may be capicitor or the compressor itself.
Aug 21, 2010 | Fedders Q Chassis A6Q10F2A Air Conditioner
Fan runs but dosnt blow cold air
You need to check the condenser fan and compressor to see if they are running. Check any fuses or breakers for them. If the breakers/fuses are good then check the contactor. If that's ok the check the capacitor(s) for them. Let me know what you find.
Jul 28, 2010 | Dometic Rooftop RV Air Conditioner
Neither A/C compressor or fan coming on in ouside unit.
The bulge is a telltale sign of a defective capacitor along with the tripped breaker. Replace it and cross your fingers.
Jun 21, 2010 | Carrier 38CKC036 Air Conditioner
1994 buick paqrk avaune fan dosnt come on
the cooling fan will only run when the vehicle reaches a certain temperature around 100 degrees Celsius. it does this using a temperature switch (usually the coolant temp sensor or a temperature switch located on the radiator). the switch sends power to a relay in the engine compartment (should be marked or you can trace the wires from the fan directly to it). the relay, when activated, sends power to the fan. you should be able to figure it out using a test light. check fuses first though. probably a bad temperature switch. if you do not know how to figure out this problem with the information provided you should probably have a technician check it out for you.
Mar 23, 2010 | 1994 Buick Park Avenue
A/c compressor hums
The compressor may be fine after setting off or a day. After retyring it then if it still dosnt start either replace the run capacitor to the compressor and fan motor or have it checked to see if it is in range.
The hum your hearing could that be the contactor relay humming?
May 15, 2009 | Goodman CKL60AR60 Air Conditioner
Whirlpool et1fttxkqoo refrigerator compressor dosnt kick in
First Check the voltage to the compressor. Usually just 2 wires. If you do not have voltage and you are sure it should be running (it is turned on and plugged in) Check the controller (thermostat or Sensor/board assembly) because your problem is not with the compressor as of yet.
Assuming you have power to the compressor and the fan motor there is running up to speed the coils under neath are clean here are the items to look for to check out your compressor:
Getting to this step: Either your compressor is broken inside or the start components are not working properly. Ohm the compressor terminals to ground and across to each other.
If any read anything to ground the compressor is bad.
Your readings between the compressor terminals should all be different and you should have 1 low 1 medium and 1 high resistance reading.
Add the low and mid reading together and the sum should be close to the highest reading. If it reads say 20% more or less then retest it a couple of times to confirm your not slipping on the terminals.
Assuming the above checks out: Get a new Start relay (start capacitor if so equipped) relay and overload (and capacitor if it has one) In other words everything that is external and attached to the wires or terminals on the compressor, and replace them on to the compressor. Then if it starts problem solved if it still does same thing the compressor is bad (broken mechanically inside the compressor) and you have to decide to replace compressor or replace the refrigerating compressor be it AC or Refrigeration.
A few times I have gotten a compressor to start after leaving it off for 6 to 12 hours then retrying it. See the compressor unless left off for 6 to 12 hours and sometimes as long as 24 hours Is tight due to linear expansion from heat. And about 1/2 the time it is ok after new start components are installed. The other 1/2 the compressor will be ok for a day or 2 then stop again. Most likely from a “hard spot” in the movement of the internal parts in the compressor.
30 years of doing refrigeration and this has not changed.
Please rate me as high as you can and ask me to clarify anything you don’t understand.
Jan 18, 2009 | Whirlpool ET1FHMXLQ / ET1FHMXLT Top...
2000 oldsmobile silhoutte
their is a radiator fan switch or coolent temp sensor that cuts it on possibly a relay but first unplug the sensor fans should turn on if not possible it has a bad fan motor
Jul 22, 2008 | 2000 Oldsmobile Silhouette
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
