Zennox turntable arm keeps lifting mid song - Audio Players & Recorders
  • 222 Answers
SOURCE: Haven't used the turntable in years. Went to use
If this is a belt driven turntable, then you have to replace the belt, as this units gets old the belts loosen up as well.
Posted on Aug 21, 2010
tbreeze47
  • 3083 Answers
SOURCE: The turntable on my CR245
Haven't worked on one of these, but there is an end of travel arm sensor that needs adjustment, or is possible broken. You will have to get inside to check it out, and adjust or fix it.
If you don't feel comfortable fixing it yourself, contact Crosley support:
http://www.crosleyradio.com/supportForm.aspx
Good luck, and hope this helps.
Posted on Feb 03, 2011
STYLUSCITY
  • 271 Answers
SOURCE: zennox usb turntable arm rises before end of record
Hi, we don't have that model turntable in NZ so I can't say exactly where the adjustment for the tone arm lift position is. However on the majority of turntables it will either be beside the base of the tonearm possibly under a rubber grommet or if you remove the rubber platter mat and there is a hole in the platter near the outer edge rotate the platter whilst looking through the hole for a screw near the tonearm. Adjust anti clockwise a little and test. Fine tune until you are happy with where it stops. John. styluscity.com
Posted on Nov 24, 2011
STYLUSCITY
  • 271 Answers
SOURCE: Problem with Auto Return on Thorens Turntable TD 147
Hi, contact me direct and I will send you the service manual. John. styluscity@gmail.com
Posted on Nov 27, 2011
STYLUSCITY
  • 271 Answers
SOURCE: my denon 26-f turntable stylus arm lifts about 2 minutes before end of record. how can this be adjusted on the turntable?
Hi Richard, at the base of the tonearm look for a rubber grommet. Under it you will find a screw. Adjust clockwise slightly to make the tonearm lift further along. Fine tune antil sorted. If the adjustment is not at tonearm base remove the rubber platter mat. If the platter has an access hole in it rotate platter so the hole is near the tonearm and look for scew to adjust. John styluscity.com
Posted on Nov 30, 2011
The needle arm won't lift and go to the record
Pull the turntable off the mount and look at the loading mechanism, I will bet you will find a broken piece.
Jul 01, 2016 | Audio Players & Recorders
Zennox usb turntable arm rises before end of record
Nov 24, 2011 | Audio Players & Recorders
Tone arm keeps returning to rest on Crosley CR249
Hi, Try this. with it turned off. Lift tone arm across a record to the run out groove and set it down. Now power up and hopefully it will reset itself. In all honesty I would sell it and get a decent old school player. John. Styluscity.com
Nov 09, 2011 | Crosley 0187SST Turntable
IT turntable will not play the entire song on 45 rpm for converting to MP3. The stylus automatically lifts up from the record before the entire song has played.
If you're mechanically inclined and can open up the case, then look inside the mechanism, oil it, and put the case back together again, this is what may be happening.
There's a mechanical sensor/actuator inside the turntable that gets pushed by the pick up arm as it travels and nears the center of the turntable. Chances are it may have been set to actuate too early, or it may need oiling, if this is an old turntable that's been lying around unused for several years.
This sensor usually consists of a thin metal plate that can be bent manualy or with a pair of plyers.
Remove the stylus or pickup head, or protect it from damage by using a probable built-in cover. Diassemble the turntable so that the flat surface holding the turning plate can be separated from the case.
Set the disassembled turntable with one edge over some piece of furniture or anything to prop it up while you watch what happens as you move the arm towards the center. You may need to recruit a helper who will turn the plate slowly and move the arm inwards while you watch from underneath.
You will eventually see some part making contact with another, which in turns engages the mechanism that lifts the arm.
Bend this tang just enough to allow the arm to travel further towards the center the necessary distance as to completely play the 45s.
Reassamble the case and try a few records. This will be a trial and error process. Keep making adjustments as needed.
If all of them play to your satisfaction, then you may tighten the screws securely.
Aug 24, 2009 | Audio Players & Recorders
Tonearm lifter in UP position - how to fix
I have also had this problem with the same model turntable. I opened mine up and the problem seems to have been that the grease on the arm lift and cueing lever was gumming up the linkage between the two. (I suspect that my turntable hadn't been used in some time.) I managed to free up the parts by manually working the the arm lift (pressing it down) several times. I'm not sure that I needed to open up the chasis for this fix but it did help me to see what was going on. Good luck with yours.
Tim Orange
Mar 20, 2009 | Technics SL-BD20D Turntable
Turntable starts playing record middle 1st song
The tonearm lift is no longer level as it should be and the arm is sliding along it under gravity as the arm lowers to the record. Has it received a knock?
Have a close look to see whether it has been tilted slightly. That would be enough to give the problem.
Jan 24, 2009 | Kenwood KD-291RC Turntable
Tone Arm skips past first song
Hello, A. Do not try to close the case when there is a record inside!! The fact that the turntable cannot do this is not a design flaw--you'll be hard pressed to find a portable turntable that can close with a record inside because if you were to pick up the player with one inside, it could easily slip off of the spindle and scratch against the sides of the player.
B. Are you using the cueing lever to lift the tone arm before you place it on the record? Read the instructions to see where the cuing lever is (it's a little switch on the right side of the tone arm). When you lift it, the tone arm will lift up and allow you to position it wherever you want on a record, then you depress the lever to make the tone arm touch the record and being playing.
I hope that helps!
Jan 04, 2009 | Crosley CR249TA Turntable
Audio Technica AT-PL50 Stereo full automatic turntable system
Try pushing the button on the far right. I had this same problem last night before I released the button was in the wrong position. It is called the "Lift" button and when depressed it lifts the needle up from the record- or keeps it raised and never lets it come down.
Sep 01, 2008 | Audio Technica AT-PL50 Turntable
Marantz TT221 turntable anti-skating problem
Hi, sounds more like tje stylus tip is gone and therefore the needle isn't holding to the grooves rather than a tracking weight or anti skate problem. Styluscity@gmail.com
Mar 27, 2008 | Marantz Reference TT-15S1 Turntable
35 people viewed this question
 Grubhead
Grubhead
