Question about Salton Elec Food Warmer Warming Hot Tray + Drawer H934
Power lead Where can I buy apower lead for this unit
    New Friend:
I need a power cable for a dalton hot ray 3030
Posted on Dec 16, 2013
Power supply green light comes on but unit does not power up.
When you say 'checked leads' does this mean you checked to see if they were firmly plugged in? or that there was power on the power leads... If there is power, you probably have a 'smoked' drive. If no power on the leads more than likely a blown fuse in your power supply.
May 03, 2015 | Power Computers & Internet
Charge led on pl70 usb charge lead won't illuminate at all
Most likely the actual charger unit has failed and is not supplying power to the cable or LED, therefore no charging will be possible. Buy a new charger unit.
Aug 11, 2014 | Samsung Pl70 Silver
The power lead on my nakamichi dr3 is cut, how do I fix it?
If the power cable goes inside the unit, then all you need to do is open up the unit and trace back the wire to where it connects. It will only be soldered on. You can buy a suitable power cable from most electrical stores.
Mar 18, 2014 | Nakamichi Audio Players & Recorders
Trying to install as slave. check disc checks it then computer stops???
since you have been connecting another hard drive and plugging the leads in/out
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your motherboard to your hard drive make sure they have a secure connection
i would also suggest you buy another PSU power supply unit preferably a heavy duty one with plenty of wattage when you add more devices ram,hard drives,cd/dvd recorders it drains more power from the power supply unit placing more strain on your computers PSU
and are not faulty or just replace them there probably old and faulty
Nov 30, 2010 | Maxtor DiamondMax 16 80 GB Hard Drive
Need green power light on
After you have ensured lead is secure and power poin work.....Most of the time on these it is the power pack, that goes, if I have the right model these dont just have a lead they have a box that goes on power cord, I being a teco, normally check for correct voltage and current coming from power supply with a multimeter....either way if is has external or inbuilt power supply that is where the issue will be, and they are not repairable units, one just replaces the whole module or most times customers just faint at expense and go and buy new. I'd quote $99 aus + parts.... or if external you can buy another from HP itself, they have a 131 number but you will be talking to non english understanding help support, great fun...
Nov 07, 2009 | HP DeskJet 5150 InkJet Printer
Dell latitude d600 purchased in USA WHAT do i need to make it work in UK POWER PLUG NOT AS IN UK thank you
if its a round 3 pin and it plugs into a power unit 3 spade type plug end, using a plug like the one that goes into an electic kettle, just buy a kettle lead and use that.
If the power unit itself is not 240 volt you can buy a universal charger/power unit from maplins or similair, but check the wattage
http://www.maplin.co.uk/Search.aspx?criteria=laptop%20power&source=15&SD=Y
Aug 23, 2008 | Computers & Internet
I have a KRC 585 car audio unit. Power getting to player but it will not switch on.
Try finding a solid ground and make sure theres not only a hot lead but also an ignition lead. If that doesn't work, you might have to a stereo shop look at it. Wait until best buy offers a coupon, usually every 4 months.
Aug 07, 2008 | Kenwood Car Audio & Video
Freezer temp
either stat is bad or charge is low. bypassing stat will achieve desires temp. if not then charge is low. if charge is low then buy new. if compressor valves are bad then buy new. to expensive to fix these days. new is cheaper. good luck. stat is power lead in , power lead out. kill power then tie em together to get constant on. be sure yor thermometor is good. i just spent 20000 dollars fixing ref at a hospital, only to find there thermometors were bad! good luck.
Jul 29, 2008 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Mains lead
If this was in the box when buy you can contact Lexmark and get it replaced for free the main chord or if want you can buy the power chord online:
Use this link :
http://support.lexmark.com/cgi-perl/selections.cgi?ccs=229:1:0:-1:0:0&target=http://support.lexmark.com/cgi-perl/support.cgi&&req=:::-1::
Jun 21, 2008 | Lexmark Z1420 InkJet Photo Printer
Salton Elec Food Warmer Warming Hot Tray + Drawer H934 Logo
98 people viewed this question
Top Salton Kitchen Appliances - Others Experts
fixzum
Level 1 Expert
Kolbrun...
Gareth Cockram
Gareth Cockram
Are you a Salton Kitchen Appliances - Other Expert? Answer questions, earn points and help others
