Question about HP Compaq Presario CQ40-330TU
Overheat My pc it turn off itself it is overheat
  • HP Master
  • 32,281 Answers
Overheating
When the CPU overheats then it will shut down (i.e. thermal overload) and won't boot up again until it has cooled down. If this is the problem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are clogged with dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make sure the vents are clear and dust free. Use a small brush and can of compressed air to do this.
Posted on May 10, 2013
Turns on and shuts down
It could be several factors. I would start with opening the case side door and blowing out all the dust and making sure the CPU fan is working. If it overheats the PC will turn off to protect itself.
Dec 09, 2013 | Gateway GT5656 Desktop PC
Alien 5620d overheats
PROB BUILD UP OF DUST INSIDE THE MACHINE CAUSING THE VENYS NOT TO WORK GREAT CAUSING THE HEAT TO BUILD UP INSIDE THE MACHINE AND CAUSING IT TO TURN OFF TO PROTECT ITSELF
Mar 19, 2013 | Alienware PC Systems Alienware M17X 173...
Dell pc turns off sometimes for no reason
If the systems overheats, then the pc turns itself off to prevent damage.
Your computer needs to be kept cool. Clean the fans and install more fans if possible.
Take care!
damnor01
Aug 05, 2012 | Dell Computers & Internet
Shuts off by itself
Check the fan to make sure it isn't clogged with dust bunnies or malfunctioning. There's a solid-state thermostat that turns off the computer if the processor overheats.
Mar 08, 2011 | Toshiba Satellite 1135-S1553 Notebook
HP Pavilion dv9000z 17" Notebook Laptop PC PC Notebook: My Hp laptop turned off by itself and wont turn on...
Make sure your Notebook is not overheat if it is then you have to make sure the fan is working and have to work on the NB by placing it on a hard surface and also BIOS update will also help to resolve the issue.
if in case the notebook is not overheating boot to BIOS screen and check if the Notebook turns off by itself in bios if it does then its a hardware issue and you need to contact manufacturer to service the notebook
May 18, 2010 | HP Pavilion dv9000z Notebook
My tohiba satelite A205 turn off by itself why
In this case the problem may be divided in to two 1. Hardware related 2. Software related.
If it is a hardware related issue, you must use a air pump to clear the air vents in the laptop. Sometimes dust accumulation may cause your laptop to overheat and turn off. If this does not work, then probably you must try to run a diagnostics in your system. If the OS in the laptop is provided by the manufacturer then the diagnostics can be found here START--->ALL PROGRAMS--->TOSHIBA--->UTILITIES--->PC Diagnostic
If the diagnostics returns an error then related action must be taken to resolve the issue.
If it is a software related issue then try reinstalling uninstalling the latest softwares you tried to install. It may have caused a conflict in the laptop. Try to clear some hard drive place and reduce the number of simultaneous processes the system is running. Sometimes the system cannot handle multiple processes which causes strain on the processor causing the laptop to overheat or seize functioning temporarily.
If not the last option would be to go for a complete PC restore to take back the laptop to its factory settings before which all the data in the system should be backed up.
Hope this works.
May 02, 2010 | Toshiba Satellite A205-S4617 Notebook
Turns itself off & gets hot -don't think fan is kicking on
Since you do not hear the fan anymore I would start by opening up the case and seeing if power is going to the fan and make sure any connectors for it have not come loose. If the connectors are still hooked up chances are the fan is shot and needs to be replaced.
If you are not familiar with working around electronics and parts under power I would highly suggest you have some one who is familiar with this do it.
May 06, 2009 | Computers & Internet
My laptop turns itself of after 8 minutes - every time i turn my laptop on it lasts for about 8 minutes then turns itself off automatically how do i stop this? I am trying to find drivers for my laptop...
check whether the hiberbnate facility is on or off as it is turning off after 8 min or so.
this can also happen due to overheating of the processor , it can turn off itself automatically
try to increase the ram on the system
http://www.driverfiles.net/Other/NEC/page,level2,866,3,resultpage1.html
Jun 09, 2008 | Computers & Internet
I have adevnt 9912
yes it is possible for a laptop to overheat and turn it self off to keep from damaging itself.
you can also try taking out the battery when you have it plugged into the wall, sometimes that can cuase problems
May 30, 2008 | Computers & Internet
HP Compaq Presario CQ40-330TU Logo
81 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
