Error code 11 on winterhalter GS502?
My machine has stopped working and says this error, is there a fix?
richroth
  • 9472 Answers
SOURCE: My kenmore elite smartwash/he4t
The "F11" fault code will display if the Motor Control Unit (MCU) has an internal failure; repeating under or over voltage, or over current conditions. If failure occurs during high speed spin the door unlocks after 3 minutes. The MCU (Motor Control Unit) is located beside the motor. Here is the part to order.
Posted on Dec 03, 2012
SOURCE: could you please tell me what error codes 21 and 6
error 6 relates to a blocked drain pump. if the drain pump is working ok check if the tank level sensor is operating or if the air chamber in the wash tank is blocked.
error 21 relates to the drain pump being activated. normally related to error 6.
also check water inlet solenoid valve is working correctly. ie not blocked or passing.
all parts of the machine can be activated manually by entering service mode.
when machine is off press service button or switch on main pcb.
p00 appears. press and hold main wash button. --- appears. using the long and short wash buttons you can scroll through parts of the machine. displayed as a01 a02 a03 etc.drain pump is a12 solenoid valve is a13. these are activated by pressing the button. when activating the drain pump the display will count down. this number is the water level in the wash tank. if it's counting down the level sensor is ok.
hope this helps
jarv
Posted on Sep 28, 2010
SOURCE: winterhalter gs502 dishwasher-error code 15?What's
The float switch/level sensor in the rinse boiler has not activated. This could be a faulty solenoid not letting the water in(assuming the isolating valve is turned on), or a faulty float switch/level sensor. This would result in water overflowing through the rinse arms and the overflow in the rear of the wash tank.
Posted on Mar 29, 2011
  • 25 Answers
The F11 code is caused by either a CCU failure or an MCU failure...here\'s how to tell:
If your machine starts a cycle and the water fills but the drum NEVER turns, your MCU is bad...it\'s most cost effective to buy a refurbished one and you can get them on eBay for $99 all day long.
If your machine makes it most of the way through a cycle but throws an F11 code during the rinse or spin, your CCU has the relay solder / vibration problem...
Posted on May 26, 2014
  • 208 Answers
SOURCE: winterhalter gs502 getting cloudy cutlery, glassware and steelware helpp??
Winterhalter has always had boiler sensor issues. The floats will malfunction so they show functional during testing but fail during operation. Replace the float.
Posted on Mar 03, 2016
Winterhalter machine code error 24 and 26
its a drain issue. something is plugged or pump isn't working.
Feb 23, 2017 | Washing Machines
Ld code. It won't drain. Not the drain pump (I changed) and not clogged pipe.
Slow drain code. How high is the outlet pipe ABOVE the machine?
Jan 05, 2016 | Washing Machines
What does error code 35 mean on the winterhalter dishwasher
Error 15 = on the GS502/515 is a Main Water Stop Valve Blocked or Closed
Apr 28, 2015 | Dishwashers
Winterhalter error codes 23
Call customer support
Jul 07, 2014 | Dishwashers
Winterhalter gs502 and getting error 11
Klix-on on motor has failed. (This is often due to overheat) Clear dust and dirt from around motor to restore cooling may be the answer. .
www.cearcommercial.co.uk/.../winterhalter/winterhalter-wps-reminder-er...
May 21, 2014 | Dishwashers
WHAT DOES ERROR CODE 6 MEAN
I'm thinking the drain is plugged. Good Luck.
Nov 24, 2013 | Washing Machines
Winterhalter gs 302 error Code 15
haw can i chainge a float switch on a winterhalter gs302 ?
please any one can hellp
Mar 17, 2013 | Dishwashers
Winterhalter gs502 dishwasher-error code 15?What's mean fault code 15?
Mar 18, 2011 | Dishwashers
Could you please tell me what error codes 21 and 6 relate to on a Winterhalter GS502 dishwasher. Many thanks. Barry CER
hope this helps
jarv
Mar 29, 2010 | Dishwashers
Washing Machines Logo
535 people viewed this question
Top Washing Machines Experts
