Question about 1A Auto Parts 1990-1992 VW Golf Starter for 2.0L for cars built in Mexico 1/90-4/90
Vw golf starter motor
I have a golf mk3 just repaired crown wheel and pinion when i fitted the starter and tried to start solenoid kicks forward but does not swing the flywheel, pls help
    Top Expert:
  • 1A Auto Parts Master
  • 42,818 Answers
Check condition of battery. Have a load test done to test for dead cell. Remove battery terminals and clean both posts and terminals with sandpaper until you see shiny metal. Check and tighten all terminals to the starter.
Posted on May 10, 2013
My truck starter seems to run but does not crank motor-just hums then stops. New cables ,battery, solenoid have been installed? It will crank over if I throw my engine starter on it. But the batery has...
are you sure you got a good solenoid?souds like it's not kicking the starter bendix out for the start.if it hums that means it's turning right? it has to be the solenoid not kicking the starter bendix into the flywheel to start the engine.i would try another solenoid. thank you for choosing fixya.com
Jan 10, 2011 | 1981 Ford F 100
My car is having trouble starting up the starter is making fkat buzzing sound any ideas?
Sounds like a slipping pinion gear. Remove starter solenoid assembly and put on the kitchen table, old newspapers for protection are optional. The pinion gear is the one on the end of the starter motor shaft that is driven forward to engage with e toothed edge of the flywheel. It should free wheel in one direction and lock solid when reversed. The locking clutch mechanism its what supplies the motor's rotation to the flywheel to crank the engine over. If the pinion gear clutch is slipping the motor makes a whizzing sound as the shaft spins within it. You can buy a new pinion gear cheaply. Whilst the motor is out buy a refurbishment kit ($10) for the solenoid consisting of contact striker plates and plunger . This preventative measure will avoid any hassle in this department for many years.
Sep 27, 2010 | 2004 Ford F150
2001 Ford F350 SuperDuty, Starts intermitently. Will start but then won't start the next time just a click at the starter relay.
I have also suffered this problem. The starter motor has a component called BENDEX. It is the part that pushes the starting pinion forward and backward so that it engages with the flywheel when you want to start. And when you release the starter, it retracts the pinion and it disengages from the flywheel. As the flywheel is much larger than the pinion, if it does not disengage the starter motor will get burnt as it would be subjected to a very high RPM by the flywheel. So, get the bendex repaired. If it can not be repaired for some reason then replace with a new one.
Aug 24, 2010 | 2001 Ford F350 Super Duty SuperCab
1995 VW polo 1300cc -no start, engine not turning good battery recon starter motor fitted(tested & working inc solenoid).any advice or ideas?thanks Lionel...
CHECK STARTER RELAY AND FUSE.REPLACE BATTERY CABLES IF YOU HAD THEM FOR A LONG WHILE.BECAUSE GROUND CABLE COULD BE BAD.TURN OFF RADIO FIRST BEFORE REMOVING BATTERY CABLES SO YOU WONT LOSE RADIO CODE.
Apr 21, 2010 | 1995 Volkswagen Golf
Golf sometimes no power to starter motor
I would check the ignition switch. You can unplug the small wire at the starter, with a test light check and see if power is at the plug when you turn the key to the start postion. If there is power there, you may have a bad starter solenoid. I've had to replace a few on my VW, (86 Scirocco, 91 Jetta GLI)
Mar 12, 2010 | 1997 Volkswagen Golf
Vw polo 1.4 petrol stater just clicks
your starter relay has probley u/s
Mar 30, 2009 | 1999 Volkswagen Golf
Starting problem with 1995 VW Golf TDi
if there is a clicking noise, its probably the solenoid on the starter. that unit pushes the starter motor forward and also connects the live of the starter.
Mar 21, 2009 | 1995 Volkswagen Golf
VW Golf maintenance instructions
www.ebookmanual.net/vw-golf-jetta-service-and-repair-manual.html
Dec 14, 2008 | 1997 Volkswagen Golf
1A Auto Parts 1990-1992 VW Golf Starter for 2.0L for cars built in Mexico 1/90-4/90 Logo
279 people viewed this question
Top 1A Auto Parts Golf Experts
FastHarley
FastHarley
ray gallant
Ronald Prier
Are you a 1A Auto Parts Golf Expert? Answer questions, earn points and help others
