Dirt Devil KURV Hand Vacuum Champagne Vacuum Logo
Posted on Mar 17, 2009
My new Dirt devil kurv hand vac will not open to empty the dirt cup. Unit will not twist open...
5 Related Answers
Anonymous
  • 1673 Answers
  • Posted on Mar 24, 2008
SOURCE: Roller on Dirt Devil hand vac won't turn
Usually the ends will pull off so you can clean them. If not, then you will have to replace it.
Anonymous
  • 310 Answers
  • Posted on Jun 11, 2008
SOURCE: Instruction Manual needed for Dirt Devil upright model 088305
http://geeksquad.fixya.com/ThreadView.aspx?prdid=89362&thid=642772
Instruction Manual needed for Dirt Devil upright...
Posted by Innahouse on Jun 03, 2008
Describe your problem I need an instruction manual for a Dirt Devil upright model 088305.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Dirt Devil Model #M088300 Upright Vacuum. The best idea is to contact the Royal Customer Service Dept and give them the model 3 and serial 3 of the unit you are requesting the owner’s manual for, I will give you the website address and phone # listed below:
So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://royalvacuums.com/ Customer Service 1-800-321-1134
Hours are: 8:00 AM to 7:00 PM (EST)
Thanks, Don the Vac Man
Go Ahead. Use Us.
advacak
Denny Adams
  • 125 Answers
  • Posted on Dec 16, 2008
SOURCE: dirt devil vacuum spits out dirt
its a design flaw that cant be fixed
Anonymous
  • 229 Answers
  • Posted on Jan 18, 2009
SOURCE: I can't seem to empty
If it is the same as mine you have to remove the dust filter and then remove or empty the bin. Hope this helps.
Robert Pagliaroli
  • 294 Answers
  • Posted on Jan 21, 2009
SOURCE: how do i open my
remove vac from charging base. twist the two section apart. it will turn about 1 inch and then pull apart. this will expose the filter to remove to empty the dirt. reassemble in reverse.
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_b96ba3f038cf317c
How do you empty it?
http://www.homedepot.com/catalog/pdfimages/e1/e1548aa7-3a91-42bc-b2c0-1b405ef54686.pdf
This owners manual shows you how to empty. If you dont have access to Internet:
1. Depress the dirt cup release button and pull nozzle away from unit.
2. Hold nozzle over a wastebasket, Grasp filter and gently pull out.
3. Shake excess dirt and debris out of dirt cup. Brush the dust and dirt off the filter or shake inside the wastebasket. IMPORTANT do not wash filter.
4. Gently push the filter back into the dirt cup.
5. To reattach dirt cup: Align bottom first and rotate nozzle up until it snaps into place.
Good luck.
How to replace filter
Hello! Happy to help with that. To replace the filter simply twist the dirt cup lid off of the dirt cup. Remove the old filter and replace with the new one. Twist and lock the dirt cup lid back on. This vacuum takes a Dirt Devil F1 filter. Follow the link below to purchase the filter directly from dirtdevil.com. Thanks!
F1 HEPA Filter
How to open dirt devil kurv
Hi! To access the dirt cup and filter first remove the dirt cup from charger stand. Then twist the dirt cup to remove. Grab filter tab and lift up to remove from dirt cup. Twist filter to remove from adaptor. Any disassembly beyond this point is not recommended. Hope this helps!
How do i clean canister of dirt devil featherlight bagless caniter vacuum
Hi there! To clean the canister or dirt cup, first remove the dirt cup from the vacuum. Twist off the dirt cup lid. Remove the pleated filter and empty the dirt cup. Tap the filter against the trash can until the dirt stops falling. If the filter is really dirty it may need to be replaced. The filter should be replaced every 6 months. I have included a link where you may go to purchase a replacement filter if needed.
Thanks! Hope this helps!
F1 HEPA Filter
How to replace batteries for dirt devil kurv
Need to buy new sub-c 1.2 V Ni-Cd battery and solder them in. I did it and it was moderately difficult - especially since the unit was not designed for this repair - you will most likely crack the housing try to dis-assemble. I have lots of experience in electrical repair, and I would not recommend the effort unless you like this kind of stuff.
1helpful
2answers
Can't get it open to empty it! Help
1. Remove the unit from the base.
2. Twist the top clockwise to separate the two halves.
3. Grasp the filter tab to lift it up.
4. Empty filter, replace, reassemble.
There is a black clip at the top of the dirt cup which holds the dirt cup in place on this vacuum. Pull back on this clip with one hand and with the other you will be able to remove the entire dirt cup assembly. Once the dirt cup assembly is off remove the lid, and take the bottom portion to the trash can and dump. Tap the side of the cup slightly to remove excess dirt. Romove the dirt cup filter inside and do the same. Replace the fiter and the lid and put it back on to the machine. You should replace the dirt cup filter every 6 months to a year. Part is below:
F1 Dirt Devil Replacement HEPA Filter Style F1, Dirt Devil Part 3-JC0280-000 Cost $ 15.95
How to clean the fan
best way with any vac.is to blow it out.
Change filter kurv dirtdevil
remove unit off base. twist handle from suction nozzle, it will separate.
6helpful
How do i open my dirt devil kone to empty it?
Top Dirt Devil Vacuums Experts
Mike Cairns
Mike Cairns
Paul Bade
NOEL
NOEL
Are you a Dirt Devil Vacuum Expert? Answer questions, earn points and help others
