E355 error code E355-0004
3 Suggested Answers
PATHAMPAD
  • 25 Answers
SOURCE: Error Code E000001-0004
The main thermistor TH1 has poor contact or open circuit.The thermal switch TP1 has an open circuit.The fixing heater has an open circuit.The SSR is faulty or the DC controller PCB.After the main power switch is turned ON the temperature detected by the main thermistor does not reach 70 C.The error must be reset in service mode :COPIER - FUNCTION - CLEAR - ERR
Posted on Feb 13, 2010
  • 149 Answers
SOURCE: What is error code E000001-0004 and E000001-0010 f...
there is a good possibility that the main thermistor and the sub thermistor has gone bad or is dirty. also it might need adjusted to be better placed next to the upper fixing roller
Posted on Jun 11, 2010
How can i solve e355-0005 error code for canon ir2202 copier
If you wish to get some details; check the site linked here. Pull up older posts......
http://electro-medical.blogspot.com/
Apr 14, 2016 | Canon Office Equipment & Supplies
How can i fix the errore e355-0004 in canon ir 2202 copier
If you wish to get some details; check the site linked here. Pull up older posts.........
May 02, 2015 | Canon Office Equipment & Supplies
Bagaimana cara mereset e355 mesin Photo Copy IR 5000??
i has cland this error but can't go to OK but don't move......E355-03 it's error
Feb 28, 2014 | Office Equipment & Supplies
Canon ImageRUNNER 3235 error code E000804-0004
Canon ImageRUNNER 3235 error code E000804-0004.. Solution for this error code is to replace the cooling fan.
Apr 24, 2013 | Canon ImageRUNNER 3235 Black and White...
Hi canon IR 1510 error E 355 what is it? Please help me
Hi
On general canon machines error code of E355 indicates, 'When turning on the power, inconsistency among the serial No. PCB, the controller PCB (SRAM), and the counter memory PCB is detected.'
If this helps?
Jan 19, 2011 | Canon iR 2016i Black and White Copier
Ir3200 error code e000677-0004 -
hi,
error code e000677-0004 is a print server error:
Remedy : Check power supply to the CPU Fan.
2. Replace the CPU Fan.
Oct 25, 2010 | Canon imageRUNNER C3200 Copier
I have problem canon ir 5000 e355,,....please help me
How to clear the error code:
1. Enter Service Mode: Press * Additional Functions, 2&8 simultaneously, then * Additional Functions again.
2. Then select the [COPIER] option. Under [COPIER], select the Function tab.
3. Under the [FUNCTION] tab, select the [CLEAR] option.
4. In [CLEAR] there is a selection E355-CLR. Select it and hit OK.
5. Reboot the machine.
If the error occurs again:
1. Make sure the connection is secure and tight to the Main-Controller board from the connector cable to the Serial Number board below.
2. Reseat the Main-Controller board into its slot.
3. Go into service mode and clear the error code as explained above.
* If the error still continues, you probably have a bad Serial Number board and it needs to be replaced.
Aug 27, 2010 | Canon imageRUNNER 5000 Copier
Aftter my photocopy is bootting .its fail with error code E355=001
try to reset the error code enter the simulation press * then press simultaneous2,8,then press again * then press copier then function,clear,err, OK then off/on
Feb 01, 2010 | Canon imageRUNNER 5570 Copier
E355 0001 E604 0000 E020 4b00
You should really be more detailed than that.
E020 is a drum code, magenta if i am correct. Replace that and that should take care of that one.
E604 i believe is the finisher (going from memory). Haven't seen a E355.
If you are having this many error codes, call a canon technician. it could be something that connects the 3.
Nov 15, 2009 | Canon imageRUNNER C3200 Copier
Toshiba e355. Wireless?
"Certain Pocket PC Models have SD or SDIO slots but are not compatible with the SDIO WLAN Card. These include: Toshiba e350 and e750 – these have SDIO slots but do not have SDIO Now! software from BSQUARE. The e355 is the same as the e350.
Sep 11, 2005 | Toshiba e355 Pocket PC
41 people viewed this question
jasbo
jasbo
