Question about Neff 23 in. T2646 Gas Cooktop
Ignition fault neff bosch - Neff 23 in. T2646 Gas Cooktop
Induction hob neff T4243 has cracked will I need to replace it
Did you crack your hob by means of impact or did it happen on its own accord?
I have a neff induction hob and has just cracked in 3 directions while cooking this evening. I am just trying to determine if there is a common fault with this neff product or I am just unfortunate. Mine is under warranty and have a engineer coming on Monday, so have the whole weekend with no hob as I have been advised not to use it.
Many thanks
Feb 28, 2012 | Cooktops
Bosch gas stove top ignitors continue to fire on two of the burner when unit plugged in. Any thoughts?
Hi tiggerwillso,
I believe your ignition switches have come in to contact with either water or moisture.
Please read my below Tip on how to fix the problem:
GAS KITCHEN APPLIANCE CLICKING SOUND...
If it does not solve your problem, I'd suggest replacing the ignition switches.
Kind Regards
JEDEMEYER1
* If you found this solution helpful, please rate it
Aug 01, 2011 | Bosch Cooktops
Neff hobb, ignition continuously sparking
igniton control module is bad or one of the switches is arched together on the inside of the switch requireing if it were arched together you to buy a new switch if you have any further questions please message me back and please remember to rank how this opinion has helped in your appliace situation Thanks again
Rick
Dec 14, 2010 | Neff Cooktops
Neff gas hob on T2124 not lightin when turning on ignition.
make sure you have gas to the hob then make sure all the rings are clean and not blocked and that the ignition electrodes are clean
Dec 09, 2010 | Neff 22 in. T2124 Gas Cooktop
My bosch gas top spark lighter doesn't work on any burner...how do I fix it?
Here is a tip that I wrote to help people troubleshoot problems with their cooktops not igniting.
Cooktop Range Stove spark ignition does not work
http://www.fixya.com/support/r5649407-cooktop_range_stove_spark_ignition_not
heatman101
Apr 21, 2010 | Bosch 30 in. NGP 732 / 736 Gas Cooktop
Ignition on centre burner keeps tripping, how do I
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair Burners Keep on Clicking
http://www.fixya.com/support/r4033033-gas_range_repair_burners_keep_clicking
heatman101
Mar 25, 2010 | Neff 28 in. T2766 Gas Cooktop
Ignition not firing on a neff hob, gas fine
heatman101
Feb 22, 2010 | Cooktops
Constant ignition clicking on Dacor cooktop
try cutting the power to the stove for half an hour, see if that resets it
regards
Nov 26, 2008 | Neff 28 in. T2764 Gas Cooktop
Neff 23 in. T2646 Gas Cooktop Logo
12 people viewed this question
Top Neff Cooktops Experts
Jim London
Jim London
Samyfam
Samyfam
ray gallant
Are you a Neff Cooktop Expert? Answer questions, earn points and help others
