Import exel product file into website x5 evolution
I want to import product lists created in exel into my website how do I do this I created a csv file but it keeps telling me I have an error in the heading
kpenguin
  • 35 Answers
SOURCE: CSV file to Import correctly into Excel 2003
Rudils,
The key is to import the data and not open the file directly.
1. Open a Blank Workbook in Excel.
2. Data, Get External Data, Import Data. (Excel 2007 is Data, Get External Data, Data from Text)
3. Browse to your .csv file and Select "Import".
4. Import Wizard should appear.
5. Page 1 Select "Delimited"
6. Select the row which you want to start the import.
7. click "Next"
8. In the Delimiters, select "semicolon" and/or other delimiters you are using.
Note: The bottom half of the window will preview the way the data is to be imported.
9. click "Next"
10. highlight each column of your data in the window below. For each column you can specify "General", "Text", "Data", or "do not import column" using the radio buttons in the top left of the Wizard box. This is an optional step.
11. Click Finish.
I hope that helps. Please add a comment if it not clear.
kpenguin
Posted on Nov 22, 2007
mastersaintx
  • 928 Answers
SOURCE: EXEL 2007
This is because 2007 excel uses a different type of file. You may follow the directions at the link below on how to save files in 2007 excel so that you can open it in 2003
http://office.microsoft.com/en-us/excel/HA100141071033.aspx
If there is anything else please do message me.
Posted on Sep 25, 2008
dennisgladx
  • 52 Answers
SOURCE: importing csc files
Hi freaks11,
I am DennisGladx and I hope to assist you.
This sounds like the Column of the data you want should be changed when you import the text file.
Right click on the column letter,
Left click on format cells from the drop down list and select the cell Con-tense you want to display.
Glad to be of assistance
please rate the solution - I can learn from your rating - Thanks
Posted on Oct 29, 2008
SOURCE: converting IIF files from Quick Books Pro 2005 to CSV
Means converting IIF to CSV. Have the IIF, need it in CSV format. Can anyone propose a tool?
Posted on Oct 22, 2010
  • 223 Answers
SOURCE: I am trying to import
Thank you for using FixYa
I am going to attempt to give you some ideas of what may be wrong. I am not an expert in Invoice2go, but you can find one on their web site under support.
http://www.invoice2go.com/supporthome.aspx
Apparently the program is designed to work with Quicken or Quick Books, but may work with others as well, with some finess.
Aside from this I have had experience in transferring information between database programs and it is one of the more difficult things that can be done with software.
First, I suggest that you look at the source file on the hard drive of the origional computer and see what the file size is. It should be more that 2k or so, since that is probably only one page. Also if may be possible to open that file with a word processing program or even the origional program to test it to see if the export actually saved the file.
The second thing I would look at is the delimiters that it defaults to when saving it, seperating the columns or spaces. Sometimes changing it to a tab instead of a comma, or a line return instead of the present format can make a difference. Check the delimiter settings and see if it gives you some other settings and you can experiment with different ones and try saving them and using them.
I hope this was useful and please comment if this was helpful to you.
Posted on Apr 27, 2011
How do I add an email address to "other contacts" in my gmail contacts?
That probably depends upon the 3rd party. You MIGHT try exporting your contacts list (as a .csv, or Comma Separated Values, file). You can then open that file with Excel or OpenOffice Spreadsheet and change it around however you like. Your 3rd party software may be able to import the .csv file, or you may be able to reimport it into gMail and have it automatically rearrange your contacts.
Aug 03, 2014 | Google Gmail
How do I get my gmail contacts transfered to my Microsoft Outlook 7 contacts?
OK
try these steps:
  1. Log on to your Google Gmail account.
  2. In the left column, click Contacts.
  3. On the right side of your screen, above the message count, click Export.
  4. Click Outlook CSV (for import into Outlook clients).
  5. Click Export Contacts.
  6. When prompted to download the export file, click Save.
  7. Choose a location on your computer to temporarily save the file. The default file name is gmail-to-outlook.csv.
NOTE You can delete this file after your contacts are imported into Outlook.
  1. Click Save.
  2. In Outlook, on the File menu, click Import and Export.
  3. Click Import from another program or file, and then click Next.
  4. Click Comma Separated Values (DOS), and then click Next.
  5. In the Import a File box, browse to find the file you downloaded in step 8, and then double-click the file.
  6. Click one of the following:
    • Replace duplicates with items imported
    • Allow duplicates to be created
    • Do not import duplicate items
  7. Click Next.
  8. In the folder list, click the Contacts folder where you want the imported contact information to go, and then click Next.
  9. To add or remove fields to determine the way the contact information is saved in the new imported file, clickMap Custom Fields.
Thanks to:
Microsoft at:
http://office.microsoft.com/en-us/outlook-help/transfer-contacts-between-outlook-and-google-gmail-HA010222048.aspx
Jul 07, 2014 | Microsoft Office Outlook 2007: Windows
Please transfer old account,joeybanta1113@hotmail.com,to new account,joeypanetta2011@gmail.com i need all my contactacks! and my pictures,"please help me"!!!! thank joey panetta
Exporting Hotmail ContactsThe first step is to get the information you need out of Hotmail, you can achieve this by doing the following:-
  1. Select Contacts from the Hotmail navigation bar.
  2. Click On Print View.
  3. Highlight the entire contents of the table (including the heading names e.g. Name, E-Mail and Phone as well as all your contacts).
  4. Press Ctrl+C to copy the table.
  5. Create a new spreadsheet document in Excel.
  6. Select Edit and then Paste from the main menu.
  7. Sort the data by the E-Mail column.
  8. For any rows with a blank E-Mail column copy any e-mail address from the Name column to theE-Mail column.
  9. Read this guide from Google on the format of CSV contact files and make any adjustments as may be necaserry.
  10. Select File and then Save As... from the menu.
  11. Make sure you select a format involving "CSV" for saving the file. (GMail can import csv files)
You should now have a csv file containing all your Hotmail contacts ready for importing into GMail.
Importing Your Hotmail Contacts Into GMailImporting your new contacts file into GMail is really straight forward:-
  1. Select Contacts from the GMail left hand menu.
  2. Select Import from the 3 options at the top right of your list of contacts.
  3. Click Browse to locate your csv file containing your Hotmail contacts.
  4. Click Import.
Jun 27, 2011 | Computers & Internet
I can't find My Advanced Mail List and address book for my MAC. please help......
Here is the skinny, if you cannot find the software but still have your mml file all you have to do is download a dos program to convert your file to a csv, comma separated value file. here is the link to the database providers site:
http://vermontdatabase.com/mymail.htm
the program dbport.exe is in the dbport.zip file.
Download it and unzip it in the same folder that has your mml files in it.
Then run the command dbport.exe e oldfilname.mml newfile.csv
Then open the new csv file with excel or a similar database program that will open csv files.
Then copy all the cells that have your addresses.
Paste them into notepad and then you can cut and paste from there. You can import them into outlook as contacts too. This however means you have to set up the importing correctly.
Jan 02, 2011 | Clickaction MyMailList & AddressBook...
I cannot get my comcast email contacts switched over to verizon. What should I do?
What email program are you using? That will determine where your contacts are stored, and that will determine your options.
If you are using ComCast's Web-based email system (in your Web browser), you'll either need to import them into a local program like Outlook or Outlook Express, or you'll have to talk to ComCast about exporting them to a .csv file. If you can display a list of them in tabular format on the screen, you may be able to copy-and-paste it into an Excel spreadsheet and then save that as a .csv file. If you're already using Outlook or Outlook Express, you should be able to just create the new Verizon mailbox and retain your existing contacts. If you can get them as a .csv file, you can either import that into Outlook or Outlook Express, or you can talk to Verizon about importing it into their Web-based email system.
Jul 21, 2009 | Computers & Internet
Can't import address book into Xerox Workcentre 7345.
The CSV format is below
"*",1,1,2,,
MFDN,MFADDRT,MFCN,MFIKEY,MFVDN,MFLINE,MFFAX,MFRBC,MFCMODE,MFSRESO,MFSHEET,MFSHEETC1,MFSHEETC2,MFPMAX,MFTMSND,MFTMSNDH,MFTMSNDM,MFMBOX,MFMBOXPS,MFMBOXID,MFRLY,MFRLYID,MFRLYPRN,MFRLYNUM,MFCHRGT1,MFCHRGT2,MFCHRGT3,MFFCODE,MFPCODE,MFSG3FRBT,MFMDMSPD,MFECMFRBT,MFEJBIGFRBT,MFIFAX,MFTIFF,MFIFAXCMODE,MFIFAXSRESO,MFIFAXPMAX,MFIFAXTMSND,MFIFAXTMSNDH,MFIFAXTMSNDM,MFSN,MFGN,MFMAIL,MFAUX1,MFAUX2,MFAUX3,MFSVRT,MFSVRADDR,MFPORT1,MFPORT2,MFUSER,MFPASSWD,MFVOLUME,MFPATH,MFUSETLS
0001,MAIL,Glenn,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,Marsden,,glenn@*************.co.uk,,MAIN OFFICE,,,,,,,,,,
Mar 26, 2009 | Office Equipment & Supplies
Converting IIF files from Quick Books Pro 2005 to CSV
Jan 14, 2009 | Intuit QuickBooks: Pro 2005 for PC
Importing csc files
Hi freaks11,
Oct 24, 2008 | Microsoft Excel for PC
Need to add employee e-mail address to xerox 440st so we don't have to type it in each tme
NOTE: Accessing the Public Address Book is optional. The Document Centre will accept a Public Address Book file that contains a list of user names and their E-mail addresses. This file must be Comma Separated Values (CSV) format for the device to be able to read the file contents. The majority of word processing packages will allow you to create a CSV file. A selection of e-mail applications will also allow you to export a list of users in the CSV file format.
The completed CSV file is imported to the device through CentreWare Internet Services. The file must have the .CSV file extension. A valid CSV file format includes the name and SMTP e-mail address. The CSV file should be created so that the Names are in one column and the E-mail addresses are in the next column. For example, the following are both valid format CSV file entries:
Smith, Smith@company.com
Smith, John - john.smith@company.com
The order in which entries are displayed in the Public Address Book at the Document Centre will depend on how the entries are sorted in the CSV file.
NOTE: This solution assumes Microsoft Internet Explorer is being used as the web browser. Other web browsers may vary. You may need to contact your System Administrator to perform this solution, as it requires knowledge of the network’s email system. Configuration of the LDAP directory settings requires the network to support LDAP Services.
The Document Centre will have to be configured for TCP/IP (IP Address, Subnet Mask, Broadcast Address, Gateway Address). Before you begin, print a Configuration Report and make sure the Document Centre has an IP address and the HTTP protocol is enabled.
From the workstation desktop:
  1. Click on [Start], point to [Programs], and select [Internet Explorer] to launch Internet Explorer.
  2. Click on [File] from the toolbar, then select [Open]. The Open window will be displayed.
  3. Enter the IP address for the Document Centre in the Address: field, then press [Enter] on your keyboard. CentreWare Internet Services window will be displayed.
  4. Click on [Index] in the upper, right corner of Internet Services. The Index window will be displayed with a list of hyperlinks to different areas of Internet Services.
  5. Click on [Public Address Book ] from the list of hyperlinks. The Public Address Book Settings window will be displayed.
  6. Click [Browse]. The Choose File window will be displayed.
  7. Browse to the location of your Address Book File (*.CSV).
  8. Highlight the CSV file and click on [Open]. The path for your .CSV file will be displayed in the Address Book File (*.CSV) field.
  9. Click on [Import Now]. An 'Are you sure you want to overwrite the existing Address Book? This cannot be undone' message may be displayed. Click [OK] to import the address book.
    NOTE: You cannot import a .CSV file with a blank name or e-mail field.
  10. An Enter Network Password window may be displayed. In the User Name: field, enter the system login of admin, in lower case letters. In the Password: field, enter the system password, then click [OK].
    NOTE: If you do not know the system password, contact your administrator. The initial system password at machine install is 1111 for the Document Centre 460|470|480|490, and 22222 for the Document Centre 425|430|432|440. If the administrator encounters a problem with changing or forgetting the machine password, a service call must be placed.
  11. Click on [Map Existing Address Book] to identify which headings in the CSV file contain the name and e-mail address to use in the Public Address Book.
    NOTE: If the CSV file contains names and e-mail addresses only, the file may map automatically.
  12. Click on the [Display Name] drop-down menu under the Imported heading. Select the heading that corresponds to the data you wish to use as the display name in the address book. The data you selected will be displayed in the Imported Sample field.
  13. Click on the [E-mail Address] drop-down menu. Select the heading that corresponds to the data you wish to use as the e-mail address in the address book. The data you selected will be displayed in the Imported Sample field.
    NOTE: If you are using a DC460|470|480|490, and if the CSV file does not contain a heading row, the drop-down menu will contain information from the first line of data in the file. For correct Public Address operation, the display name must map to a user name and the e-mail address must map to an SMTP format e-mail address, for example, name@domain.com.
    If you are using a DC425|430|432|440 and if your CSV file does not contain a heading row, the first row of data will be lost.
  14. Click on [Apply New Settings] to save any changes.
    NOTE: If you click on the [Clear All Addresses] button all entries will be removed from the current public address book.
  15. Click on the [X] in the upper, right corner to close Internet Explorer and return to the desktop.
Sep 23, 2008 | Xerox Office Equipment & Supplies
Computers & Internet Logo
50 people viewed this question
David Payne
David Payne
