Question about Lexmark X9350 All-In-One InkJet Printer
Lekmark x9350 I am using a filled cartridge and every time I try to print the printing is stoped by a pop up windwos wich says that the "ink is not genuinem lexmark" and the printing is stoped until i close the window by hand/ It is very annoing and its stoping me from printing documents one after another becouse I have to close the window between every document. How can I stop this pop up ? thanks Karatster
    Sergeant:
  • 390 Answers
Try first doing a thorough clean of all printheads, cartridges too, then unplug all usb and power cords after turnig off. replug all and try again. I f no better, uninstall and reinstall printer.
Posted on Aug 12, 2007
False ink empty
Are you sure its exclamation mark?..
This warning message related to print head. (warn out). When you are replacing ink tube assembly use dummy print heads to do the priming (new ink tubes are empty & they have to fill with ink)..
Action: Remove all cartridges and print heads, switch on the printer follow the screen message.(Insert cartridges first next dummy print heads).once its recognizes cartridges then it switch over to print heads,insert dummy print heads. Once printer recognized the dummy print heads, printer will perform priming, during priming dummy print heads will filled with respective inks.(follow the display message)Remove dummy print heads & insert normal print heads. Wait till printer recognizes print heads, load the paper & wait till performs the calibration, once calibration is successfully done issue closed.
If calibration not successfully done, check align print out for which print head is not printed properly, replace it..
Pl ensure that minimum 50% ink levels required in cartridges before performing the priming. Best of luck..
Dec 03, 2012 | HP DesignJet 500 InkJet Printer
Poor print quality
Make sure you are using genuine Lexmark cartridges. Lexmark products work best with original supplies. Lexmark does not recommend the use of refilled, re-manufactured, or clone cartridges. You might not get the print quality you expect from ink that is specially formulated by Lexmark.
Check your cartridge ink levels. From the printer operator panel, go to Maintenance > View Ink Levels. Replace the cartridge that has low ink level. If your ink levels are still substantial for printing and you are using genuine Lexmark supplies, please contact Lexmark Technical Support Center for further assistance.
Dec 28, 2011 | Lexmark X9350 All-In-One InkJet Printer
Says to replace cartridge which i did but it still wont print.
Why isn't any ink coming out of a new ink cartridge that has just been installed?
The ink cartridge may have a plastic tag covering the print head, which should be removed before the cartridge is installed. If the tag has been removed and the problem persists, there may be air bubbles blocking the print head. In this case, you can try using the print head cleaning function of your printer or leave the ink cartridge in your printer for about an hour to allow the air bubbles to rise to the top of the ink cartridge.
What should be done if the ink cartridge doesn't print or some of the colors don't print?
The nozzle may be clogged with dried ink. The print head should be blotted with a damp lint-free cloth to remove the dried ink. If this does not work, try soaking the ink cartridge in water for a few minutes. To soak the ink cartridge, place it in a Styrofoam cup and fill the cup with water until the ink cartridge is halfway immersed in water. If the ink cartridge does not print after this is done, try soaking the ink cartridge overnight.
Hope it helped...
Oct 28, 2010 | Canon imageCLASS MF5750 All-In-One Laser...
Unable o clean
HTML clipboardHi If your brother printer has been left unused for some time it is probably clogged? And the inbuilt cleaning facility does not help then you will probably need to buy a Magic Inkjet Flush Print Head Cleaning Kit.
Which you can find on Ebay.
http://tinyurl.com/yfx2y5k
Although it is possible to take the Brother printers apart, it is too difficult for most people.
To view what´s inside a Brother Printer click on next line...
Click again to enlarge photo.
http://magicinkjetflush.com/images/Unclog_Refill_Brother_Printers.jpg
Therefore, what we suggest is to make cleaning cartridges using the Dr.EpSUN Refill Tool...
Then use them to flush the print head (usually at the end of long tubes near to the back of the Brother printer)
*NEVER TOUCH THE WHITE star shaped PIN... under ink cartridges... because once pessed in... it cannot be used !
Also in most cases a single cleaning cartridge for black and 1 for colour is all you will need.
If you only have FULL INKS and need to make a cleaning cartridge use Dr.EpSUN Refill Tool to empty ink cart...
Save the ink in a clean glass jar or similar make cleaning cartridge then once unclogged simply use Dr.EpSUN Refill Tool
to refill with your saved ink.
How to make Brother Cleaning Cartridges
If you wish to see photos? You can also follow the procedure for Epson C80 in the Magic Inkjet Flush Manual.
Using FREE Dr.EpSUN Refill Tool.
To refill Brother inks... or if printer has been left unused and you need to unclog print head? (To make a cleaning cartridges *Fill empties with Magic Inkjet Flush instead of Ink / Then print rectangles using Magic Inkjet to FLUSH print heads once prints appear without white lines simply replace with inks and continue printing rectangles untill all Magic has been flushed out of print head.)
How to refill Empties...
1. Secure empty Brother ink cartridge UPSIDE DOWN in a vice or similar.
2. ONLY HALF fill Dr.EpSUN Refill Tool with warm Magic Inkjet Flush (or correct color Ink if refilling with ink)
3. Then Holding Dr.EpSUN Refill Tool upright... cover metal tip with a tissue and expell any trapped air until ink appears.
4. Insert metal tip into circular ink outlet hole of upturned cartridge... until black rubber makes a GOOD seal.
Holding both securely...
5. Do NOT TRY TO FILL Instead. PULL UP on the plunger of Dr.EpSUN REFILL TOOL.
6. Air will bubble up through the Magic/ink whilst escaping from cartridge creating a vacum.
7. Now... Simply allow plunger to retract and the Magic/ink will automatically refill the cartridge for you.
8. STOP filling before the Dr.EpSUN Refill Tool is empty otherwise air will entering.
9. Repeat until ink cartridge is full.
How to FLUSH a BROTHER print head.
10. Place filled cartridge into printer and you are ready to print.
Use print head cleaning to prime which will also fill the ink tubes... then....
11. Print rectangles of the problem colour(s) using test sheets (see below) to prime ink.
As found in the manual, here are the print test sheets for printing rectangles depending on colour(s) with problem.
Just choose... Yellow, Magenta, Grey Tones etc...
PRINT TEST SHEETS FOR USE WITH MAGIC INKJET FLUSH
http://magicinkjetflush.com/Ebay/Print_Test_Black.jpg
http://magicinkjetflush.com/Ebay/Print_Test_Color.jpg
http://magicinkjetflush.com/Ebay/Print_Test_Cyan.jpg
http://magicinkjetflush.com/Ebay/Print_Test_Yellow.jpg
http://magicinkjetflush.com/Ebay/Print_Test_Magenta.jpg
http://magicinkjetflush.com/Ebay/Print_Test_Grey_Tones.jpg
Once prints appear to be normal simply replace the Magic Inkjet Flush with ink cartridges and continue printing rectangles untill flushed.
Hope it helps. If you need any further help Click Here then choose "Ask a Question"
Thanks
John P Bradley Tinteiros (Ebay)
Nov 23, 2009 | Brother DCP 115C All-In-One InkJet Printer
Lexmark x9350 printer gives error message #1203
I logged into Lexmark's web site and checked their printer support page. It said that if you get error message 1203 your ink cartridge has leaked fluid. In order to find the right cartridge, do the following. Remove both ink cartridges, put in one, turn off the printer, turn it back on and if you get the message 1203 that's the cartridge with the problem. I did not get that message. I turned off the printer, put in the other cartridge, and turned it back on. Sure enough, I got the 1203 message again. (I had cleaned the wrong cartridge before). I removed the leaky cartridge, cleaneded it (making sure I did not leave any residue) and put it back in the printer. It worked!
Jun 13, 2009 | Lexmark X9350 All-In-One InkJet Printer
Kodak esp-3 cannot purge air from print head
WE HAVE AKODAK ESP-3 ALL IN ONE.
RAN OUT OF BLACK INK. HAVE REPLACED BLACK CARTRIDGE 2 TIMES BUT CANNOT GET BLACK TO PRINT. WHAT SHOULD I DO NEXT???
Apr 23, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
Need to Override Ink Level - for High Yield Ink Cartridge
have you tryed to remove the cartridges, en reinstalle them again? - you then have to run the ajust job...
/Teis
Jan 30, 2009 | Lexmark X9350 All-In-One InkJet Printer
PRINTING WITH BLACK INK CARTRIDGE ONLY; COLORED CARTRIDGE IS EMPTY.
Apparently, if you hold the "resume button" (the one next to the power button) for about five seconds after you get the message saying to replace the color ink cartridge the machine starts printing. I did this after I went to "maintenance" under "preferences" and changed ink to "black only." At first that alone did not work, but after trying the resume button for 5 secs it worked okay.
Sep 13, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
Ink cartridge (not) installed properly
For the Canon iP1800 printer are you sure you're using the 30 for black and 31 for color?
And make sure they "click" when installed. That should confirm that they're nice and tight in their ink compartments.
Besides that, maybe reinstalling the printer drivers could do something?
Sep 08, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
Epson Stylus CX3810 replace ink box. will not let me print.
I'm sorry to say, but I just spoke to epson and the printer will not print unless all cartridges have ink. The black ink only option is only used to extend the life of color cartriges. Just another way for them to get you to buy things you don't need.
Dec 04, 2007 | Epson Stylus CX3810 All-In-One InkJet...
Lexmark X9350 All-In-One InkJet Printer Logo
153 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
