Frigidaire PLHS267ZCB4 side by side. Ice maker quit making ice. Found that water dispenser also not dispensing. Water supply to filter fine when switch depressed (held check open with filter removed). Problem is water cannot return to valve because coil of plastic tubing in lower frig compartment is frozen. Noticed that freezer is also begining to thaw. Noticed that you neither hear or feel air blowing from fan when holding doors open. Feels like compressor is running and condenser fan is running. Evap fan problem?
Thank you for your post, friend!
I see that the icemaker on your Frigidaire refrigerator works intermittently. I would like to ask you some troubleshooting questions. When was the last time you replaced your water filter? Have you checked to verify the water valve is completely opened? I would also check to make sure there are no kinks in your water line. If you continue to experience these issues with your icemaker please comment back. I would like provide any additional information if possible. -Matt
Hello Jim czyryca - From what you are describing if the ice maker is not making ice but is dispensing water, sounds like the refrigerator has a frozen water line, faulty ice maker valve or bad component that sends power to the ice maker valve when needed. The ice maker cycles internally to call for water so I strongly suggest contacting a professional to move forward accurately to assist with the repairs.
Replacement parts can be
purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
partsselect.com
Before going to buy any parts
directly.
Go through this troubleshooting help links.
This is list of refrigerator problems,
which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly
in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on
refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
directly.
in refrigerator?
refrigerator?
These will help.
Thanks,.
