Question about Dell Inspiron 1721 Notebook
Start directly on external monitor - Dell Inspiron 1721 Notebook
  • Dell Master
  • 32,281 Answers
Connecting an External Monitor or Data Projector
You can switch to an external monitor or data projector by two methods.
1. Connect the external monitor to the laptop's video port, power up the external monitor first and the laptop. The video information will automatically switch to the external monitor.
2. If you power up the laptop first then you can switch the video output to the external monitor by pressing the Fn key and one of the Function keys, depending upon your make and model laptop. You can also toggle between the external monitor or both LCD screen plus the external monitor or back to LCD screen only by pressing the Fn key plus one of the function key a few times.
Here is a list of key combinations for some of the laptops :-
IBM ThinkPad = Fn + F7
HP and Compaq = Fn + F4
Toshiba = Fn + F5
ASUS and Dell = Fn + F8
Posted on May 10, 2013
Need both laptop and monitor on at same time.
Hey Roger,
Below is information that should help you with trying to get monitor and notebook screen to work.
First make sure your laptop is equipped to be able to connect a secondary display, there should be a port for connecting a standard monitor cable on the back.
Connect your secondary monitor and reboot the laptop, the system bios should recognize that a second monitor has been added.
Then right click on your desktop and bring up the display properties dialog box.
Select "settings"
Your laptop should be identified as monitor 1 and you should also be able to see the secondary monitor as monitor 2.
Click on the secondary monitor and check the box that says "Extend my Windows desktop onto this monitor".
Set your screen resolution and color quality for the second monitor and click apply.
Directing icons and browser windows over to the other monitor is just a matter of drag and drop.
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Apr 11, 2014 | Dell Latitude D600 Notebook
Problem with external monitor activating with DV6 1360-us
You can switch to an external monitor or data projector by two methods. 1. Connect the external monitor to the laptop's video port, power up the external monitor first and the laptop. The video information will automatically switch to the external monitor. 2. If you power up the laptop first then you can switch the video output to the external monitor by pressing the Fn key and one of the Function keys, depending upon your make and model laptop. You can also toggle between the external monitor or both LCD screen plus the external monitor or back to LCD screen only by pressing the Fn key plus one of the function key a few times. Here is a list of key combinations for some of the laptops :- IBM ThinkPad = Fn + F7 HP and Compaq = Fn + F4 Toshiba = Fn + F5 Dell = Fn + F8
Sep 20, 2012 | HP Pavilion Computers & Internet
External monitor only works if I start windows vista in safe mode
First after you boot it up normally (not Safe Mode) can you move the mouse far to the left or to the right do you see the mouse. If you do see the mouse pointer you are running dual monitor mode and the laptop screen is set as the primary monitor. You have to run it in Save Mode and set the external monitor as the primary monitor. Hit the Start button then select Help+Support and in the search box enter "dual monitors". Read how to set up the primary monitor.
Second maybe you need to activate the external monitor. When laptops boot normally (not Safe Mode again) with a external monitor connected you have to hit the Fn (function) key (probably blue near Alt key) and some other number key (it probably has a blue monitor symbol on it) I'm not sure which one. This key sequence is a toggle sequence. In other words when you boot a laptop it goes directly to the laptop screen then the first time you do a Fn + number key combination it will turn on the external monitor and turn off the laptop screen the next time you push Fn+number key it will turn on both monitors (external and laptop screen) the third time it will turn on only the laptop screen and so forth.
Aug 19, 2012 | HP Pavilion dv7-1245dx Notebook
WHen I hook my laptop to my external HP 22" monitor, using my HP docking station, it recognized the monitor but the externalk monitor stays dark. Every so often it will flicker and then give the...
no laptop stated ok W7 OS, nice to know.
hopeless?
nor external model screen stated
try a different external screen
any shop can fix it, ask them
no need to ship anything
get it checked out by a technician
we can test all 3 parts and tell you whats worn i minutes.
i can not understand your post
try to be more clear
does local LT screen work ok
does using a known directly connected screen (VGA)
on the LT you must turn on external screen using the fn hot key
the the external works,. do so, now
if both internal and external fail the LT is bad, guess, bad GPU chip
if only external fails, try a known working external screen
if that works your external is bad.
the docking is last, and if only it fails, then ITS BAD.
Mar 14, 2017 | HP Pavilion DV6910US Laptop
My hp pavillion tx 2000 laptop is not working.............. when i turn it on, all the relevant lights comes on but nothing appears on the screen. i only get a blank screen.................. what could...
If you hear it start up and the lights come on, try hooking up an external monitor. When you do, be sure to push the Fn key plus whatever special function key shows 2 monitors on it so the output will be directed to the external monitor.
Sounds like the LCD screen might not be working.
Apr 20, 2011 | Computers & Internet
Dell laptop connected to 1209s projector...dell page indicates searching for signal and can't
Using the Display When you start the computer with an external device (such as an external monitor or projector) attached and turned on, the image may appear on either the display or the external device.
Press <Fn><F8> to switch the video image to the integrated display only, the integrated display and an external CRT monitor simultaneously, an external CRT monitor only, the integrated display and an external DVI monitor simultaneously, external DVI monitor only, and external CRT monitor and external DVI monitor simultaneously.
May 15, 2009 | Dell Latitude D800 Notebook
Screen blank but when toggled you can see output on external monitor
sounds like the internal video card has a direct feed problem, it plays on external. while screen is hooked to external check control panel for main screen dianostics. You have to live with it untill it fails altogether. Internal video is starting to fail. time for new laptop
Apr 28, 2009 | Computers & Internet
D800 laptop will not display on external monitor
Most laptops go into standby mode when the lid is closed. To stop this, (Windows XP) click Start, Control Panel, Performance and Maintenance, Power Options, then click on the Advanced tab, select "Do nothing" in the drop-down for "When I close the lid of my portable computer"
Feb 12, 2009 | Dell Latitude D800 Notebook
Aardvark pro q-10
Yes, you have to connect the monitor outs to a mixer (or directly to your monitors) to hear. It is a totally separate sound card than what is coming out of your audio out port. Anyway, you'll get much better sound quality from the monitor outs.
Nov 26, 2008 | Aardvark Direct Pro Q10 (bundle) External...
External Monitor connection issue
There is only one way to connect an external monitor to a laptop.Most laptops have an "FN" key. by simultaniously pessing the "FN"key and F7 key it toggles from laptop to external to both each time you press the keys.
Mar 13, 2008 | Computers & Internet
Dell Inspiron 1721 Notebook Logo
632 people viewed this question
Alun Cox
