Question about Toshiba E-Studio 232 Copier
Canot copy or print function - Toshiba E-Studio 232 Copier
    Problem Solver:
  • 15 Answers
JUST CHECK FOR THE PRINTER PICTURE IN THE TOOLBAR.
Posted on May 10, 2013
Canon MP110 running Windows 7 with corret software will not print colour nor will it read colour in scan.
Can you try to do COPY function?
If COPY function fail,means the machine in fault. Most probably is PRINT HEAD in fault.
Nov 24, 2014 | Canon Office Equipment & Supplies
Our kyocera printer says WASTE TONER BOX FULL. what does it mean?
there is a little bottle depending on the model if I get a model I can tell you where it is at but its used for after every copie it cleans the drum and transfer belt it canot reuse that toner so it has to get rid of it so it sends it to the waste toner bottle if the bottle is full you will not be able to print or copy you may be able to scan though
Apr 08, 2014 | Kyocera Office Equipment & Supplies
I cannot get the printer to copy anything, it just goes into the align mode. It will print things from my computer.
Start up your multi-function printer and computer. Wait until it has powered on completely before beginning.
Open the printer's lid and place your item on the copying surface with the side you want copied face-down on the glass. Double-check the alignment.
Shut the printer's lid. For large items, such as books, you may want to remove the printer lid rather than forcing it closed.
Choose the kind of copy you want: black-and-white or color. You also may have to select the kind of paper that you are copying.
Size the copy to the page if desired. Some multi-function printers allow you to expand or shrink the original to fit different sizes of paper.
.Enter the number of copies you want. You may do this on the multi-function printer or in the print setup of your computer. Make sure the paper tray has enough paper to finish your copying job.
Press the "Start" button. Other names for this might be the "Copy" or "Print" button.
Remove the pages as they are delivered from the printer's feeding mechanism.
Do not tug on the copies as they come out. Let them fall into your hands.
Take care.
May 15, 2010 | Office Equipment & Supplies
Hp 4300 officejet canot print from system command but they working fax incoming and out going and copying solve my problem
you have a problem in the computer,delete the hp 4300 from the printer menu on the computer,download from hp.com the latest drivers for your printer and Reinstall it.
Mar 09, 2010 | Office Equipment & Supplies
How do I make copies
What do you mean by copies? Like printing 1 page in more than 1 copy?
In the Print dialog box (when you click the File => Print command), You can increase the number of copies to be printed in just one printing.
If your printer is multi-function (one printer that can scan, copy, and print), just place the document to be copied (photocopy) in the scanner tray, cover it and then PRESS the OK. In some models, it is MONO or COLOR under START button group.
Feb 06, 2010 | Office Equipment & Supplies
Receipt not printing
I believe this might help, not exactly familiar with this exact model but here it goes.
Receipt ON/OFF function
When you use the printer to issue receipts, you can disable receipt printing in the REG mode to save paper
using the receipt ON/OFF function. To disable receipt printing, press the Rkey in the OP X/Z position. This
key toggles the receipt printing status ON and OFF.
The register will print reports regardless of the receipt state, so the paper roll must be installed.
To issue a receipt when receipt ON/OFF function is set to OFF:
If your customer wants a receipt after you finalized a transaction with the receipt ON/OFF function being OFF
status, press the Rkey. This will produce a receipt. However, if more than 30 items were entered, the
receipt will be issued in a summary receipt.
Copy receipt
You can print a copy receipt by pressing the Rkey when the receipt ON/OFF function is in the “ON” status.
To realize this function, you must enable the function. Please refer to page 62 (Job code 63).
Nov 11, 2008 | Sharp XE-A404 PC Desktop
IS IT POSSIBLE TO GET A TEST PRINT OR SCAN TEST WITHOUT THE X1180 BEING CONNECTED TO A PC?
No, if you print or scan, you need always to store the file on a computer, and if you use copy function, you still need the computer, as copy function allowed on this printer is only Colour Copying with PC .
This printer cannot print, scan or copy if it is not connected to a computer.
Oct 10, 2008 | Lexmark Office Equipment & Supplies
Will not make a copy
If it won't copy, it is unlikely to handle faxes either since those functions use the same scanner. If your received faxes are coming out blank, then it is a problem with the ink system; if you can get faxes printed but not copy a document, the scanner may be at fault.
Have someone send you a fax to check this function (printing) and then try sending one back to check the scanner.
If either one fails, then hyou know where the problem lays.
Jul 10, 2008 | Brother IntelliFAX 560 Plain Paper Fax
Toshiba E-Studio 232 Copier Logo
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
