Code access i have done the surveys on this web site many times. now when i log in and try to do them again i get that my ip address has already filled the survey, i was never given the download code what can i do to get it?
  • Micheal ryan Sep 20, 2013
    I have done the surveys on this web site many times. now when i log in and try to do them again i get that my ip address has already filled the survey, i was never given the download code what can i do to get it as well? or is it just a waste of time???
SOURCE: forgot security code nokia 6288
I forgot my security code for nokia 6288 plz help me if you can
353226/01/385828/1
Posted on Jun 02, 2008
  • 59 Answers
SOURCE: Unable to access web address
if you are using google chrome! then try cleaning the cache first! if it does not works enter the url in the address bar then while it is opening the site press stop button or the "Esc" key on the keyboard and then press "Ctrl+F5", you can also try this on Internet explorer and fire fox. hope that solves your problem! there is no problem with the site the site is online...
Posted on May 16, 2009
  • 62 Answers
SOURCE: When running the setup CD, I get a Site Survey
I can help you configure your expander manually instead of using the CD.
You can connect your expander to your PC via ethernet cable and then assign a static IP address on your PC.
To assign a static IP address, just double-click on the monitor icon on the lower right hand corner of your PC and then view status and go to properties. Look for TCP/IP v4 and click properties.
Select use the following IP address:
192.168.1.2
255.255.255.0
and then click OK.
After successfully assigning an IP address to your PC, let's test the connectivity by going to command prompt.
Go to Start>Run>and then type cmd and hit Enter.
Once you're on the black screen type ping 192.168.1.240.
If you get replies then your good to go...
Let's now access the Web UI of the you Wireless expander.
Open a browser and then type on the address bar 192.168.1.240 and then hit enter.
It will prompt you with WRE54G's username and password. Just type the password to login to the Web UI. The default password is admin.
Once your on the Setup page, you have to configure your settings exactly the same as your wireless router (e.g. wireless security, IP address range) except for the SSID. You may want to change the SSID on your WRE54G for you to easily identify where your wireless computer is connected.
You can leave the WRE54G's IP address to 192.168.1.240 if your wireless router's IP address is on the same range like 192.168.1.x
Then on the Gateway address type your router's IP address. If you're also using Linksys the default IP address usually is 192.168.1.1
Then you can configure your wireless settings same as your router. After that, same the settings and see if the light on the WRE54G becomes BLUE. If yes, then you're good to go! You can unplug the PC from the WRE54G and then set your PC's IP address back to Obtain an IP Address Automatically. See static IP address procedure above.
Posted on Jul 02, 2009
  • 62 Answers
SOURCE: site survey failed
192.168.1.2
255.255.255.0
and then click OK.
Posted on Jul 06, 2009
  • 81 Answers
SOURCE: When I run the set-up disk, it reads Site survey
maybe the device is faulty or the disk is bad try replacing it and try again.
Posted on Nov 24, 2009
What is the IP address for my Firestick?
The IP address of an item, unless you specifically assign it one, is done automatically by the router when it connects to the network. This address can be different each time the device connects depending upon what other devices are already connected.
Jan 02, 2016 | Computers & Internet
Cheats and cheat codes
Try using the survey bypasser.
Dec 24, 2013 | Android Apps
192.168.0.1
Try this.
http://192.168.0.1
Mar 14, 2013 | Computers & Internet
Website not displayed error http 500
The Web server (running the Web Site) encountered an unexpected condition that prevented it from fulfilling the request by the client (e.g. your Web browser or our CheckUpDown robot) for access to the requested URL.
This is a 'catch-all' error generated by the Web server. Basically something has gone wrong, but the server can not be more specific about the error condition in its response to the client. In addition to the 500 error notified back to the client, the Web server should generate some kind of internal error log which gives more details of what went wrong. It is up to the operators of the Web server site to locate and analyse these logs.
500 errors in the HTTP cycle
Any client (e.g. your Web browser or our CheckUpDown robot) goes through the following cycle when it communicates with the Web server:
  • Obtain an IP address from the IP name of the site (the site URL without the leading 'http://'). This lookup (conversion of IP name to IP address) is provided by domain name servers (DNSs).
  • Open an IP socket connection to that IP address.
  • Write an HTTP data stream through that socket.
  • Receive an HTTP data stream back from the Web server in response. This data stream contains status codes whose values are determined by the HTTP protocol. Parse this data stream for status codes and other useful information.
This error occurs in the final step above when the client receives an HTTP status code that it recognises as '500'. (Last updated: March 2012).
Fixing 500 errors - general
This error can only be resolved by fixes to the Web server software. It is not a client-side problem. It is up to the operators of the Web server site to locate and analyse the logs which should give further information about the error.
Fixing 500 errors - CheckUpDown
Please contact us (email preferred) whenever you encounter 500 errors on your CheckUpDown account. We then have to liaise with your ISP and the vendor of the Web server software so they can trace the exact reason for the error. Correcting the error may require recoding program logic for the Web server software, which could take some time.
Jan 28, 2013 | Facebook Social Network
My ip is banned from some forums but first time i'm logging into the forum why this happen any one please help me to solve this....
because of your ip is already identify by the website.. so use some proxy address hidemyip software or hidemyass proxy address...go to internet option-advanced-network setting-now select manually and paste the proxy you get from the hidemyass site..or install the software hidemyip it automatically changes the ip and you can surf through that website and check the ip is changing or not through ip-details.com
Oct 10, 2012 | Video Game Consoles & Games
I've log in facebook home page, but there is a msg pop out asking me to complete a survey if not I can't go further to use the facebook. Pls help!!!
That normally happens when you are using a different location to log into Facebook, or if you are using a wifi connection in a location that is not your home as it will create a Differnt IP address each time. But you MUST answer all the question correctly, if you are not sure off the picture click on that option as if you get a question wrong it just keeps asking you time and time again
Jan 15, 2011 | Dell Inspiron N4010 Notebook
I am not able to access my yahoo account, showing error code#1, please advise.
1. Clear your cookies and temporary internet files (AKA cache), exit from the browser, then restart the browser.
2. If you are a home user and do not pay for a static IP address, get a different dynamic IP address; do
[Start] > [Run] > cmd > ipconfig
{{write down the IP address, then disconnect from the Internet with}}
ipconfig /release
{{wait a few minutes and then reconnect with}}
ipconfig / renew
{{compare the new IP address to the old to make sure your IP address changed, then try again}}
If you are an office user, try someone else's PC which will have a different IP address.
3. Log into Yahoo through a different country's server. I.e. if you usually log into Yahoo via http://login.yahoo.com/ or http://mail.yahoo.com/ then try http://login.korea.yahoo.com/ or http://nz.yahoo.com/
4. Access your Yahoo mailbox via http://wap.oa.yahoo.com/
5. Use a different browser. Use Firefox (free download from mozilla.com) if you normally use IE or Safari.
6. If you have a web accelerator (mostly an affliction of dial-up users) then try turning it off.
7. If you use a proxy server (mostly a corporate user thing) then try turning it off.
Nov 20, 2010 | Yahoo Mail
I am getting this error while trying to log on to Yahoo mail There was a problem accessing your account. Please try again in a moment. Error #1 please help
ipconfig /release
ipconfig / renew
Aug 11, 2010 | Yahoo Mail
I want to change the default SSID name
log on the router using the default gateway IP address and change it. if you need more details post router model/make and we'll assist
Feb 02, 2010 | Computers & Internet
I installed my D-Link DIR-615 router today and did my setup in my Window 7 laptop. I don't know whether it matters whether I do setup in a laptop or a desktop. Then, I connect the modem/router to my...
If you have trouble connecting to your modem, you may need to lock the speed down on the WAN port of your router to 10Mbps. Within the web-based configuration utility for the router, go to Tools > Misc and the option to select the WAN speed will be towards the bottom. Not all routers have this option.
Follow the steps configuring the router once again...
Step 1 Log into the web-based configuration by typing in the IP address of the router (default:192.168.0.1) in your web browser. The username is admin (all lowercase) and the password is blank (nothing).
Note: The address 192.168.0.1 is NOT on the Internet. The web-based configuration is built-in to the router.
Step 2 Click the Setup tab and then click the Internet button.
Step 3 Dynamic IP Address is the default value, however, if Dynamic IP Address is not selected as the WAN type, select Dynamic IP Address from the drop down menu. Click Clone Mac Address. Click on Save Settings to save the changes.
Step 4 Click on Status. Under WAN, Click DHCP Renew. If it does not get an IP address or times out, then continue with the next step.
Step 5 Power cycle the cable modem and router using the following steps:
Turn the cable modem off (first)
Turn the router off
Leave them off for 2 minutes**
Turn the cable modem on (first)
Wait until you get a solid cable light on the cable modem
Turn the router on
Wait 30 seconds ..
Step 6 Follow Step 1 again to log back into the web configuration. Click the Status tab and click the Device Info button. If you do not already have a public IP address under the WAN heading, click on the DHCP Renew button.
Jan 22, 2010 | D-Link DIR-615 Wireless Router
Computers & Internet Logo
David Payne
David Payne
