Canon ir3235 / IR 3245 UFR II
We used to cannon ir 3235 at office and connect local printer.computer system information is Windows 7/32bit. recently we had installed security program each computers of user. and then excel and PDF files don't work print out. we can't off security program because rull of office security. plz let me know how resolve this issue. ppt/word/text/etc.. can wokr print out but only excel and pdf file not work print,
  • philip May 10, 2013
    add one information we had been reinstall printer driver ....
    plz let me know
Soulvisitor
  • 1113 Answers
SOURCE: Canon iR 3220 printer problem with PDF files
Sound like a driver issue, reinstall and check that it is correct one.
Posted on Nov 09, 2007
SOURCE: downloading software for Canon imageCLASS MF6550
gracias
Posted on Mar 01, 2008
  • 2072 Answers
SOURCE: Phaser 8500 color printing issue - pdf file
Try setting up PDF direct printing..
> Support & Drivers > Phaser 8500/8550 Support > Search Results Solution: Perform PDF Direct Printing From Microsoft Windows 2000 / XP / Server 2003 OS and Apple Macintosh OS X (10.x) bttn_print.gifMake Printable bttn_email.gifEmail this page elem_1_spacer.gif PDF direct printing can be used to send a PDF file to the printer without having to open and view the file on a computer.
NOTE: PDF Direct Printing may not be successful if the printer does not contain a hard drive.
Depending on the OS being used, click on one of the following links:
Macintosh OS X
To download a PDF file directly to the printer from Windows 2000 / XP / Server 2003:
To download a file to a printer that is connected using an Ethernet (network) cable, use the FTP command or CentreWare Internet Services (CWIS). To download a file to the printer that is connected directly to the computer with a USB cable, use the Xerox File Downloader Utility.
To download a file to the printer using the FTP command:
NOTE: To perform this solution, the printer must be connected to a network that utilizes the TCP/IP protocol. The printer must also contain a valid IP address. If necessary, contact your System Administrator for additional information.
Not all web browsers can be used to perform this solution. If problems occur when performing this solution, download the file using CWIS. See the To download a file to the printer using CWIS section below.
  1. From the computer, open an Internet browser window.
  2. Type: ftp://xxx.xxx.xxx.xxx, where the x characters represent the IP address of the printer, in the Address field.
    NOTE: The IP address of the printer can be found on the Configuration Page. See the Related Items below for additional information.
  3. Press [Enter] on the keyboard. A blank FTP connection window with a [.] icon will be displayed.
  4. Drag and drop the file to be sent to the printer into the blank FTP connection window. The file will be sent to the printer.
To download a file to the printer using CWIS:
  1. From a computer, open an Internet browser window.
  2. Enter the IP address of the printer in the Address field, and then press [Enter] on the keyboard. The CentreWare Internet Services home page will be displayed.
    NOTE: The IP address of the printer can be found on the Configuration Page. See the Related Items below.
  3. Click on the [Print] button.
  4. Click on the [File Download] link in the list of options on the left side of the window.
  5. Depending on the browser being used, click on the [Browse] or [Choose File] button, and then browse to and select the file to be downloaded to the printer.
  6. Click on the blue, square button to send the file to the printer.
To download a file to the printer using the Xerox File Downloader Utility:
NOTE: This solution assumes the Xerox File Downloader Utility has already been installed on the computer. If necessary, click on the [Drivers and Downloads] link under the Product Resources menu on this window to download and install the utility.
  1. From the computer, open the Xerox File Downloader Utility. By default, the utility is installed in the following location on the computer's hard drive: C:\File Downloader.
  2. Select the required printer from the Select the printer to spool the file to from the list below pull-down menu.
  3. Click on the [Browse] button, and then browse to and select the file to be downloaded to the printer from the Select the file to sent to the printer section.
  4. Click on the [Send] button to send the file to the printer.
To download a PDF file directly to the printer from Macintosh OS X:
Files can be downloaded to the printer using the Print Center or Printer Setup Utility, or by using CentreWare Internet Services (CWIS).
To download a file to the printer using the Print Center or Printer Setup Utility:
NOTE: This method can be used for Ethernet (network) and USB connections.
  1. Open the Print Center (for Mac OS 10.1 - 10.2.x), or the Printer Setup Utility (for Mac OS 10.3.x and 10.4.x):
    1. Double-click on the [Hard Drive].
    2. Double-click on the [Applications] folder.
    3. Double-click on the [Utilities] folder.
    4. Double-click on the [Print Center] or [Printer Setup Utility].
  2. Double-click on the printer that needs the file sent to it. The print queue window will be displayed.
  3. Drag and drop the file to be sent to the printer in the print queue window below the Name column. The file will be sent to the printer.
To download a file to the printer using CentreWare Internet Services (CWIS):
NOTE: CWIS can only be accessed if the printer is connected to a network that utilizes the TCP/IP protocol. The printer must also contain a valid IP address. If necessary, contact your System Administrator for additional information.
  2. Enter the printer's IP address in the Address field, and then press [Enter] on the keyboard. The CentreWare Internet Services home page will be displayed.
SOURCE: Users manual for the Canon ir c3220
http://www.service.canon.com.au/manuals/ufrv130.pdf Give this a go mate.
Posted on Sep 10, 2008
  • 3 Answers
SOURCE: Unable to print PDF files
use the PS driver for that
Posted on Feb 24, 2009
Why does error come on cannon adding machine
please give information about your computer and model of printer ()
1. PC operation system : choice my computer -> right click -> properties, you can see name of software (for ex. windows xp 32 bit, windows 7, 64 bit )
2.have you disc of device or downloaded from internet
if its from internet may be its connected with compatibility versions of softwares (32 or 64 bit) choice compatible version of driver
3. describe the your all acts during the installation and what written on error message it helps to solve the problem
Dec 31, 2014 | Cannon Office Equipment & Supplies
Cannon 3200 when machine has warmed up error code 000732-001
This is a reader communications error. It's been a long time since I worked an IR-C3200 copier but all cables must be plugged in. They will only go where they were intended to go. Reseat all those cables and good luck, other wise you have a professional help problem. Make sure all the cable checks are done with power off. Then power up agai n and see what happens.
May 07, 2017 | Canon imageRUNNER C3200 Color Printer
How to install the printer
Install a printer.
There are several ways to connect a printer to your computer. Which option you choose depends on the device itself, and whether you're at home or at the office.
Always consult the information that came with your model for specific instructions.
Watch this video to learn how to install a printer (1:40) b9f5cdc8-106a-4599-bc11-9845533e5ef6.jpg
Local printers
The most common way to install a printer is to connect it directly to your computer. This is known as a local printer.
If your printer is a universal serial bus (USB) model, Windows should automatically detect it and begin installation when you plug it in.
If you're installing a wireless printer that connects to your computer over a wireless network (Wi???Fi), you can use the Add a device wizard to install the printer. For instructions, see Connect to Bluetooth and other wireless or network devices.
If it's an older model that connects using the serial or parallel port, you might have to install it manually.
Dec 25, 2010 | Computers & Internet
Problem with printing on canon ir 2200
go to run prompt on client end and typ \\ip add of main pc where ur printer actually connected nd then u will get shared printer on display, u will get shared icon of ur network printer right click there nd connect it .... if it doesnt show any problem to connect it will work nicely ...........
Apr 16, 2010 | Canon (6981A002AA) for imagerunner 2200,...
Can't connect to remote Deskjet 5150
Please, how does your Win 7 x64 machine compare to anything else on your network?
Can any other computer see that printer at all?
When you install the printer locally does that mean by USB, or what please?
Nov 29, 2017 | HP DeskJet 5150 InkJet Printer
How to add cannon iR 2016 to a network?
yes you can connect directly to a router/switch, then its just a matter of giving an IP address to machine and installing printer on PC's
Mar 24, 2009 | Office Equipment & Supplies
Need for Cannon Digital Copier & Printer ir2016j driver
Try www.canon.com. They should have the drivers/software for you in the support area available for free download. Hope this helps & please take a moment to rate this solution. Thanks.
Mar 11, 2009 | Computers & Internet
Canon L:BP3500 with Vista business
Here are solutions to some common problems with Vista that you might encounter while trying to add or use network printers,
If you have used the printer before without problems, try these options:
• Make sure that the network is working and that your computer is properly connected to the network. For more information, see the following Help topics:
View the status of your home network
Identify and resolve home network problems
Troubleshoot network and Internet connection problems
• Check the status of the printer in the print queue, or go to the printer to make sure that is it powered on and ready to use.
• If the printer is plugged in to another computer and shared on the network, make sure that computer is turned on. If it is turned on and the problem persists, contact the computer owner to make sure that the computer is connected to the network.
• If you are trying to print to a printer that you added using a TCP/IP address instead of a printer name, make sure that your computer is connected to the Internet or the network where the printer is installed. If you recently experienced a power outage, the printer TCP/IP address might have changed. The new address will not work with the printer port that you used to connect the printer to your computer. Try to add the printer again. For more information, see Add or remove a printer.
If you recently installed a new version of Windows, changed the printer driver software, or are trying to print to the printer for the first time, you might need to install printer drivers that are compatible with the version of Windows that you're running. If you are trying to use a printer that is plugged in to another computer and shared on the network, make sure that a driver for your version of Windows is installed on the other computer.
Hope this helps
Dec 28, 2007 | Office Equipment & Supplies
121 people viewed this question
k24674
jasbo
jasbo
