Question about Universal Remote Control Televison & Video
Polar code 9045698 - Universal Remote Control Televison & Video
F28 error code on Maytag front loading washer
The communication between the Central Control Unit (CCU) and the Motor Control Unit (MCU) has failed.
Possible Causes
- Reversed polarity or mis-wire along with open ground switch(es).
- Communication cable from CCU (MI3) to MCU is damaged.
Procedure for reversed polarity or mis-wire
1. Clear error code.
2. Unplug washer or disconnect power.
3. Check the white wire on the RFI filter to ensure correct polarity.White wire needs to be toward front of washer.
4. Check outlet for correct polarity. To check within washer for polarity at the RFI, white to cabinet ground must be 0 volts.
5. Check that the ground switches of the toe panel and rear panel are correctly closed.
If switches are good ,replace the CCU.
Oct 14, 2016 | Maytag Washing Machines
Dvd code polar dvd
258,255,250,259. Try these codes. If you wish to get more, try the following links. Both the sites linked have set-up code list & set-up procedure to many popular brand remote controls.
http://electrohelponline.blogspot.com/
http://electro-medical.blogspot.com/
Jan 21, 2014 | Philips SRP2003/27 Remote Control
Polar code 9074993
Codes are 4257 4477 4499. If you wish to get more, http://electrohelponline.blogspot.com/ Pull up previous posts there, either by its left side bar, or view it in Timeslide option.
Jul 10, 2013 | Televison & Video
I need the manual of my polar electro ce0537
Hi! Welcome to FixYa,
Please refer to the link below for the manual of polar electro ce0537:
http://www.polar.fi/en/support/product_support?document=/gip/PKBStoGIP.nsf/LINK/xAF42D5B7E6C545CF422569F400405E36?OpenDocument
You have a great day and thanks for using FixYA!
Jun 20, 2011 | Polar Electro Wearlink Coded Watch
What is the code in all of the polar games?
Unfortunately each game has a different code. The only way to acquire the code is by unlocking the game, which can only be done if you bought it.
Jun 16, 2011 | Polar Bowler for Windows
My wife asked me to set the time on her watch. She no longer has a manual. Can you help? It is a polar CE0537 Polar Electro and has two side buttons but no button in front. Thank you.
There is a link to download any Polar manual in PDF form in my tips and tricks page.
Are you sure there is no button in front? Polar watches are all activated for exercise recording by a front button. And if it is an A5 as the request and picture show there is definitely a front button.
On the back of the unit, near the upper portion of the backing will be the model number it will be a letter/ number code like A5, M32, etc... The CE0537 is a different coding than the model itself. You will need the model number for the correct manual.
Apr 25, 2011 | Polar A5 Wrist Watch
I need the polar bowler unlock code
look here..
www.crackfound.com ^_^
Sep 10, 2009 | Polar Bowler for Windows
Install manual says to use 3- 16AWG 'polar' wires to connect condensor to indoor unit & 2-22AWG 'non-polar' wires for control. What is'polar' wire?
Polar refers to polarity. When dealing with the power you have to use color coded wire usually red, black, and white. This is so you don't incorrectly hook it up and cause a short. On the control it does not matter if you use coded wire. It is just to complete a 2 wire sine circuit for a thermostat. Hope that helps.
Jul 01, 2009 | Mitsubishi Heating & Cooling
My watch band is ripted
I don't know this watch in particular, but I know there are two main types of bands. Coded and non-coded. The S120 uses non-coded. That means you can use possibly any band on the market. Bands I know are compatible: Sigma and Ciclosport. The Polar bands are sealed, so you can use them while swimming. That's not true of the other two I mentioned - but the upside is you can replace the battery yourself once it wears down. You can probably get a replacement band from Polar directly, or buy a cheap knockoff elsewhere.
Jun 05, 2009 | Polar S120 Wrist Watch
Televison & Video Logo
114 people viewed this question
Top Universal Remote Control Televison & Video Experts
Computer Repairing
Computer Repairing
Are you an Universal Remote Control Televison and Video Expert? Answer questions, earn points and help others
