Question about RCA P52926 52" Rear Projection Television
RCA keeps flicking from 16x9 to normal square during a movie -
It does not interrupt the movie, just every 5 seconds the screen size changes!!! Any thoughts?
    Sergeant:
    Champion:
  • 375 Answers
Eeporm settings
Posted on Aug 22, 2007
SOURCE:
Sony Grand Wega KDS-R60XBR1
yOU SHOULD HAVE 2 MORE SETTINGS ZOOM AND EXTENDED ZOOM THIS SHOULD FILL OUT YOUR SCREEN, THE REASON FOR THE SMALLER PICTURE WHEN IN REGULAR CABLE IS BECAUSE IT IS SENT IN 4X3 FORMAT INSTEAD OF 16X9.
Nov 22, 2009 | Sony Grand WEGA KDF-60XS955 60" Rear...
Picture is too big for screen
You will have a button on the _original_ remote that says Format, Aspect Ratio, Zoom, Size or just AR. It will cycle through Normal, Stretch, Partial Zoom, Zoom, Gray Bar, or the like. You are not in Normal but in one of the Zooms. Stretch is used to make 4x3 movies fill a 16x9 screen, may not be desirable. Zoom is used to fill the 16x9 screen with movies that have been letter boxed. Gray Bar fills the sides of a 4x3 picture on a 16x9 set with gray to "avoid" burn in. Use normal except zoom on LB. -Ken
Oct 04, 2009 | Insignia 32" 720p Flat-Panel LCD HDTV
It shows picture not in full screen like the movies black screen at top,in middle is the picture,black screen at bottom
If this happen on DVD's it is because the DVD is formated to Widescreen, 16x9 size, your TV is 4x3 size. Unless the Menu has an option of Picture size, or Format, to set to Full screen. there is nothing you can do other than be sure to check the DVD for picture format size before purchasing.
Sep 28, 2009 | Hitachi 43F300 43" Rear Projection...
Heads cut off on the screen
Ocean's Eleven. Best remake movie, I think.
I believe your TV is in "ZOOM" mode for the screen. This will make a 4x3 picture come up closer to fill in the 16x9 screen, but this cuts off the top and the bottom.
Keep pressing the WIDE button on your remote until the picture looks best.
If you have HD channels, the screen mode should be on NORMAL. HD channels will have the 16x9 screen format.
The non-HD channels will have 4x3 screen format. When the screen mode is on NORMAL, you will have the cut off picture on the sides because the 4x3 format will not fill in a 16x9 screen.
May 30, 2009 | Vizio Gallevia GV42LF 42 in. LCD...
Rca scenium 52" has light bar area down each side
I take it that you have watched many hours of 4x3 video on this 16x9 TV . What you see is evidence of screen burn, like they used to warn about with the old "pong" type games with stationary objects. The 4x3 pattern is burned into the phosphor in the projection tubes. the area of the burned pattern is not as efficient as the unused areas that make up the 16x9. If you watch enough 16x9 it may even out somewhat, but will never be perfect. Replacing the tubes will fix it, but they're pricey, and you may be subject to it happening again, depending on your viewing habits.
May 25, 2009 | RCA Scenium M50WH187 50" HDTV
Picture size off with 1080i
Thats as good as youre going to get bc its a projection set. Use the non hd input.
Sep 03, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
I have an rca scenium
turn off autoformat in customer setup
Feb 25, 2007 | RCA Scenium HD65W20 65" Rear Projection...
Black bars in the picture
For Models: CC4352, CC4362, CC4393. Your camcorder has a wide format recording mode that lets you make recordings compatible with the 16x9 format. When 16x9 is activated, the camcorder records black bars at the top and bottom of the picture to produce the wide-screen (movie) effect. This is also known as "letterbox" recording. Do not use this mode unless you have a compatible 16x9 TV. When played on a regular TV, black bars appear on the screen. If the 16x9 feature is activated on your camcorder and you want to turn it off, press REC/PAUSE to pause recording, and repeatedly press DIGITAL EFFECTS until no digital effects display appears.
Sep 06, 2005 | RCA CC-432 Camcorder
RCA P52926 52" Rear Projection Television Logo
Top RCA Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
