Question about Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Kdl46ex500 I have had the TV for less then 3 years and it just shut off on its own and will not turn back on. Is there a way to reset the device?
Tv wont power on
If you have a light flashing, it might be the lamp has burned out.
Also the instant on power supply may have failed. Hard to tell anymore from description...
Dec 23, 2013 | Sony KDL46EX500 46 in. HD-Ready TV
Tv will not turn on
If the tv is connected to a stabilizer check whether its working or not...if its working then u hv some problem on the tv's pcb.
No sound kdl46ex500
Check the audio output settings in the menus. Check the sound bar with a CD player audio signal, make sure it is plugged in the correct place.
Oct 01, 2012 | Sony KDL46EX500 46 in. HD-Ready TV
TV suddenly shut off, blinking red light in power button
The TV's power supply capacitors probably went bad.
Check with a mobile tv repair co. to see if it is worth fixing.
Dec 20, 2017 | JVC GD-V502U 50 in. Plasma Television
RCA P52937SG
Time to replace.
Mar 10, 2017 | Televison & Video
TURNS OFF BY ITSELF
my tv starts turning a red color and then turns off by itsself then i have to unplug it to turn it back on every 5 mintues or so.
Nov 14, 2007 | Toshiba 46H84 46" Rear Projection...
TV won't turn on, no status lights, nothing.
urn on you tv after it goes off
go to front press menu and device at same time
it will recycle and the green will start flashing
count the cycles a three flash pause and than a 7 flash
will mean a bad fan
there is fan in the back that cools a heat sink
it is easy to get to
sometimes the connection goes bad
you can check your fan
dont order one from mit
this is a standard 3 wire 50mm x50mm computer heat sink fan
take yours out and find one to match
cost about 6-8 dollars unless you have laying form old computers
you have to take off the plastic cover in the back no big deal
with cover off yu will see a metal cover looks like a tunnel at the bottom
three screws removes it wires are under
after removal you will see the fan and heat sink
put you filter on the side back on with the two screws
so that the tv will start plug it back in turn power and see if the fan spins
if not check connects no run after that
than replace this fan
mine worked fine with new fan
if need more help you email me at tileman22@comcast.net
Nov 03, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Sony BRAVIA  KDL-46S2000 46 in. LCD HDTV Logo
61 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
