Question about Intel Computers & Internet
Dark speck on processor
My computer shuts-off suddenly and often hangs while working with windows and prior to starting windows, I have noticed that my intel p4 3.0 ghz pinless processor has got a dark spot on it and my motherboard is Lenovo 20KT48AUS with 2 gb ram, but 1 socket pin is bent on my motherboard, what should I do?
  • 4 Answers
It may be the temperature problem. If the heatsink and the fan does not sit tight on processor the heat from the processor will not be dissipated properly and the heat rises up and the processor shuts off as soon as it starts working. So please see that the heat sink and the fan on the mother board sits tight. Also apply heatsink paste on the surface of the processor which comes in to contact with the heatsink. It comes filled in Syringe and retails around Rs.10-20 only. I think it will solve your shotdown problem.
Posted on Jul 06, 2013
ldnleaf
  • 7 Answers
SOURCE: upgradation to 1 gb ram
Go to this site http://www.crucial.com/ and follow the instructions and it will give you the ram that is compatible for your system.
Without knowing the manufacturer
and model it is difficult to give you the info. Use the site above and it will be specific.
Posted on Apr 25, 2008
marked
  • 6487 Answers
SOURCE: Can you add to much Ram for the processor to handle?
That additional RMA will be good for your computer so it will be much faster and don't worry everything should work fine there after adding new RAM to your computer....
Posted on Jan 13, 2009
marked
  • 6487 Answers
SOURCE: Can I put to much RAM in the motherboard for the Processor?
That additional RAM will be good for your computer so it will be much faster and don't worry everything should work fine there after adding new RAM to your computer....
micromend
  • 748 Answers
SOURCE: i dont know where the model number on my computer is
I have to assume the sound is derived from the mother board. We'll need the Manufacturer of the motherboard (not the chips) i.e. Intel, Assus etc. and the model # which should be printed very close to the manufacturers name.
Posted on Mar 26, 2009
coolguym342
  • 52 Answers
SOURCE: i have an Intel(R) pentium(R) 4 CPU 2.80 GHz and
ya surely it will work properly...no doubt on that
Posted on Jul 11, 2009
I have a Speck Pump, model E71, only a year old. It suddenly stopped working - it was fine at the start of the season. The problem is that it just hums when turned on.
Since it hums it has power. I believe there is a start capacitor on it, that or the start switch may have failed.
Speck Pumps Pool Pump Parts
usa speck pumps com
have Speck Pump model E71 only year old It suddenly stopped working it was...
Speck Pumps Pool Products Inc
Jul 02, 2016 | Speck Pumps Pool & Spa
Dark spot on pinless processor
the computer tends to shut down when the procssor ovrheats and if u removed the processor or the heatsync for that matter you have to remove old termo pate and replace it with new termo paste otherwise your brossesor will burn out
May 08, 2013 | Intel Computers & Internet
My Lenovo U165 hung, and after waiting for the system to resume, the laptop suddenly freaked, screen went blue (with white text) for a split second, before the laptop restarted. What happened?
Remove all USB attached devices like drives.
  • Roll back system with System Restore. Win 7 - Start > Search type System Restore. XP - Is Start > All Programs > Accessories > System Restore. Now choose a date prior to problem. You may have to try a few dates.
  • Uninstall last program(s) that was installed, again in safe mode.
Oct 26, 2012 | Lenovo IdeaPad U160 Laptop Computer...
When I boot my computer the monitor flashes the Windows XP logo then goes dark and the computer shuts down and then restarts itself and start the process all over again and again
Try starting it in safe mode, F8 during the boot process, this loads a windows shell, once active, run a system restore.
(Programmes - Accessories - System tools - System restore)
Choose a date prior to your problems.
Sep 12, 2010 | Kogi L7CH Monitor
System hangs up frequently
Might be a loose RAM (memory stick). Try removing it and then connect it again properly and see if it solves the Problem.
Jul 12, 2009 | Intel Pentium Dual-core Processor E5200...
Computer hangs up on shutting down screen
Ok.....
1. Make sure ALL user accounts are logged off!!!
2. UPDATE ALL DRIVERS
3. Check to see how many Programs are running while attempting to Shutdown the PC..(the more programs it tries to close, the longer it can take...(ESPECIALLY WITH LOW AMOUNT OF RAM/SLOWER RAM)
Mar 22, 2009 | Toshiba Satellite Laptop with AMD Athlon...
Shutting down
Look...maybe the processor cooler is dusted.If the processor get to varm hes shut down.
Nov 22, 2008 | Intel Compaq EVO D500 (RBMDTCPQP42400) PC...
Hangs up
Did you notice that the computer started freezing after you have installed any software or any type of hardware to the computer. If yes, then uinstall the software or remove the hardware and the drivers and check.
You may also try to do a system restore prior to the date you started having problems with the computer.
If not, then back up all you data and reinstall the OS.
Feb 18, 2008 | Computers & Internet
CPU Hung
Hello Wolf, It sounds to me like the processor fan is not working correctly. When you put a load on the processor like programs, movies or games, it overheats and hangs up. Try taking a fan, and with the side removed from your case, have the fan blowing into the case, and try a movie or a game. If it does not hang up, replace the processor cooler and fan. Please let us know how it works for you, and if we can help you in any other way. Best regards, nightdiver
Oct 08, 2006 | Intel Celeron, 1.8 GHz Processor
Computers & Internet Logo
85 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
