Question about RTO Gas Motor Scooter 50cc
Baccio scooter 50cc bogging down
Needed gas got premium now running rough 3 day of ownership ran great before
4 Suggested Answers
SOURCE: my 2005 50cc kymco cobra racer scooter does not start
i have fire and new cdi ran find for 2 days but hard to start now it will not start
Posted on Mar 26, 2011
SOURCE: I have a 20023 Gelley 50cc scooter that doesn't
check fuel filter
Posted on Apr 01, 2011
SOURCE: 50cc moped runs great until full throttle then boggs down-does not do it at 1/2 or 3/4 throttle
Check for good fuel flow to carburator. If so have a qualified technician look in the carb for debris blocking the main jet. this is very common when the vehicle sits for an extended period of time.
Posted on Dec 28, 2011
My 50cc scooter won't go over 30mph
Hi, Bob and the usual suspects are:
1. Idle speed improperly adjusted.
2. Inlet system air leak.
3. Damaged or restricted fuel tank venting system.
4. Dirty or damaged air cleaner element.
5. The accelerator pump is inoperative.
6. Vacuum piston assembly malfunction.
7. Enrichener valve is not seated or leaking.
8. Restricted fuel supply tract.
9. Plugged bowl vent.
10. Loose or plugged fuel and air jets or passages.
11. Improper float level.
12. Worn or damaged needle or needle jet.
13. Loose or plugged main jets or passages.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Help Ruck won go above 30mph Thanks
Advice please 49cc won go over 20 mph
gy6 50cc to 100cc bbk upgrade still wont go over 30mph It Is The Ride
My scooter won reach top speed anymore scooters
SCOOTER WONT GO OVER 20MPH HELP
Mar 28, 2017 | GAS Motorcycles
My 50cc scooter(chinese) hesitates at full throttle, almost like it wants to stall and then it kicks back in. Could this be a problem with the carburetor valve?
Hi, Randy and the usual suspects are:
1. Inlet system air leak.
2. Enrichener valve not seated or leaking.
3. Damaged or restricted fuel tank vent system.
4. Restricted fuel supply tract.
5. Dirty or damaged air cleaner element.
6. Plugged bowl vent or overflow.
7. Worn or damaged needle or needle jet.
8. Vacuum piston assembly malfunction.
9. Loose or plugged main jets or passages.
10. Improper float level.
11. Accelerator pumps inoperative.
Chinese Scooter Club View topic Hesitation On Acceleration
Why is the engine bogging under acceleration Suzuki FA50 Moped
scooter keep bogging down under throttle
1 HOW TO FIX Most common MOPED Carb problem
How to tune in scooter carburetor
Mar 24, 2017 | Motorcycles
Keeway matrix 50cc scooter cuts starts to cut out after it gets warmed up
CHECK VOLTAGE WITH VOLT METER AND GAS/OIL MIX COULD BE RUNNING ROUGH
Apr 10, 2013 | 2006 Keeway Matrix 50
50cc taotao scooter the carb is runs then fills with gas untill it stalls out dont get much off the searchs i have made dont no if it is the carb our choke broke down carb and looks clean no clogs or
My 2012 Taotao 49cc scooter was spitting and sputtering then just died one day. I brought to a small engine repair person and come to find out, the hoses that came off the carb had cracks in them. Changed the hoses and the problem went away. Hope this helps.. I have since replaced the cheap hoses with new ones from the auto parts store and never had the problem again.
Oct 21, 2012 | Star 50cc scooter for kid
I rode my 50cc scooter in the rain, with no air filter.
If you allowed water to get into the air inlet, if a 2stroke, I suspect the crankcase seals are damaged. If 4 stroke check compression for damaged piston.
May 28, 2017 | Star 50cc MOTOR SCOOTER
Dec 28, 2011 | RTO Gas Motor Scooter 50cc
My 2005 50cc kymco cobra racer scooter does not start
Jun 27, 2010 | RTO 50cc Moped Scooter
Baccio vx50 won't start, no sound, crank at all.
where are you located? i may be able to help with your baccio vx50
Apr 16, 2010 | Peg Perego Vespa Scooter
RTO Gas Motor Scooter 50cc Logo
27 people viewed this question
Top RTO Toys Experts
The Scrivener
Pete Bruk
rostit
Are you a RTO Toy Expert? Answer questions, earn points and help others
