Question about Cameras
Opteka C450D how do I open the door to the battery compartment
How do I fix a jammed battery compartment in a kidde i12060 smoke detector?
You could try to pry the door loose with a small screwdriver. To be safe, make sure the primary 110V power is turned off before trying to loosen the compartment door.
This is an inexpensive unit, less than $10, and is easily replaced if you can't get the door open.
If you do decide to replace it, you may want to look into a combination unit which monitors smoke and carbon monoxide if you don't have a carbon monoxide detector already in your home.
Aug 26, 2015 | Kidde i12060 Hardwire w/ Front Load...
Open battery compartment
Spray WD-40 around the compartment door and try to let it trickle inside the compartment. That should break the acid corrosion buildup that holds the door from opening.
Oct 19, 2013 | Nikon F601 35mm SLR Camera
My keyless entry pad will let garage down when code is keyed in, but when code has been keyed up to let it up it will not do so.
I assume you mean that the entry keypad works when the door is open but not when the door is closed. This usually indicates that the signal strength on the entry pad is low. Try changing the battery.
Insert a small Philips screwdriver in the opening on the bottom of the battery compartment cover. Pull the cover slightly outwards then pull the cover down. The battery in the compartment is a 9V battery. Then replace the cover by inserting the lip in the top of the battery compartment and then snap it into place.
If you change the battery quickly, you shouldn't need to reprogram the opener. If a new battery doesn't solve the problem, check what may be causing signal interference when the door is down. (Consider moving the keypad to a spot closer to the door opening. I know that we have the keypads placed on the side of the door jamb on our garage doors. When the small handheld remote units start to loose their batteries, bringing the remotes to that area that often works.)
I hope this helps.
Oct 04, 2013 | Sears Craftsman LiftMaster Chamberlain...
Can't open service door
HP Support > Probook 4530S Notebook PC > Manuals > Service Manual,
http://h20000.www2.hp.com/bizsupport/TechSupport/DocumentIndex.jsp?contentType=SupportManual&lang=en&cc=us&docIndexId=64179&taskId=101&prodTypeId=321957&prodSeriesId=5060880#1
Under the bold subheading -
Service and maintenance information -
Click on -
HP Probook 4530S Notebook PC and HP Probook 4730S Notebook PC - Maintenance and Service Guide
Bottom Door - Page 49
1) Remove ALL power. Remove the AC adapter (Charger), and Battery.
2) Position laptop bottom side up, Battery Compartment facing you.
3) Remove the Locking Screw if installed.
(Area where Battery Compartment meets Bottom Door, and in the Middle; is screw location)
4) Slide the Bottom Door release latches to release the door.
(One latch on each side of Bottom Door; where Bottom Door meets Battery Compartment. The Latches slide to the INSIDE of the laptop)
5) Slide the door towards the Front of the computer, and lift off.
(Front of computer is AWAY from you. On the opposite side of the Battery Compartment)
Regards,
joecoolvette
[ P.S., you remove the Bottom Door; you wear an ESD wrist strap, and have it's alligator clip attached to a good ground source; or you risk using the laptop for a Frisbee from now on, or a doorstop.
Average cost is around $3 to $6 ]
Nov 06, 2012 | HEWLETT-PACKARD Probook 4530S 156 I52410M
How to change battery
Hi, try:
To install the battery:
Note: To open the battery door, you will need a paper clip or thin pen.
1. Take the paper clip and use the end to press down on the door latch.
2. Holding the latch down, push the battery door up.
3. The door will slide up and spring open, allowing you to access the batteries.
4. Place the battery into the compartment. Be sure to match the (-) on the
battery with the (-) inside the compartment.
5. Slide the battery cover to its original
Jun 09, 2011 | Disney Pix Micro Digital Camera
Open battery compartment on outside battery base??? i want to change batteries on the unit but cant open door for battery??
I finally got mine open a few minutes ago by prying it with a knife. A thin screwdriver would have been safer.
Dec 18, 2010 | Sears Craftsman LiftMaster Chamberlain...
I cannot find a way to open the compartment to change battery in mouse. Have pressed button and pushed and pulled - nothing
This help?? >>>>>>>>>>>>>>>
Where do I change the batteries for my mouse? I can't find where the batteries go.
Answer
This article applies to the following products:
All Logitech cordless mice
For some cordless mice or trackballs, there is a slot for the battery door on the bottom of the mouse. Between the slot and the outside edge of the door is a thin strip of plastic. If you compress this thin strip of plastic towards the slot, the catch on the door will release and the door should open.
On other mice, the battery door is on the top of the mouse. Simply slide the top of the mouse cover down and lift the door up. There should be an etched diagram on the door indicating which direction to slide the door.
Once you have opened the battery door, remove the old batteries and dispose of them according to your local waste disposal regulations. Then insert the new batteries into the battery compartment using the diagram in the compartment as a guide. When you have finished inserting the batteries, replace the battery door.
Mar 28, 2010 | Logitech Cordless Mouse
How do you open battery compartment on the 1500?
With the 1500 facing you, the "B" is on the right, The "B" is on the battery door. The lever snaps to the right, push the battery door far right edge to the left... this should work
Mar 20, 2009 | Bushnell PinSeeker 1500 20-5103...
Opteka tripod quick release replacement
I was looking for the same and found it on Opteka's site.
http://opteka.com/replacementquick-releaseplatefortheoptekaopt-700070full-sizetripod.aspx
Jan 04, 2009 | Opteka (OPT7000) Tripod
Cameras Logo
20 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
