Related Tags:
This problem should be removed because:
Problem with Hamat 3-2861ST Everest Pull-Out Kitchen Faucet with Lever Handle Stainless...
I have a Hamat faucet that has low water pressure all of a sudden
The faucet is a Hamat A12.18.1M and is now only providing half the water pressure that it used to provide. I removed the faucet from it's supply tube and the water pressure is still great out of the supply tube. It must be a problem in the faucet itself, but I can't figure out how to remove any parts from the Pull out sprayer handle. Any ideas how to disassemble it to clean out any mineral blockages or other brocken parts?
Solutions (2)
Best Solution
I have the exact same faucet from Hamat and I just took it apart ...every last bit....the tabs on each part are notched so when you put it all back again...its pretty easy....I had every single part layed across the table.
(Below is the red neck way....without the special tool to take off the top key part which requires a special T tool)
now for the desembly.... under the handle is the red/blue button...unscrew carefully not to ruin the color...if it does not come out ...pry it out...mine was not so friendly....then take a small hex and stick it in the hole and unscrew a small screw....whalllaaa ...the top is off....now for the only hard part of this whole project....without their special tool your going to have to take a vice grip layed over a cotton cloth and clamp it on the top back side perpedicular....on the actual crome/stainless steel....this part will not be seen from the front.... I did scratch mine a bit ...but dont see it after the fix...remember it under the handle on the backside....then take another vice grip and cloth to the part you stick in the counter....(not the threads of course...just above) then with hulk like procedures your going to give it all.....hold with the left the base vice grip....and with the top ...crank it counter clockwise....again with the vice grip perpendicular ...on the back edge...I had to use a small screwdriver or rod to stick it across the vice grip for leverage.....erggggg....got it.
after that take note of how the part fall out.....eventuallly you might need to take out the cylinder.....remove the hose (did it at begininng) then wiggle....and pull out the cylinder...dont unscrew....back and forth in 10 degree turns as you pull out.....this is not screwed in.....Only One big screw already taken care off... the hoses connected in the interior are tough and for some wierd reason need a 10mm wrench.
Ok good luck....and by the way MINE DID NOT HAVE HOT WIRE...a part of rubber washer came loose from my plumbing under the counter and found its way to block hot water...inside the very core of the faucet....oh well ALLL DONE.... hot water for dishes...for my wife...just kidding.
Pull spray head out and remove hose at end then turn on water to flush out. Please rate. Thanks
I need to find a replacement Hamat part
I have a Hamat 3-2861 Kitchen faucet that is leaking and I need to replace the head. It is pre-2003
How do you repace a sprayer head on a kitchen...
How do you repace a sprayer head on a kitchen faucet?
I have a Hamat 3-2861 faucet. The sink is being replaced under warranty and I must remove the faucet and re-install it. I desire the...
The spray feature will not stay on when button is
The spray feature will not stay on when button is pressed. The water volume coming out of the head is much less than when originally...
Add Your Solution
i need to replace washer for hamat kitchen faucet
i need to replace washer for hamat kitchen faucet 3-3942-pc. im having trouble locating this part. help!
Need to replace: Everest
Need to replace: Everest pressure balance shower valve, HAM-2-2990-CP where can I find it (I live in NYC on upper west...
The sprayer broke clean. Looks
The sprayer broke clean. Looks like a red sealant was broken.
I want to replace the washer but don't know...
I want to replace the washer but don't know how to take out the lever (the top)?
WON'T SPRAY, I TOOK IT APART NOW IT WON'T...
WON'T SPRAY, I TOOK IT APART NOW IT WON'T SPRAY MODEL 3-2861 EVEREST 30361
See all Hamat 3-2861ST Everest Pull-Out Kitchen Faucet Problems
Fix-O-Meter
624
624 people viewed this problem
- 3 people found this problem to be helpful.
- 0 people are following this problem. Be the first!
Verification:
Please enter the characters below to complete your post
Can't read it? Try a different one
