Question about Garden
Murray Ride On Mower
Motor back fires when engage cutting deck
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,917 Answers
Need to adjust govenor
Posted on Jun 07, 2014
2 Suggested Answers
  • 603 Answers
SOURCE: hi, I have an older Murray ride on mower, small
Sounds like you have some sort of seize up problem in your deck assembly. Have someone help you with this check, start your engine, engage the blade or blades, and have someone watch the shoot from a distance to see if blade or blades turn. if not then your problem is in the area of top pulley and blade or blades. You may need to replace or loosen the pulley to blade shaft. Sometimes this part is repairable where you can replace bearings or bushings and sometimes the whole unit needs to be replaced. Look to see if there are grease fittings on this unit. Try oil anywhere it will flow down in between areas that may be seized and work on loosening up the pulley blade assembly.
If this doesn't help, go to some of your local mower repair shops, they may be able to sell you a used part. Remember to bring mower information with you so they can help you with the correct part.
I hope this has been helpful to you. GOOD LUCK.
Posted on Jul 19, 2011
Mowers shuts off when I engage the pto switch, I jumped all of the safety switches,put new pto switch on, belt and pulleys are fine! Please help
Craftsman Garden Tractor 917.28746 Engine shuts off when ...
www.shopyourway.com > Manage My Life > Questions
Craftsman Garden Tractor 917.28746 Engine shuts off when engaging mower deck. 917.28746 ... Then start the tractor and pull the pto button out. If the engine ...
Why does my engine die when the blade is engaged ... - iFixit
https://www.ifixit.com/.../Why+does+my+engine+die+when+the+bl...
iFixitI have an older Murray riding lawn mower, whenever I engage the mower the engine dies, otherwise it runs .... My dr feild brush mower ... cuts off when I engage theblades. ... My Huskee only shut off once I put it in drive with the blade engage.
Riding Lawn Mower Problem - Dies when PTO engaged - GardenWeb
forums2.gardenweb.com > Garden Forums > Tractors
Apr 28, 2008 - When I pull the switch to engage the PTO, the engine bogs down real ...off I can keep the engine running with the mower engaged then it is fine ... Riding mower cuts out
May 18, 2010
mower dies when I let off the clutch
Sep 19, 2008
pto on Cub Cadet will not stay engaged...
Apr 6, 2008
Craftsman Mower deck (clutch) Won't engage
Jul 1, 2006
More results from forums2.gardenweb.com
Dec 29, 2015 | Garden
How do I fix my Murray riding lawn mower? The motor will not fire;
coil,safety switches,ignition switch,fuse,connected wrong,,,choose 1 to eliminate then go to the next,etc,,,etc,,
pull the black wire off of the coil,try to start,if it works,the safety switches(1 or 2 or 3 out of 3)are bad,seat,brake/clutch,deck switches,if not,then the coil is bad,pull the ign switch out,clean all contacts on back and plug back in
May 25, 2015 | Murray Garden
Spring mount location for belt tensioner for murray 45256x92a
Try this site to get your manual and see if the exploded parts diagrams help
Mar 30, 2015 | Murray Garden
Ride on mower can ride around but whe engage fanbelt for cutter motor stall no power but very thing does turn easy with hand
Sounds like your mower deck safety switch is bad..it is located near the end of the handle that engages the mower deck..try unhooking it and bypassing it with a wire or heavy paper clip...then try mowing if it mows that is your problem..the mower deck will,operate that way but is a safety switch..you need to get it replace,,easy to do yourself..good luck.
Jan 09, 2014 | Briggs & Stratton Garden
Murray Select 16.5 hp OHV 42
is one of the blades bent?is one of the bearing s seized or binding
Apr 16, 2012 | Briggs & Stratton Garden
Hi, I have an older Murray ride on mower, small
Jul 19, 2011 | Briggs & Stratton Briggs Stratton...
Murray ride-on lawn mower model 155/107 (15.5 HP Briggs & Stratton engine). Engine starts o.k. but cuts out as soon as the hydraulic clutch is engaged via foot pedal. ie foot on clutch to start...
two possible problems. check power from safty switchs, put the lever down under the seat and rock the back tires back and forth until you here a click. then try again. a safty swith is giving you problems
Apr 25, 2011 | Garden
Deck trouble with a murray 40: cut mower
A hanger may have come loose from the deck that needs to be reattached.
Plus check your tire pressure, one tire with less air than the other will make it cut lop sided.
Sep 26, 2009 | Garden
Husqvarna YTH20K46
Is this the first time cutting grass with a lawn tractor?
How tall of grass?
Use the grass cutting heigth adjustments on the tractor to a higher setting when cutting tall grass. Cut again to a lower height setting on the second pass. Grass higher than your tractor is not good for your tractor. Follow the manual instructions for best results.
Jun 27, 2009 | Husqvarna 23 Hp 48" Deck Yard Tractor
Garden Logo
15 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
