Question about Samsung Televison & Video
In samsung plazma ps42b450b1 fault is picture/screen brightness flrctuat continuously..what can i do?.
My 40 Samsung flat screen TV its having picture problem, i tried to balance the brightness,sharpness, co lour everything but they are still appeared poor, i don't know why?
Sounds like main board fault. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Aug 24, 2015 | Samsung Televison & Video
My lg 32inch plazma tv is showing faint blue on screen without picture.
Faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent.
Feb 14, 2015 | LG 32LX1D 32 in. LCD Television
Have a samsung PN64D550 plazma with 3/4 inch black horizonal line. What is repair solution?? and is this something that I can do myself?
Faults & possible causes to LCD & Plasma TVs are given with screen-shots. You can get an idea about the fault to an extent.
Jan 11, 2015 | Samsung PN64D550 64 1080p 3D Plasma HDTV
Yellow screen, no picture, but sound is complete
i think maybe the video board...
can you take a picture to be more sure..
thanks!!
Feb 10, 2010 | Samsung LN-T4665F 46 in. LCD Television
When Playing Halo 3... The Screen Shrinks Down...
kyleolver,
16:9 is the widescreen mode, the other size is 4:3 ratio which is what the game's native size, it is picture boxing by the plazma is showing the size as not to distort the image, to get the full screen picture, but make sure it's not the plazma's setting first - where it selects the size of the image, you may have the streched version on your normal play.
randy320sgi
Dec 21, 2008 | Samsung HP-R4272 42 in. Plasma HDTV
SAMSUNG LCD TV FAULT
samsung lcd tv 40inch modle .LA 40c 53F1R negitve video and brightness high plz send id mirzarashidbaig126@yahoo.com
Dec 12, 2008 | Televison & Video
Samsung hpr4252x perfect picture in
You have a burn in problem from watching widescreen movies.If you have access to a signal generator or tv setup disc run a perfectly white screen on the plasma for about 30 min.This should help even out the pixels on the display.
Mar 05, 2008 | Samsung HP-R4252 42 in. Plasma HDTV
Changing Screen Size on Samsung HP-R4272
you must not have the correct picture settings in the cable box, as although they are not HD they will still be widescreen, so check both tv and box for picture settings.
Oct 14, 2007 | Samsung HP-R4272 42 in. Plasma HDTV
Televison & Video Logo
24 people viewed this question
Henry  Thomas
Henry Thomas
