SOURCE: priter is showing a error code 5B00
* With the printer powered off but connected to a power source, press
the Power button while pressing and holding the Stop/ Reset button.
* When the Power is lit, press the Stop/Reset button two times while pressing and holding the Power button.
* When releasing the Power button and the Stop / Reset button
(regardless of order), the printer will move into a service mode.
(Waiting for menu selection)
* When the on/off lights in green,
press the Stop/Reset button the specified number of time(s) according
to the function listed in the table below.(Each time the Stop/Reset
button is pressed, the LED lights alternately in orange and green,
starting with orange.)note: press 4 times for waste ink counter reset.
SOURCE: Check Printer (5B00)
try this -
1) Enter SERVICE MODE By pressing Menu-Scan-Copy-Scan
2) Enter NVRAM by presing <--- or ---> then OK
3) SET ABS-M LEVEL TO 0
4) OK
good luck
SOURCE: i have the error code 5b00 on my canon i905d. please help
The error code can only be reset by using diagnostic routines only available to canon shops.
SOURCE: I have a Canon IP4700
Ruwanye
I believe the waste ink counter is full so you need to reset it:
http://fix-your-printer.blogspot.com/2010/11/error-code-5b00-on-canon-ip2700-printer.html
Good Luck
